how do you attach eched parts.
    August 2016
Posted by Beginner on Wednesday, August 24, 2016 8:22 AM
I never work with them before. I am working on a Trumpter Chinese JHU-6 and it has part I have never seen.  Any help would be appriciated. Thanks
Tags: Nick
    May 2013
Posted by hogfanfs on Wednesday, August 24, 2016 6:08 PM
You can use CA glue (Crazy glue), or I use a glue call Gator's Grip Glue. It's an acrylic glue that gives more time to get the piece in place before the glue dries.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    September 2014
Posted by rooster513 on Wednesday, August 24, 2016 7:45 PM
Hogfanfs covered it well. I've used loctite brand super glue. You'll want the thin for quick gluing and the gel for when you want some working time. I just bought a bottle of the Gators Glue and so far I really like it. Allows for a lot of working time which I need:)
-Andy
    June 2014
Posted by Tanker - Builder on Sunday, August 28, 2016 4:53 PM
DITTO !  T.B.
    December 2006
Posted by Jester75 on Sunday, August 28, 2016 6:08 PM
I use CA as well, usually thin and thick viscosities. I apply using a homebrew applicator that anyone can make. It is basically one of the larger sewing needles with the end cut off of the eye leaving the two prongs. The prongs hold the ca until they touch the surface to be glued then it releases into the part. Leaves some pretty clean attachments.
Eric
Posted by Tojo72 on Sunday, August 28, 2016 7:51 PM
Gator glue.
Posted by Don Stauffer on Monday, August 29, 2016 9:08 AM
This thread should probably be in one of the other forums (techniques, maybe).
I and many of my ship modeling buddies use thinned white glue.  The small size and light weight of most PE means you do not need a lot of bond strength.  White glue dries slowly, giving you a lot of time to position piece, and thinned white glue leaves a pretty unobtrusive mark if glue runs out of bond area.
For large pieces like a long area, like long railing lengths, I will put down a couple of small CA spots just to hold the railings in place while I run a bead of white glue along the railing/deck bond line.
    April 2016
Posted by GlennH on Thursday, September 15, 2016 9:04 PM
Great idea with the sewing needle. Thanks!
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
Posted by Don Stauffer on Friday, September 16, 2016 9:39 AM
I also use a needle cut off to make it into a fork. I made two- one for the CA itself and one for the accelerator.  Some of my buddies ask what happens when it gets a CA buildup on them.  Because those things are made with stainless steel, the CA does not stick that well to it, and I clean them off with an X-acto knife- no problem.
    November 2008
Posted by plasticjunkie on Monday, September 19, 2016 5:18 PM
I have been using Aleenes tacky glue. It grabs super quick and dries clear and invisible. It has a strong bond too.
 GIFMaker.org_jy_Ayj_O
