Holding small parts for airbrushing
    June 2015
Posted by chatles on Sunday, June 21, 2015 1:17 PM
I frequently see YouTube videos showing modellers holding small parts on the end of toothpicks or small sticks with what appears to be putty on the end.  Are the putty sticks something available to buy and if not, what are they best made from?  When using toothpicks is it necessary to drill holes in the part to attatch the toothpick or is it glued to the part?
Thanks
Craig
    January 2013
Posted by BlackSheepTwoOneFour on Monday, June 22, 2015 8:06 AM
Silly putty or poster tack
Posted by Don Stauffer on Monday, June 22, 2015 8:49 AM
I use poster tack also.  But I also frequently drill a small ( 0.020) hole in the part and jam in a pin or small wire.  I also sometimes tack small parts down to a piece of scrap particle board with double-sided tape.
I also paint many parts while they are still on sprue, then touch up the spot where they are attached to sprue after painting and removing.
    September 2006
Posted by the Baron on Monday, June 22, 2015 11:38 AM
As with so many other things, I've used each of the methods that the others have mentioned, and still do, depending on the situation.
  • I'll use poster tack to stick something on a toothpick, and then plant the toothpick in a block of styrofoam.
  • I'll use masking tape (3M's household tape, which I no longer use for masking), doubled back on itself, to tape items to pieces of cardboard.
  • I'll drill holes in pieces, especially figures, and then tack them with white glue to a toothpick or a straight pin.
  • I also use clothespins or those plastic clamps from Harbor Freight, as temporary holders, or to allow a piece to sit or stand without falling over, when airbrushing.
Upshot, is, there are many techniques, and you might wind up using more than one, or even all of them, depending on your own results.
    May 2013
Posted by Greg on Monday, June 22, 2015 12:57 PM
All of the above.
And one more I use a lot....
A small piece of double-sided mounting tape on the end of a Popsicle stick. Holds a variety of things.
    January 2014
Posted by jelliott523 on Monday, June 22, 2015 3:26 PM
I use the above mentioned methods as well.  As for the sticks that I use, I went to my local Walmart and found a bag of craft sticks in their arts and crafts section.  The bag has roughly 150 wooden sticks that are about 41/2 inches long and are about 3/16 in wide.  These are thin enough that they can be carved with a hobby knife to fit smaller areas if needed.  Yet, they are sturdy enough that I have glued sandpaper strips to them and used them as sanding sticks for tight spaces.
    December 2011
Posted by Chrisk-k on Monday, June 22, 2015 10:03 PM
Alligator clips attached to skewers hold parts for me.  Works 100% all the time.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    February 2007
Posted by mitsdude on Tuesday, June 23, 2015 1:22 AM
Nothing to add!
You guys took em all!
    August 2008
Posted by tankerbuilder on Tuesday, June 23, 2015 9:45 AM
I use those little plastic sticks with the clear sticky bulb on one end .I get them at my LHS . They are good for hundreds of uses .
    June 2015
Posted by chatles on Tuesday, June 23, 2015 11:57 AM
Thanks so much for all the advice! it's greatly appreciated  The last time i did any modeling was in 1960.  I held parts with my fingers and painted them with a brush.  My how things have changed.
Craig
    December 2011
Posted by Chrisk-k on Thursday, June 25, 2015 12:56 AM
tankerbuilder
I've bought them from Hobby Lobby with a 40% off coupon.  I use them for gluing tiny parts.
    February 2014
Posted by CN Spots on Thursday, June 25, 2015 10:05 AM
Ditto on the toothpicks and blue-tac.  I'll use old pieces of sprue too.
    January 2011
Posted by TigerEP1 on Thursday, August 6, 2015 3:42 AM
I use the Stix brand holders (green smart hold and blue strong hold) they work great.
On the bench:
1/35th Tamiya Willi's MB
