Looking for a new glue brand. Any suggestions?
    March 2011
Posted by modeler#1 on Tuesday, February 18, 2014 4:34 PM
My LHS recently stopped stocking my current glue of choice and I need to find a new supply.
What kinds of glue do you guys use and would recommend?
thanks for the replies!
On the Bench: Nothing atm
    February 2015
Posted by Bick on Tuesday, February 18, 2014 4:38 PM
I like Tamiya Extra thin - or if I can't find that I use MEK (methyl ethyl ketone but it's becoming hard to find as well). I also use white glue, epoxy, CA, TiteBond and watch crystal cement depending on the job.
    April 2013
Posted by SchattenSpartan on Tuesday, February 18, 2014 4:45 PM
I second the Tamiya Extra Thin Cement. I use it for everything involving plastic. If you can't get it, Gunze's Mr.Cement Deluxe is similar, but it smells a lot more.
    December 2011
Posted by Chrisk-k on Tuesday, February 18, 2014 5:49 PM
I have Tamiya, Testors & Gunze cements.  I like Tamiya Regular and Extra Thin the best.  Gunze's Mr. Cement has a really terrible toxic smell, much worse than lacquer thinner.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Tojo72 on Tuesday, February 18, 2014 7:09 PM
Tamiya Extra Thin for sure
    December 2013
Posted by jetmaker on Tuesday, February 18, 2014 7:18 PM
I have to add myself to the fan base of Tamiya Extra Thin. It's excellent, both the cement and the bottle/applicator. I also like Testors Liquid Cement in the odd-shaped black container with the metal applicator tube
    March 2011
Posted by modeler#1 on Tuesday, February 18, 2014 8:55 PM
Great, I'll see if my LHS has Tamiya extra thin cement.
Posted by Don Stauffer on Wednesday, February 19, 2014 8:54 AM
When you say "types" rather than "brands", do you mean like solvent cement vs CA vs epoxy, etc.?
    April 2013
Posted by minimagneto on Wednesday, February 19, 2014 10:23 AM
If you are talking brands of cements, I have been very happy with Humbrol Liquid Poly for plastic welding.  Seems to grab better than my Plastruct or Testors did.
Posted by Texgunner on Wednesday, February 19, 2014 12:01 PM
I bought a can of MEK at the hardware store and it seems to weld plastic ricky-tick.   Cheaper in bulk than Ambroid from Hobby Lobby too.
Gary
"All you mugs need to get busy building, and post pics!"
    March 2011
Posted by modeler#1 on Wednesday, February 19, 2014 5:35 PM
Im talking about different brands of glue, sorry for the mix up.
    April 2008
Posted by zapme on Friday, February 21, 2014 7:48 PM
Tamiya extra thin, revell liquid glue ( with needle) and CA
My Blog - leoslatestbuilds.blogspot.com
On the workbench: 1/72 Airfix De Havilland DH88 Comet , 1/35 Trumpeter M1A1, 1/35 Tamiya Tyrannosaurus Rex, 1/8 (?) vinyl C3PO brand unknown
    December 2013
Posted by jetmaker on Friday, February 21, 2014 9:25 PM
Tex, that's interesting. I use MEK at work to clean sheet metal for sealing. That stuff is seriously toxic. I bet it welds plastic with ease. I never thought of using it for that. I bet it works very good. Probably have to be careful with it though. I certainly wouldn't breathe much of it, and be careful getting it on your skin. It attacks the nervous system
    November 2008
Posted by plasticjunkie on Sunday, February 23, 2014 5:51 PM
I use about 90% of the time Plast-I-Weld plastic welder with the Touch-N-Flow applicator. Ever since I have mastered using the applicator, this is my system of choice. It melts the plastic, welding both pieces making a solid join. This some times reduces the use of fillers since the plastic melts and fills the voids,
I also use Aleens tacky glue on certain pe or plastic applications. it's extremely strong and flexible. For clear parts I use Testors clear parts cement. Also thick CA for some pe applications.
 GIFMaker.org_jy_Ayj_O
    February 2011
Posted by Reasoned on Monday, March 3, 2014 9:00 PM
plasticjunkie
Glad you figured that TNF out, never could get it to work for me.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    March 2013
Posted by patrick206 on Monday, March 10, 2014 7:59 PM
Fellow modelers.
A caution to all regarding the liquid cements listed here, I believe most, if not all, use MEK as an ingredient. The Material Safety Data Sheet, (MSDS,) for MEK identifies it as highly carcinogenic, or cancer causing. The smell of liquid cements is horrible, these cements should be used only in areas with positive ventilation, (as in you should not detect it when in use.)
A Medical Doctor friend tells me it is considered "accumalative," meaning the stuff leaves your body so slowly you'll never get rid of all of it. I'm not a world famous expert on this, but I assure one and all that it places a real risk to your lives and health, if not used with respect and caution.
Even Tenax, which I think has the least obnoxious odor, has MEK listed on the ingredients label. Please use care, I want all of you to avoid health issues because of inhaling toxic fumes. The skin is just another body organ and highly absorptive, these agents are easily taken in through your skin. Proper gloves are called for as well.
Be careful and be well.
Patrick
    February 2015
Posted by Bick on Thursday, March 13, 2014 7:32 AM
patrick206
Fellow modelers.
Patrick
Are you sure of this. I've looked at the MSDS for MEK and don't find such information. What I find is information like:
"CANCER, REPRODUCTIVE & OTHER CHRONIC HAZARDS:
This product has no carcinogens listed by IARC, NTP, NIOSH, OSHA or ACGIH, as of this date, greater or equal to 0.1%."
Which is quoted from this https://www.tapplastics.com/uploads/pdf/MSDS_MEKS.pdf; link.
mgh
    May 2011
Posted by mgh on Thursday, March 13, 2014 11:24 AM
If you have lacquer thinner around, try that.  I have been using it for some time now, and it works great.
    September 2012
Posted by Tankster on Wednesday, April 2, 2014 9:45 AM
Tamiya Extra Thin is what I use.  Gunze Mr. Cement is good and pretty much the same as far as odor and bonding strength but the bad part is that it has a broad applicator brush and not the fine point brush Tamiya Extra Thin cement has.
Another good brand is Proweld it a thin liquid like Tamiya but it dries really fast but  the bond is really strong.  The only bad part about that is that the bottle is really tall & skinny and easy to tip over, it doesn't have a fine tip brush applicator and you have to make sure you leave the cap on or else it'll evaporate really quickly.
On The Bench: Dragon  1/35 Jagdtiger Henschel
On Deck: Dragon 1/35 Ferdinand
    September 2006
Posted by the Baron on Wednesday, April 2, 2014 11:34 AM
For styrene, I use Testor's tube glue (I can hear the collective gasp throughout cyberspace as I write this) and Plastruct's Bondene/Weldene liquid glues.  For CA glue, I use HobbyTown's store brand, extra-thin.  I also use their store brand of 2-part epoxy.  For white glue, it's Elmer's.
mgh
    May 2011
Posted by mgh on Sunday, April 13, 2014 11:20 AM
Well! Apparently not all lacquer thinners are equal.
After 2 1/2 years I needed to get another can of lacquer thinner to use for liquid cement.  Last can was Klean Strip, and the new can I bought was the same brand, but the new can is not the same stuff.  New can is not melting the plastic like the old one did.  Not sure exactly what is going on, but it might be drying faster, so fast that I cannot get the pieces together quickly enough, and it does not melt the plastic before evaporating.  So I may have to withdraw my earlier suggestion.
Posted by Don Stauffer on Sunday, April 13, 2014 12:30 PM
Indeed lacquer thinner is not a specific chemical, it is merely a product used to thin lacquer paints.  Some of the chemicals used as lacquer thinners include MEK, toluene, and acetone.
mgh
    May 2011
Posted by mgh on Sunday, April 13, 2014 6:42 PM
Don Stauffer
Thanks for that information.
Are the other 3 you list specific chemicals?  MEK is always the same stuff, acetone always the same?
I was at Home Depot today, and they did not have MEK, just something called an MEK substitute.  They did have a can marked as acetone.
Posted by Don Stauffer on Monday, April 14, 2014 8:50 AM
MEK substitutes are not MEK.  They are replacing MEK as it is supposed to be a carcinogen.  I do not know what chemicals these substitutes contain.  Yes, acetone is a specific substance.  So is toluene.  Some hardware and paint stores have these later two, some don't. I think acetone is generally a bit easier to find than toluene.
    March 2014
Posted by Tarasdad on Wednesday, April 16, 2014 8:13 PM
I've been using Testor's liquid cements for as long as I can remember. One type comes in a plastic bottle with a long, thin hypodermic-like tube and is fairly thick, the other in a glass bottle with a brush applicator and is water thin. I love both. You can also check out Micromark Same Stuff.
Tarasdad
On the Bench:
  • Revell 1/48 F-15 Strike Eagle
  • Revell 1/48 A-10 Warthog
  • Revell 1/426 USS Arizona
mgh
    May 2011
Posted by mgh on Thursday, April 17, 2014 12:14 PM
My apologies to Modeler#1 for high-jacking this thread.
For anyone that is interested, I have ended up with MEK for liquid cement now.  The lacquer thinner and acetone evaporate too quickly.  The MEK is slow enough to melt the plastic to make a good bond.  It smells awful, which will certainly remind me to be careful with it and work with ventilation!  I don't know that it is any more harmful than some of the other chemicals we use in modeling, but the smell makes me think of being careful around it.
I would also like to try the Weld-on 3, but have not found any locally yet.  The Micromark product is, unfortunately, unavailable from the retailer I usually order from.
    January 2013
Posted by jibber on Thursday, April 17, 2014 9:07 PM
Theres a lot of threads on this but if I had to pick just one for plastic kits it would be Tamiya Extra Thin. It does almost everything I need it for, but I have to admit my bench is full of different types of glues and cements.
    February 2015
Posted by Bick on Friday, April 18, 2014 4:49 PM
Don Stauffer
Hi Don,
Do you have a reference for this? I've looked at the toxicology studies, various government reports and the MSDS sheets from many manufacturers of MEK and have not found this. MEK is being banned in some states but I believe it's because it's a VOC and pollution is a concern; it is also regulated because of it high flammability. It has been reported to be neurotoxic (central nervous system) after prolonged inhalation. I'm not aware of any reports that classify MEK as a carcinogen or a suspected carcinogen. There are reports that there isn't enough data to 'classify it' one way or the other.  Indeed, several ounces of MEK have been ingested by an individual and, with proper treatment, full recovery with no apparent long term effects. There is, to my knowledge, no data to show that "substitute MEK" is less harmful whatever it contains. Don't mean to belabor this point but, if I missed something I'd like to know about it. IMHO, our use of MEK in modeling poses very, very minimal risk. Just don't bathe in it or drink very much of it and don't smoke while using it.
    June 2013
Posted by Reaper420 on Thursday, May 29, 2014 1:43 AM
I either use BSI Insta-Cure + (labeled as Hobbytown USA house brand but made by BSI) or Extreme Power from Hobby Lobby. Both are CA and cost $5 for 1/2 oz for BSI and 1 oz for Extreme Power. Both work great and fill gaps and seams nicely.
Kick the tires and light the fires!
    May 2009
Posted by Pawel on Thursday, May 29, 2014 2:23 AM
Hello!
I'm a big fan of using lacquer thinner for glueing together styrene parts. It gives a very strong bond, that doesn't deteriorate with time and the excess glue doesn't need cleanup if handled right - it just evaporates. It's also great for preparing surfaces to be glued with CA, makes the bond stronger and it also causes CA to dry faster. Like Don said, lacquer thinner doesn't have a specific composition - they vary from bottle to bottle, so it's worth to check a specific product if it works as glue - but if you buy a good bottle of it, it might last you for ten years or so. The checkI use looks like follows: I take a piece of sprue, put a large drop of the lacquer thinner on an even surface of the sprue and wait a few seconds. Then I touch that surface with my finger and take the finger away. If you can see fibres of molten plastic raising between the finger and the sprue, the composition will make a good glue.
As for the toxicity - I looked up the most popular components on wikipedia:
en.wikipedia.org/.../Methyl_ethyl_ketone
en.wikipedia.org/.../Acetone
en.wikipedia.org/.../Toluene
en.wikipedia.org/.../Xylene
Those pages above say many things - like you can make drugs from one of those substances (that's why they are substituting it), explosives from the other, they are all highly flammable, and good for sniffing if you really don't like your contact with the reality, but they don't cause cancer any more than alcohol and tobacco do. Sure those are dangerous chemicals - but your primary concerns are: 1.Fire 2:Passing out and hurting yourself 3:Throwing up. So let's stay safe without building a paranoia here. I believe using lacquer thinner from small containers, like nail lacquer bottles (makes a great applicator), to reduce the spill risk, and reasonable ventilation of the work area, plus common sense in handling heat and electricity should keep us all relatively safe.
Good luck with your glueing and thanks for reading, have a nice day
Paweł
www.vietnam.net.pl
