Is it just me?
    November 2015
Is it just me?
Posted by E. Halibut on Thursday, February 27, 2020 1:41 PM
I noticed, after returning to modelling after a 30 year absence, that decals don't adhere to the surface like they used to. I place the decal, on a glossy surface, with Micro Set, and have a hard time getting it to stick. Sometimes they just fall off as soon they dry. Lately I had a decal that after placement had been Micro Soled, given another coat of Future AND a coat of Tamiya Flat Clear, just peeled off during weathering.
Of all the hundreds of decals I placed in my early years, over all kinds of surfaces and without the use of decalling agents, I don't recall that ever happening. Oh, they'd silver, but they stayed put. Has anyone else had the same experience?
Terry Jones, 1942-2020
"He's a very naughty boy!"
    July 2018
Posted by Tickmagnet on Thursday, February 27, 2020 1:59 PM
No I haven't had that issue but have had others. My suggestion is to paint at least your insignia and larger markings. It's a lot less frustrating and much more fun to do.
    September 2012
Posted by GMorrison on Thursday, February 27, 2020 2:08 PM
Try cutting the soak time way down. I generally go about 15 seconds or so and then place it on a piece of paper towel. Test it gently until the glue softens and lets it just begin to slide.
There is of course the whole aftermarket of decals that didn't exist thirty years ago. There, results may vary.
i also try to stay away from set/ sol unless it's obvious that it bneeds it.
And overcoating the decal does nothing to help adhere it, except perhaps around the edges.
Bill
    July 2004
Posted by stikpusher on Thursday, February 27, 2020 4:19 PM
The only time that I've had something happen as described here is with a few Academy brand kits and their own decals. But certainly not with any aftermarket decals, nor with the vast majority of kit decals.
Bil, I'd counter on aftermarket decals of 30 years ago. There were fewer companies, but they had extensive catalogs, and much longer production runs. Nowadays there are more companies, making short run sheets for only a handful of subjects types that each company tends to specialize in. Once that sheet is sold out, you're on your own.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Thursday, February 27, 2020 4:51 PM
You are certainly right, in the sense that to me 30 years ago, AM decals meant Microscale.
    May 2013
Posted by Greg on Thursday, February 27, 2020 5:59 PM
GMorrison
I agree, this almost certainly is the problem. Remove from water as soon as you can move them, but they don't stick.
    July 2014
Posted by Bakster on Thursday, February 27, 2020 7:29 PM
Greg
GMorrison
I third the motion.
    November 2015
Posted by E. Halibut on Thursday, February 27, 2020 7:43 PM
That's what I do. In fact, I only soak them for about five seconds or so before I put them on damp paper towel.
I don't use aftermarket decals, and the decals I've had the most trouble with are in Revell AG, Dragon and Italeri 1/72 armour kits. Cartograf?
I can't remember where I read it, but in one article I saw recently the author talked about soaking decals briefly in a water/white glue mix. I've never tried that, and I can see downsides, but that kind of tapped into the frustration I've felt.
    August 2005
Posted by Phil_H on Thursday, February 27, 2020 11:03 PM
This stuff is your friend.
http://www.mr-hobby.com/en/itemDetail.php?iId=215
Unlike every other decal setter/solvent that I've come across, Mr Mark Setter has an adhesive component and will actively stick the decal down on the surface. It's pretty tenacious and sometimes you will need to dilute with water (using a wet paint brush) if you need to reposition a decal after applying to the surface.
Posted by Don Stauffer on Friday, February 28, 2020 4:21 PM
I have noticed this recently.  I think there are a lot more mfgs of decals now.  Bigger differance between brands, thickness of decal, release time, affected differently by setting solutions and solvents, differences in ability to bend sharply.
