Dremel collets and tiny drills
    January, 2017
Posted by clockdoctor on Friday, January 06, 2017 2:18 PM
I use a collet based watch makers lathe. Collet chucks will only accurately hold
drill sizes identical with the collet they are designed for, outside this size the jaws are
not concentric with the drill and the the drill will run out of true and will break.
Proops Bros in Leicestershire UK sell a range of microdrills with a 0.125 shaft that
can be relied upon to run true in a standard  Dremel collet.
Speed control on my lathe has been achieved by use of a standard high wattage
light dimmer switch in circuit with the (brush) motor.
I also have one built into a electrical twin socket plug box so the controller is one side
and the output socket is along side with the controller plugged into the supply with
a length of 13 amp cable and plug.
Another source of "stepped" drills is from Banggood who supply tungsten carbide
drills with 0.125 shafts for drilling printed circuit (fibre-glass) boards, very sharp
totally resistant to overheating and VERY brittle
Have (accurate) fun!
    August, 2013
Posted by Jay Jay on Wednesday, January 11, 2017 8:06 AM
Dremel makes a tiny 3 jaw chuck for their tools. I have had no problems gripping bits down to #79 with it. Maybe you can use one on your lathe . I hope this helps.
    November, 2009
Posted by Don Stauffer on Wednesday, January 11, 2017 9:27 AM
I have a modeler's lathe (Sherline).  I use one of those chucks with the eighth inch shaft frequently for the small drills and very small metal stock.
