Preserving decals
    July 2015
Preserving decals
Posted by Garron on Wednesday, July 8, 2015 6:26 PM
Hi,
I have a question on how I can ensure that my decals stay preserved in good condition. I've gone a bit crazy over the past year stocking up my supply of models that I plan on doing. I now have so many in my stock that it will be years before I get around to doing some of them. Is there any way to ensure that by the time I open up a kit in a few years that the decals haven't faded and cracked?
    January 2006
Posted by dirkpitt77 on Thursday, July 9, 2015 2:39 PM
I don't know that there is a way to preserve them, other than to keep them in a cool, dry place (like the  kit box). Many of  my stash kits are also getting up there in age. Some in the 10-15 year range. If I start one, I will use my scanner to make a duplicate image of the decals. This way I can print them on home decal paper if there is a problem with the original sheet. Also, when I start the decaling process, I will cut one of the smaller, not readily seen decals out and do a test application. This can help you to judge the condition of the sheet, although usually I've found that the bigger sized decals are the ones that give you trouble. Oftentimes decals sheets have several marking versions on them, so you can pick ones you don't want on the model and use those to test, also.
Hope this helps.
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    January 2014
Posted by Silver on Thursday, July 9, 2015 5:16 PM
Preserving them in clear high school type note books w/ clear holders.Stored on a shelf or drawer.
    July 2015
Posted by Garron on Thursday, July 9, 2015 6:12 PM
Hi Chris,
Thanks for the reply. Good advice regarding using a scanner to make a duplicate. I hadn't thought of that!
    December 2011
Posted by Chrisk-k on Thursday, July 9, 2015 8:44 PM
I put decals in zip lock bags and store those bags in a closet.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    June 2014
Posted by USAFASME7 on Friday, August 7, 2015 7:28 AM
I keep mine in a 3-ring binder, in clear document protectors. All categorized by Era.
A lot of people keep them in small Ziploc bags to keep the humidity controlled.
--Rob
Glue Sniffer since 1977
