Wire Bending Tool
    December 2011
Wire Bending Tool
Posted by Chrisk-k on Wednesday, June 10, 2015 2:16 PM
I need to consistently bend a copper wire like "ᴨ" to make multiple grab handles.  I know some folks use the bending comb section of the Brass-Assist to do that kind of job, but it's way too expensive ($70).  Is there a cheap alternative?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    March 2010
Posted by Nathan T on Wednesday, June 10, 2015 4:01 PM
bend around a small needle nose or duckbill pliers. Or a piece of rectangular evergreen strip.
    July 2004
Posted by stikpusher on Wednesday, June 10, 2015 7:00 PM
I second the needle nose pliers suggestion. The little gripping ridges in the mouth of the jaws are perfect for grasping the wire in a consistent spot for bending the same lengths.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Thursday, June 11, 2015 9:20 AM
Drive small brads into a piece of particle board to make wire bending jigs.  If you will make several parts from any one jig, save it.  For one-offs, jigs are cheap enough to pitch afterwards.
    August 2008
Posted by tankerbuilder on Friday, June 12, 2015 11:36 AM
Hi;
   I use standard pliers or flat nose pliers .The teeth hold the wire and then if it is so , the pliers body width gives me the length . So , perfect hand grabs etc.  You can use ANY size pliers for this depending on the size you need .
    December 2011
Posted by Chrisk-k on Friday, June 12, 2015 1:37 PM
I just tried the plier method. It worked like a charm.
    July 2004
Posted by stikpusher on Friday, June 12, 2015 2:02 PM
Chrisk-k
Keep It Simple StupidDunce
Murphy's Laws of Combat- If it's stupid and it works, it ain't stupidWink
       - Plankton
LSM
    August 2013
Posted by Jay Jay on Friday, June 12, 2015 4:50 PM
ChrisK
m doing the same thing on a 1/350 scale ship for " permanent ladder steps" that are welded to the structures.  ( There's a bunch of em )  I found a small square jawed pair of pliers in the jewlery section at Michales craft store that has 3 different square graduations .  I  just hold the wire in the appropriate section . bend ,bend, and snip.
quick, easy and cheap with the 40 % off coupon.
Posted by Don Stauffer on Saturday, June 13, 2015 9:29 AM
The advantage of a jig is that it helps keep parts in one plane.  Ones made with several bends with pliers can end up looking like an Escher print.
    March 2008
Posted by WigWag Workshop on Saturday, July 18, 2015 1:50 PM
I purchased a Resistor Lead Forming Tool to make my grab handles, they can he had for about $5.  Search for "Resistor Lead Forming Tool" with your favorite search engine, or look on that auction site.
    January 2014
Posted by gobobbie on Saturday, July 18, 2015 4:30 PM
Please excuse me as I am on the road and have no access to reference library. I cannot recall what page it is on but in Shepard Paine's armor book is a diagram showing how to make your own wire bending tools for things like grab rails.
Bob Gregory
Ruining one kit at a time.
Posted by Don Stauffer on Monday, July 20, 2015 8:33 AM
Another method I have used specifically for grab irons is to use a strip of basswood of the proper width and thickness. I use soft wire and wrap it around three sides (one wide side and the two short sides).  This makes sort of a wide U shape. I then cut with diagonal cutters held against the rear, the side with no wire wrapped around.  This method makes quite a few irons pretty quickly but only one size, not very versatile.
    October 2015
Posted by Comanche pilot on Thursday, November 12, 2015 10:03 AM
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=Z+bender
A whole range of price and feature wire benders.
