Modifying Tools
    June 2014
Modifying Tools
Posted by Tanker - Builder on Saturday, January 26, 2019 5:07 PM
Here's one for you .
 How about this .You take an X-Acto knife handle that has the knurled butt end and soft-touch plastic handle and make it stiffer and better locking . How ? You replace theSoft-Touch handle with a Thick-walled Aluminum tubing piece and this does the job.
 Drill bits for Dressing molded holes or De-Burring Plastic or metal tubing . Set drill bit down butt end in a jar with a hole in the direct center of the lid . Now you prep the bit by filing flat spots in the sides . Pour Sprue -Glue in to a depth of the bottle where it starts to narrow . Drill holes around the lid so the product can gas out .
 When this  , done , yeah  , it takes a little time , Do this . Break the bottle releasing the part . Now , file the resulting cylinder to a rounded ball like profile with a flat spot on one side ( It won't roll of the table that way )
 There it is , a perfect to the hand ( much like the little drills made this way with wood balls . ) and sure better to control .You can do this to bits that won't fit a pin - vise but are ones you use a lot . Instead having to break out the power drill .
 Hammers . Want a hammer you can pound on plastic Gears and Wheels and you don't have a small wheel-gear press ? Coat the smallest hammer you have with the coating made for handles .
 Air Brushes . MMMMMM This is a hard onne .Is it ? Say you have an old one that you can't get new innards for ( Internal Mix style) Well don't throw it out . Use it to blow out a gentle stream of air to dust off those old models on the shelf .They will appreciate it and you won't pull out hair over broken masts or antennas .      Bye      T.B.
    August 2012
Posted by Rambo on Sunday, January 27, 2019 3:20 AM
I took a excell swivel blade handle and a heavy gauge sowing needle cut the eye in half then tig welded them together and now use it to apply small amounts of CA glue.
Clint
    July 2014
Posted by Bakster on Sunday, January 27, 2019 9:37 AM
Rambo
Clint, I did the same for the same purpose. In my case I didn't weld it. I still need the handle for drill bits and such.
    November 2008
Posted by mrmike on Sunday, January 27, 2019 12:47 PM
Some time back a contributor named Chuck W. posted this tip, and it's worth a repeat. Those of us who use the razor saws by UMM and others will have blades break. Instead of throwing these away, use them as mini-saws. I do woodworking, so my handles of choice are wooden dowel pins, about 2" long and 1/4" in diameter. I saw a slot in one end and superglue in the broken blade...viola, a small saw that gets into little places the big blades won't reach.
With a little practice (wearing safety glasses, of course) you can snap the broken blades with pliers to make handy shapes. These little saws have become my go-to for removing delicate parts from sprue and working in tight areas with lots more control than a #11 blade.
