Clear Acrylic
    January 2015
Clear Acrylic
Posted by Moff on Friday, February 5, 2016 8:18 AM
I saw a build in a recent edition of FSM of a U-Boat submerged completely in a block of water-tinted acrylic. For the life of me I can't find the photo, but it caught my eye. What type of acrylic do you think the builder used for the large amount of water he was simulating? I have both Vallejo Still Water and AMMO Wet Effects, but from my research, they are generally used for surface moisture and puddles - nothing as extreme as a whole cube/prism of scale water. Do you guys have any idea what the modeler may have used?
"Gaiety is the most outstanding feature of the Soviet Union." - Josef Stalin
    January 2013
Posted by BlackSheepTwoOneFour on Friday, February 5, 2016 8:31 AM
Clear cube box? LOL! I know what you're talking about but I haven't a clue.
I've seen sunken tanks in water like that as well. I can't remember where I saw it though.
    August 2005
Posted by EdGrune on Friday, February 5, 2016 11:59 AM
Moff
Your may be thinking of an entry from the 2015 IPMS National convention.    There was a small scale U-boat imbedded in some green-tinted clear cast resin.   It drew a lot of comments.
You may want to look at a product similar to these imbedding resins from Smooth-On
http://www.smooth-on.com/Encapsulation-and-/c1277/index.html
Note of caution.  Most casting resins are exothermic (means they generate heat) as they set.   A large volume of resin can generate enough heat to warp plastic (ask me how I know).    Work slowly in numerous thin lifts or pours.  Some resins also shrink as they set.  This appears like water surfaces uncharacteristically climbing the ships, pilings, or float-plane floats (ask me how I know).
    February 2011
Posted by Hokey on Friday, February 5, 2016 1:39 PM
You are correct. It was 3-4 months ago. I have it here somewhere. According to the article Marc Millis built it and that he layered clear resin tinted blue.
Also a similar thread is here.
    January 2015
Posted by Moff on Saturday, February 6, 2016 7:47 PM
Ok, thanks for the info! Special thanks to EdGrune for the product link.
Do you think I could mix Vallejo paint into the resin, even though it heats?
    August 2005
Posted by EdGrune on Saturday, February 6, 2016 8:19 PM
Moff
no
they sell tinting agents for resins
perhaps tamiya's clear green or blue may work
    January 2015
Posted by Moff on Sunday, February 7, 2016 9:38 AM
EdGrune
Any particular brands you can think of?
Posted by Don Stauffer on Sunday, February 7, 2016 11:22 AM
Making colored polyester resin castings is still a reasonably popular hobby.  I know I have seen resins and colors and molds at Michaels, and I assume Hobby Lobby carries that stuff too.  What resin are you intending to use? If polyester, you would know the colors would work fine. They may work with epoxy, but no guarantee.
    August 2005
Posted by EdGrune on Sunday, February 7, 2016 3:33 PM
Moff
Using the link to the Smooth-On site which I posted,  go to their FAQ page and enter TINT into the search function.
Wait,  I'll do it for you ...
http://www.smooth-on.com/faq_display.php?faq_id=1
    January 2015
Posted by Moff on Sunday, February 7, 2016 9:21 PM
EdGrune
Moff
Thank you! Sorry for being a pain in the gluteus maximus...I should have looked more closely, but I was on mobile at the time.
    September 2009
Posted by Cobra 427 on Monday, February 8, 2016 7:33 AM
Listen to our friend from Texas - he's right! DON'T just use any old thing, use the right product designed for it! www.specialtyresin.com  www.uscomposites.com  are two sites that I go to get very specific casting resins from. Smooth-on just sells the stuff they make, and it shrinks. The specialty resin doesn't just sell their stuff, they also make it!  And it doesn't shrink. You can get tints for projects that is DESIGNED for the resin itself, and won't cause problems when trying to mix with resin, and it's components. The problem is that there is an incompatablity factor involved when using two dissimilar products/chemical compositions. US composites sell many different types of resins, and compounds for industrial applications that can make your life much easier. It also has obscure things like polyester resins, and the matting for making your own fiberglass parts. Check both of them out - you'll be amazed at what you'll find!
~ Cobra Chris
Maybe a picture of a squirrel playing a harmonica will make you feel better?
Posted by Don Stauffer on Monday, February 8, 2016 9:00 AM
Again, a warning that almost all catalyzed resins generate considerable heat when curing.  Keep layers thin, too thick a layer will soften and distort any styrene you are embedding.
    January 2015
Posted by Moff on Monday, February 8, 2016 11:07 AM
Just to clarify, my hypothetical project would probably involve submerging a resin kit, if that makes a difference.
    September 2009
Posted by Cobra 427 on Monday, February 8, 2016 11:50 AM
www.specialtyresin.com  is the one that I use to get my silicone rubber mould making kits, and resin from. This is polyurethane resin, and it's pretty durable, and strong. It paints, sands, and glues easily. Only use resin with resin, and not polystyrene with it. It does create some heat, but not that hot. This won't distort the model, but it can create enough heat that it can make it hot enough that you can't touch it with your hand until it cures completely. It depends on how much resin you're planning to use! Just do it in thin layers, but be careful to measure perfectly so that as you do this you don't get soft spots, or discolouration from having too much hardener in the mix!
~ Cobra Chris
    January 2015
Posted by Moff on Monday, February 8, 2016 2:47 PM
Cobra 427
~ Cobra Chris
I checked out Specialty Resin, and it doesn't look as though they have a transparent polyurethane resin available. The most transparent polyurethane resin available from Specialty Resin is the Color-Pro resin, and that dries to a rather foggy whitish color (undyed of course). Color-Pro seems to be more opaque than transparent really.
As for US Composites, it looks as though there are two different polyester resins available that would fit my needs: Silmar 41 and Silmar 249. However, polyester resin's fumes are considered carcinogenic, and it is finicky when it comes to curing.
    August 2014
Posted by goldhammer on Tuesday, February 9, 2016 2:48 PM
I got a box of Easy Cast, which says clear epoxy casting resin.  Made by Environmental technology Inc.----www.eti-usa.com
They do make some tints for it, but have not played with it yet.  Got it at Hobby Lobby, was $26 for 16 oz, says ideal for small casts 6 oz or less.  Tint was $8 for 1 oz concentrate bottle.  HL didn't stock much in tints, so don't know what is actually available.
Might look them over.
    January 2015
Posted by Moff on Friday, February 12, 2016 9:56 AM
goldhammer
Problem is, I've heard that epoxy yellows over time. Has anyone else heard similar?
    September 2009
Posted by Cobra 427 on Saturday, March 19, 2016 5:35 PM
OK. I forgot that this wasn't good for encapsulation. Try www.smooth-on.com This site DOES offer a resin made specifically for this. I just forgot about it. I hope that this will be the answer to your prayers.
~ Cobra Chris
    November 2008
Posted by plasticjunkie on Thursday, March 24, 2016 6:40 AM
I recall reading an article about a submerged Sherman with some kids swimming aroud it. I think it was set somewhere in the South Pacific. I believe the builder used a clear plexi box, and the turret stuck out thru a hole on the top. Then he used some type of water effect product for the surface water. It looked fantastic but I can't remember where I saw the article at.Confused
 GIFMaker.org_jy_Ayj_O
    January 2015
Posted by Moff on Thursday, March 24, 2016 2:39 PM
Cobra 427
~ Cobra Chris
Ok, thanks!
    January 2015
Posted by Moff on Thursday, March 24, 2016 2:40 PM
plasticjunkie
I saw that too, and I also have no idea of the source Smile
    August 2014
Posted by goldhammer on Friday, March 25, 2016 5:04 PM
Wasn't that in one of the Readers Gallery in FSM sometime in the last year and a half or so?  I remember a half sunk Sherman as well........
Posted by Tojo72 on Saturday, March 26, 2016 7:50 AM
goldhammer
Here is an article about the diorama
http://www.helmo.gr/index.php?option=com_deeppockets&task=catContShow&cat=14&id=1559&Itemid=35
    November 2008
Posted by plasticjunkie on Saturday, March 26, 2016 12:39 PM
Thanks Tojo. That's the one!
    January 2015
Posted by Moff on Monday, April 11, 2016 9:03 AM
It's just breathtaking, the skill involved in that build... Indifferent
