pe tool
    August 2004
pe tool
Posted by Daytripper on Saturday, January 6, 2007 6:44 AM
Hi,
I have started to use photo etch parts when modelling 1/48 scale a/c but i am finding it  very frustrating when it comes to cockpit detail, i have a pair of long needle nosed tweezers to use with very small pe stuff but have found that these are not ideal for small cockpit detail, i was wondering what do you guys use to hold and fix small pe detail parts ( handles,levers et al) or any advice on what to use.
Thx DTSmile [:)]
    May 2003
Posted by qmiester on Saturday, January 6, 2007 7:49 AM
I've got a set of long, narrow, needle pointed tweezers that lock that do a good job for me.  Took some time to get used to using the lock feature, but the number of dropped items has declined significantly since I began using them.  I've had them long enough I don't remember where I got them, but I believe Micro-Mark carries them in their catalog.
Quincy
    June 2005
Posted by smokinguns3 on Saturday, January 6, 2007 9:16 PM
If youu can afford it pick up an ecth mate or if you can really afford it buy a frnder bender ive herd great things about both products but unfortunatly all i bought was a cheap plastic pe bender and regret it.
Rob I think i can I think i can
    August 2004
Posted by Daytripper on Sunday, January 7, 2007 6:58 AM
Hi sg3
I guess what i am after is an alternative for picking up ultra small pe items and fixing to other peices as the tweezers are a little awkward to use for this
regs DT
    April 2005
Posted by wing_nut on Monday, January 8, 2007 8:11 AM
Hey DT.... you reminded me of something I use all the time for tiny PE and plastic parts.  I added it to the tips sections on my site, about 1/4 down on the page.
 http://wingnutmodels.com/tools%20&%20tips.html
Marc
    March 2005
Posted by mfsob on Monday, January 8, 2007 12:32 PM
I would like to submit the following, bearing in mind that I use it on 1/700 ship models:
The lowly, wooden toothpick! With the tip cut off one end, and moistened with your tongue, it can be used to pick up, and place, small PE items. Just put a dot of CA or white glue where you want the item to go, wet the toothpick, pick up the PE, and place. What I like most about this is that the toothpick is small enough to get just about anywhere without knocking other parts off.
