Using Solvaset
    May 2008
Using Solvaset
Posted by Tom8321 on Sunday, April 19, 2015 7:44 PM
Sorry if this is a repeat but I don't see how to search a specific forum... I only see the SEARCH feature for FineScale.com.  If I'm wrong please let me know how to do this.
Anyway, my question:  I'm getting ready to use Solvaset for the first time and I notice that other decal solutions have 2 parts to the process as in, MicroSol and MicroSet.  Does Solvaset work the same in one step or am I missing something?
Thank you, Tom
Tags: Decal , decals , Solvaset
    August 2007
Posted by DUSTER on Monday, April 20, 2015 12:52 AM
  Solvaset is reputed to be a very strong setting solution. Especially when compared to the Micro Sol/Set type of solutions.
So be very careful in its  use. But others with more experience should be able to give you  specifics.
Steve
Posted by Don Stauffer on Monday, April 20, 2015 8:57 AM
Only use solvaset if you really need to. It is for emergency use, not a normal procedure.  Most times you will not need any decal solvent.  Setting solution is normally enough.  So apply decals with setting solution only.  Wait for decals to dry.  Only if there is a problem do you resort to solvent.
    March 2010
Posted by Nathan T on Monday, April 20, 2015 1:30 PM
Solvaset is used to apply to the top of the decal, after it is laid down. Use sparingly. I dip the brush in the bottle then dab the excess off on a paper towel before I apply it, sort of like dry brushing.
    January 2014
Posted by Silver on Monday, April 20, 2015 2:00 PM
Mix Micro sol w/ micro set in a bottle w/two drops of vinegar and apply on the gloss surface , lay the decal then apply solution .You will be fine
    May 2008
Posted by Tom8321 on Monday, April 20, 2015 7:02 PM
Thanks for all the information especially since I'm sure you've answered this, or a similar question, many times in the past.  In any case, I've been reading a lot about Solvaset and based upon that and what I've just read here I think I'll try Micro Sol/Set first and keep the other for the 'hard cases'.
    November 2008
Posted by plasticjunkie on Friday, April 24, 2015 9:36 AM
For a while I only used Solvaset but got back to using Sol and Set for general use and it works fine. I use Solvaset on thick decals or stubborn ones that just don't want to cooperate.
Once you brush on the Solvaset  do NOT touch the decal, try to remove wrinkles, etc. Let it dry overnight and use a new #11 blade to puncture any bubbles or lightly score a wrinkle then sparingly re apply.
 GIFMaker.org_jy_Ayj_O
    May 2008
Posted by Tom8321 on Friday, April 24, 2015 3:47 PM
Thanks.  Like I said I think I'll follow this rule and use the Solvaset for the think ones.  My MicoSol and Set have come and I'll give it a try today.
    February 2007
Posted by mitsdude on Saturday, April 25, 2015 2:42 AM
I've not  had any problems with Solvaset. I haven't used Micro Sol/Set
Posted by Don Stauffer on Saturday, April 25, 2015 10:31 AM
Micro sol and Micro set are for two different purposes.
    November 2008
Posted by plasticjunkie on Saturday, April 25, 2015 12:48 PM
Right, Set is for positioning the decal and to give it some bite into the surface making it easier to adjust. Sol is then added on top to make the decal snuggle down.
    January 2006
Posted by Paul Budzik on Tuesday, May 5, 2015 12:31 PM
Tom,
I routinely use Solvaset.  This video will explain the order in which I use the solutions ...
Paul
Paul
