model glue
    June 2018
model glue
Posted by model lover on Saturday, September 21, 2019 10:25 AM
How long does model glue last before it gets old? How many years does it last?
Posted by Tojo72 on Saturday, September 21, 2019 2:58 PM
What kind of glue ? I find the ca or super glue can turn pretty quickly,the liquid stuff evaporates over time
    June 2018
Posted by model lover on Sunday, September 22, 2019 7:49 AM
I'm using tamiyas glue. the regular and extra thin cement.
    August 2013
Posted by Jay Jay on Sunday, September 22, 2019 8:09 AM
Does 5 min. Epoxy have a shelf life ? mine doesn't seem to be adhering as well as it used to.
    June 2014
Posted by Tanker - Builder on Sunday, September 22, 2019 8:28 AM
Hi;
     Well, the question is this. How fast do you use up a bottle? I usually have about a fine sludge in the bottom in about a year. The comment about super glues is correct. I use it a lot and I've noticed when I open the refill bottles( Very Large) I have about six months to a year of shelf life.  T.B.
    May 2013
Posted by Greg on Sunday, September 22, 2019 9:46 AM
model lover
I find the Tamiya bottled cement to last several years. I've yet to had one go bad. Hard to say exactly how many years though.
In my experience, when plastic glue goes bad, you'll know it. It will simply fail to hold parts together.
-Greg
Posted by Don Stauffer on Sunday, September 22, 2019 10:59 AM
Jay Jay
I have had problems with epoxy in recent years even when it was not old, as far as sticking to styrene.  Someone said on this forum awhile back that the kit makers may be using different styrene than in the past.  Don't know about epoxy chemistry, but it does seem that way.  When I first had problems I blamed release agents, but I washed and cleaned kits thoroughly and it didn't make a difference.
    July 2013
Posted by modelmaker66 on Saturday, March 14, 2020 2:05 AM
model lover
Other than tube glue, I can't recall it ever going bad.
    August 2005
Posted by Phil_H on Saturday, March 14, 2020 5:52 AM
modelmaker66
I have a tube of Pactra non-toxic glue from about 1979/80 which is still quite liquid and most likely usable (as much as the early citrus-based non-toxic glue is considered usable).
    August 2005
Posted by EdGrune on Saturday, March 14, 2020 6:28 AM
I have found that with Tamiya liquid glues that if you do not screw The top tightly, during the warmer summer months some of the volitile components will evaporate.   This leaves the less volitile components.  These less volitile materials are not as efficient in melting plastic
yes, Tamiya liquid glue can go bad over time if not kept tightly capped
Posted by Tojo72 on Saturday, March 14, 2020 8:07 AM
Opened CA glue will definitely go bad.
    January 2010
Posted by rob44 on Saturday, March 14, 2020 9:03 AM
I store my unopened CA glues in the refrig if I do not need them.
Rob
