Clamp Suggestions
    July 2020
Clamp Suggestions
Posted by Lone Traveler on Sunday, July 12, 2020 7:35 AM
I just got some plastic clamps. They do not have any padding on the jaws And tend to slip off some of the non-flat model parts.  I tried some plastic packing foam but it just tore off above the glue layer. I'm looking for a DIY solution that is not too thick. Maybe about a 1/16th (1.5mm). A thin version of what is on my ratchet clamps would be great.
  " alt="" /> " target="">
Thanks
Lonnie
Posted by Don Stauffer on Sunday, July 12, 2020 8:37 AM
You can get sheets of felt covered paper with adhesive backing at Michaels and some other craft stores.  Cut strips to right size and stick them on.
    October 2019
Posted by Tanker-Builder on Monday, July 13, 2020 7:17 AM
Hi Lonnie!
 What I did with mine is similar. Only I got some ribbed thin Rubber sheet and cut it to fit with the ribs located sideways( For Grip) and then Contact cemented them in place . I have literally had to go buy new clamps.The originals wore out!
    July 2020
Posted by Lone Traveler on Monday, July 13, 2020 8:38 AM
Tanker
Thought of that but couldn’t think of where to get the thin rubber sheeting. Any suggestions?
Thanks
Lonnie
    July 2020
Posted by Lone Traveler on Monday, July 13, 2020 8:39 AM
Dan
Good idea. Didn’t think of felt.
Thanks
Lonnie
    November 2014
Posted by Nuckss on Monday, July 13, 2020 10:59 AM
You should be able to find stick on grips soles for shoes that would provide enough for many clamps
    November 2008
Posted by plasticjunkie on Wednesday, July 15, 2020 4:33 PM
I have a multitude of clamps for different applications. Harbor Freight has some plastic ones that I use as lot along with wooden clothing laundr pins. I also have 6 DeWalt mini grip clamps that are fantastic.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Thursday, July 16, 2020 8:46 AM
I find these micro-adjustable bar clamps to be super!  I have four inch Irwin ones- they are expensive but my local Menards had them on sale and I bought four.  Harbor Freight has theirs on sale frequently for a buck.  Not quite as good as the Irwin ones, but I bought two.  These bar clams are my goto now.  I can't believe how super adjustable they are if you use a light touch on the adjustment trigger.
    November 2008
Posted by plasticjunkie on Thursday, July 16, 2020 10:06 AM
Don, The Harbor Freight small bar clamps are garbage. The eventually begin to slip and will not hold a solid grip. The Irwin ones are just like the DeWalts and are fantastic and well worth the higher price. Harbor Freight has some plastic clip type ones that are good and come in several sizes.
    August 2004
Posted by cwalker3 on Friday, July 17, 2020 7:29 AM
Try auto parts stores for that ribbed rubber sheeting. They sell it for lining the drawers of tool boxes.
Cary
    November 2008
Posted by plasticjunkie on Friday, July 17, 2020 8:15 AM
Liquid electrical tape is a plastic coating that can be brushed on and is thin.
Posted by Don Stauffer on Friday, July 17, 2020 1:09 PM
plasticjunkie
I have not had the HF clamps slip yet.  The biggest problem with them that I have is the pads falling off-so common.  And yes, I have that big bag of their spring clips.  But, at a buck a piece I continue to pick one up each time they are on sale.  I use them for the less rigorous jobs, and do have more of the Irwin than the HB ones.  Just wish the Irwins would go on sale more often.
    July 2020
Posted by Lone Traveler on Friday, July 17, 2020 2:53 PM
PlasticJunkie. Wow. Never knew that existed.
Thanks
Lonnie
    June 2020
Posted by Markeno on Saturday, July 18, 2020 7:59 PM
I purchased my Liquid Electrical Tape at Harbor Freight actually.   Then awhile later I found that Walmart sold it for significantly less for the same bottle.  I picked it up for lighting and electronics for in models and projects.  It does grip well, I couldn't speak as to how well it will hold up long term as clamp grips, but it may.  It is great for insulating wiring, providing strain relief for wiring, and light blocking, it also has a pretty good grip for holding stuff.  Just have ventilation when using it.
    November 2008
Posted by plasticjunkie on Saturday, July 18, 2020 9:08 PM
You are welcome LT. looks like Markeno gave it a good review.
    July 2020
Posted by Lone Traveler on Saturday, August 1, 2020 9:08 AM
Got both the felt and the shoe rubber. Neither very expensive. I can say both work very well. The rubber is a little mo grippy. But the felt softer. Btw go in with a friend to get it I only needed about a 3" inch square to do 4 small and 4 larger clamps.
Thanks
Lonnie
Posted by Don Stauffer on Saturday, August 1, 2020 10:50 AM
I was in Hobby Lobby the other day.  They had the micro-adjustable bar clamps.  With their coupon the would be not too expensive- forget the price but not bad.
    March 2015
Posted by JohnnyK on Saturday, August 1, 2020 3:49 PM
Here is another use for a bar-clamp:
I have used this paint shaker for years and have never been hit on the head by a flying paint bottle yet.
    November 2008
Posted by Justinryan215 on Monday, August 3, 2020 12:17 PM
For thin parts, I have two sized of paper 'clips' (sping loaded alligator type clamps) that work wonders on wing halves and such.
Plasti-dip is another type of product similar to the liquid electrical tape, originally designed to dip tool handles to restore the rubber grips....
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
