I call to you airplane builders who put amazing work on your decals
    February 2015
Posted by Billmc on Monday, July 18, 2016 1:27 PM
I am a fat finger model builder. When i get to decals for airplanes, in wich i love by the way, i have the darnest time applying them!. Now i am not talking the stars on the wing of a B-29, lol i can do that,,,,most of the time lol. Its the tiny markings on all scale builds, that are smaller then pea, and only slightly bigger then head of a pin. The stripes that will run the length of a aircraft, how in the world do you apply it 1, with out breaking!, 2- straight and 3- keeping the model with enough soulotion before it drys up?.  Another question?, so i put a coat of future on before i do the decaling, and the decal still wants to stick right where i lay it down, no time to move it in to place. I am i doing something wrong?, right?. Any help would be great.
    May 2009
Posted by Pawel on Monday, July 18, 2016 2:31 PM
Hello!
OK, let me take a shot.
Small decals -> good tweezers. Also, don't keep 'em in the water for too long. Just dip in warm water (holding with said tweezers) and put them on the model near the place where they belong and wait a minute for the glue to dissolve. Check with tweezers or a toothpick, if it already moves on the backing paper. If it does, just slide it on the model where it belongs.
Sticking decals (I mean too soon?) - make sure there is some water between the decal and the coat of future. Make sure the future is really dry (several hours should do it). Some recommend putting a little saliva on the model (I never had to try this one myself!)
Stripes - try drawing a line with pencil to aid you in putting it on straight. You can also try cutting up the stripe in smaler portions and apply them one after another.
It also helps with all decals to prop your model in such way as to have the surface the decal goes on horizontal. This way if you put a drop of water or solvent in place, it stays there.
I hope it helps you - good luck with your modelling projects and have a nice day
Paweł
www.vietnam.net.pl
    January 2013
Posted by BlackSheepTwoOneFour on Monday, July 18, 2016 11:10 PM
Yeah, what he said. Saliva? That's a new one, Pawel, LOL!
    August 2005
Posted by Phil_H on Tuesday, July 19, 2016 8:09 AM
Pawel
At the risk of poking a hole or otherwise damaging decals, I prefer to use a moistened paintbrush for pushing small decals around. Wink
Posted by Don Stauffer on Tuesday, July 19, 2016 9:12 AM
I also endorse Pawel's comments, especially the tweezers.  Do not scrimp buying them. I have several sets of tweezers, most cheap, but one quality set with needle-sharp points.
Proper use of decal setting solutions and solvents is important.  Decal solvents are not the same as setting solutions.  I always use decal set, only use solvents for really tough cases, since you can really screw up a decal when you apply the solvent.
    February 2015
Posted by Billmc on Tuesday, July 19, 2016 9:46 AM
So do you put down a good amount of the decal solution or water, or both. If both do you lay down the solution under the water. Wont the water dissolve the solution?
    September 2012
Posted by GMorrison on Tuesday, July 19, 2016 9:57 AM
Pawel nailed it.
I'd reinforce two of the points.
1. When I was younger, I'd put the decal in a plate of water and wait until I could poke it loose. Bad idea. Now I put it in until I can see that the backing paper has absorbed water, then put it on a piece of paper towel to let it dissolve the glue.
2. Cut up a long decal. The plusses outweigh the minuses.
And...
If you have access to a scanner, make a high res scan of the sheet. It's perfectly legal if it's for yourself.
    May 2012
Posted by pilotjohn on Tuesday, July 19, 2016 2:05 PM
GMorrison
Pawel nailed it.
And...
A second (or third) on cutting longer decals.  You can slide them together and they look just fine.
Separate but related question; soaking the decal for say a minute vs a few seconds.  What is behind the time in the water?  If you are separating the decal from the paper, why not let the water do the work?  If you are putting lots of water under it to slide it around for positioning, it would seem that any glue on the decal isn't it.  What am I missing?  Thanks guys.
John
    May 2009
Posted by Pawel on Tuesday, July 19, 2016 3:58 PM
Hello!
I'm glad you liked my comments. I believe I see the problem now - if you kick the decal with decal solution before positioning it, it will likely stick for good. The thing is to position the decal with some water first. You can also add some MicroSET (!), some even take strong vinegar here for better adhesion. Some printed decals tend to stick on pure MicroSet, but adding some water helps moving the decals. After the decal is positioned to your satisfaction, you can use paper towel or something like that to remove excess water, but be careful - otherwise you're bound to move the decal.. Press down with the paper towel, and just then you can add the MicroSOL, Solvaset or what else you have. It doesn't have to be a lot of it neither.
Good luck with your decals and have a nice day
Paweł
www.vietnam.net.pl
    June 2016
Posted by Murphy's Law on Wednesday, July 20, 2016 8:26 AM
GMorrison
Pawel nailed it.
And...
Probably a dumb question but what does making a scan of the sheet do? do you mean for making another set of decals with a printer?
Posted by Don Stauffer on Wednesday, July 20, 2016 8:40 AM
Billmc
The point of the setting solution is to make the water wetter, reducing the surface tension and eliminate beading up.  So the water does dilute the solution, but this is okay.  I start with just the setting solution (it is already a dilute solution).  If more water is needed, I add it.  The solution may dilute further, but this is usually not a problem.
    February 2015
Posted by Billmc on Wednesday, July 20, 2016 10:53 AM
So the long side decals, stripes, around the crowling??. How the heck do you make these with out breaking! And look like they have not been through a earth quake!
Posted by Don Stauffer on Thursday, July 21, 2016 8:36 AM
My method with those long ones is not to remove the decal from the backing paper ahead of time, but place decal and paper up close to where the decal will go, on the surface of the model.  Then, slide the decal from the backing paper directly to the model.  Do not hold those long decals suspended in space.  They will indeed curl back upon themselves, or fold glue side to glue side.  Sometimes I will hold end of decal to model in the proper place with tweezer, and pull the decal backing paper back away from the decal.
