PMM736,
The set from Micro mark is a Basic Acetylene Torch tip cleaner. If you have a welding shop around (Any place that sells gases, rod, etc) they should have the exact same set up for $8 or so.
I have several of these and also a couple from the hobby store and a couple with wooden handles. I find that the best ones have a swivel on the head that allows you to place pressure on the drill with you index finger and turn the drill with the thumb and middle finger. Also, look at the collet and the chuck before you buy. For the drill bit sizes we use in this hobby, try to find a collet that when closed all the way will leave little or no gap (a zero clearance chuck, if you will allow).
I tried to be thorough in my explanation and refer to what I have tried and haven't, If this has upset anyone, please let me know and I will do better next time
HTH,
Ted
