Old Model Decals Peeling and Lifting - Need Help
    May 2014
Posted by carcrazy on Friday, May 30, 2014 3:52 PM
So I recently moved...Ok well 3 years ago and had all my old models in storage tubs in my basement packed away with packing peanuts. I just started taking them out and all the decals are lifting up and peeling....any suggestions how to reapply them and prevent them from doing this again??? Thanks for the Help!
    August 2007
Posted by DUSTER on Sunday, June 15, 2014 2:36 AM
    Misting on some  warm water? some decal setting solution?, some Future?
Misting verses Spraying  so the very small droplets would give some control of how much your putting on and may soften them just enough to use a paint brush to gently push them into place
Steve
Posted by Don Stauffer on Sunday, June 15, 2014 11:34 AM
I would try decal solvent if the setting solution does not work.  Solvent is more agressive and makes the decal softer and stickier.
    August 2005
Posted by Phil_H on Sunday, June 15, 2014 11:41 AM
With a notable exception (eg. Gunze Mr Mark Setter, which contains an adhesive) or two, generally speaking, decal solvents/setters won't help much if the decals have lifted due to lack of adhesive.
Some decals just aren't that sticky when they are made and sometimes, bad application practices, eg. over-soaking can cause loss of adhesive from the decals.
    November 2008
Posted by plasticjunkie on Sunday, June 15, 2014 9:00 PM
If you can get it, brush on Future.
 GIFMaker.org_jy_Ayj_O
