How bad is putty really?
    November 2006
Posted by TheLastPriest on Saturday, January 5, 2008 3:55 PM
I finally got some decent putty, I had been using the tube of testors crappy stuff and just couldnt deal anymore. I got the squadron white and was very excited.....and then I read the warning label that takes up ohhh I dont know, The entire tube! I usually work in my recliner right next to an open front door and that vents everything(paint,thinner,testors putty etc) well enough but with the way the warning is on the squadron stuff it makes me feel like I should have a full resperator and hazmat suit working in a sealed room with an industrial ventallation system when working with this stuff. How bad is it really? I live in a one bedroom apartment with my wife and 3.5 month son, I cant take chances with stuff that is potentially deadly anymore.
It is only the intellect that keeps me sane; perhaps this makes me overvalue intellect against feeling
    January 2003
Posted by Triarius on Saturday, January 5, 2008 4:07 PM
See whether or not you can find the MSDS, that wil tell you.
As an alternative, why not try Aves Epoxy Sculpt? Or just learn to use CA for that. I almost never use putty anymore.
    November 2006
Posted by TheLastPriest on Saturday, January 5, 2008 4:16 PM
What may I ask is Aves Epoxy Sculpt, I really would be happy with any product that would out perfom testors putty and safe to use in my home. I use CA a lot for filling but sometimes I just feel I get better results with putty. Especially for shaping
    December 2007
Posted by JViguers on Saturday, January 5, 2008 4:31 PM
Try a tube of Elmers Carpenter's Wood Filler. It's as good as any putty IMO and it has no hazardous fumes. Just use the moist cloth to wipe off the excess and sand when it dries. Big Smile [:D]
I got that from ModelNerd. He has many good tips here.
On the workbench: Pegaso 90mm Templar Sergeant
    May 2005
Posted by Bgrigg on Saturday, January 5, 2008 6:29 PM
Most modeling putties such as Squadron White or Green (and others, I'm not picking on Squadron!) contains a witch’s brew of solvents that are know carcinogens or can cause brain cell injury. I would prompt you to NOT use them in such a small area with your child, as young children are even more susceptible to such things. I use the stuff, and am always careful not to breathe in the fumes, but I also have the luxury of a dedicated man cave, away from the rest of my family.
Sculpting putty, CA and wood filler would be much less hazardous, and I will be looking at these as alternatives when my supply of putty is exhausted.
So long folks!
    May 2006
Posted by waste gate on Saturday, January 5, 2008 7:57 PM
A little reason goes a long way in these matters.  Are you exposed to what ever is in the putty for long periods of time?  More than an hour at a sitting in an enclosed air tight chamber?  I wager not.  Driving your car is more hazardous than using any manufacturer's putty, and you wouldn't stop driving.
Enjoy the build and stop worrying about what could, possibly, under the most dire circumstances kill you.  Believe it or not your going to die eventually anyway!!!!
The sky isn't falling.
    November 2006
Posted by TheLastPriest on Saturday, January 5, 2008 8:14 PM
I do understand the irony in these matters, I have been known to when it is raining, smoke a cigarette while driving in my car with the windows up. If I were sitting by myself in the apartment I wouldnt ask, however with a small child all these questions now make themselves apparent. I do agree with you, we are all dying the only question is how fast. I would just like it to be slower with the most important thing in my life.
    March 2007
Posted by JMart on Saturday, January 5, 2008 9:06 PM
hey TLP - I sent you a box with some stuff (and even MORE putty ;) it included couple paper facemasks and gloves. The "bad" part of putty is when you cut it/smooth over using acetone-based nailpolish remover. The fumes given off are toxic. I mask my model (Swammys method), then go to my AB booth to apply the putty and smooth over with acetone-polish remover. Use it whenever you use your AB, outdoors and ventilated. Put your model in a large box to dry off, that way you can take it inside. Also dont forget the putty is also flammable, careful smoking around that ;)
cheers, jim
Posted by jhande on Saturday, January 5, 2008 9:23 PM
I would not get overly excited regarding the hazardous fumes from the putty. As an added precaution you can place a fan near you to blow or suck any modeling fumes out the open door. You are using such small quantities that there really isn't that much fumes to be concerned about, unless your baby is sitting in your lap, which I hope not.
I've worked in the automotive industry for many, many years as has many people. I have been in both a body shop and a garage longer than 8 hours a day working with putty, filler, sanding dust, paint fumes, exhaust fumes, asbestos brake dust, degreasers, you name it, I smelt it and wore it. All with no ill effects. So what I glow in the dark and don't have a clue who I am... just kidding. Propeller [8-]
Do a test if you want to make yourself feel a bit more comfortable. First can you smell anything from the putty? Set yourself up at your open door with the fan going. Dab some putty on something disposable. Have your significant other walk into the room and see if any oder is detected.
Or you can always work outside. Tongue [:P]
-- Jim --
"Put the pedal down & shake the ground!"
    November 2006
Posted by TheLastPriest on Saturday, January 5, 2008 9:54 PM
Ha, I dont know how much I can trust my significant others nose. The other night I tested my new putty on a couple of small sinkholes and she was across the room on the computer, we had both read the warning label. I filled the sinkholes, smoothed it out and then placed the piece in a tupperware container and put it away. Then sealed up the putty put it away. Bout ten minutes after I got a call from across the room "Honey I dont think you should use that anymore, im getting a headache". Hypochondriac much?
Jmart, I am pretty good about not smoking around kids and flammible things, allthough I was cleaning out my AB the other day shooting some thinner through and realized I had a lit cigarette  in my hand. Gonna blow myself up one day if im not carefull. I am looking forward to that box. It sounds all full of goodies I can use.
    May 2005
Posted by Bgrigg on Saturday, January 5, 2008 10:18 PM
No. She's not. It takes that long for the brain cells to be affected by the Toluene in the putty. This is not a case of being over protective. It's one thing to use it yourself, as I do, and expose yourself, or your wife. It's quite another to expose your baby, who can't tell you they are getting a headache. If it was just you and Pink, I would recommend good ventilation. Since you say you live in a small one bedroom apartment with an infant, I suggest putting the putty away until you can use it safely. There are less toxic methods. Please consider using them.
http://www.atsdr.cdc.gov/HEC/CSEM/toluene/physiologic_effects.html
http://www.inchem.org/documents/icsc/icsc/eics0078.htm
You can consider me a fear-mongerer if you want, but the risk of Toluene exposure are many and well documented. Put another way, right now Pink is supportive of your hobby. Would you risk changing that?
So long folks!
    November 2006
Posted by TheLastPriest on Saturday, January 5, 2008 10:36 PM
Bgrigg, I do not consider you a fear monger by any sense and am subscribing more towards your train of thought regarding all this one due to you are confirming my own fears and also due to your advice is always trusted on my end. That said my wife is a hypochondriac, maybe not clinicly but she sure is close, she is always sick or in pain from something or another, generally due to something she just learned about. Cant say I am any better though.
In this case though I was sitting there using the stuff right next to the door and she was 15ft away. I would be inclined to believe if she was not giving herself a headache through worrying she was attempting to use examples rather than just say "I dont feel comfortable with you using that in here" either way between her "having a headache" and my own erring on the side of caution I think I will save the putty for times when I can work outside(been storming pretty good around here lately. well for california at least). I think we will head down to michaels tomorrow and seek other alternitives.
Just irritates me that the better quality something is the more toxic, I use testors putty all the time and dont smell a thing. Tis the way of life, yin and yang, pros and cons, every action equal and opposite reaction.....all that jazz
    May 2005
Posted by Bgrigg on Saturday, January 5, 2008 10:57 PM
Well, you know your woman better than I do! Women tend to have a keener sense of smell than men. Toluene tends to "spread" faster at room temperature, so I can see it affecting someone across the room. My wife can tell if I'm brush painting or using putty from upstairs!
Treading on the side of caution is always a good idea with a baby. I have teenagers now, and I often wonder if solvents are at fault for the way their brain works, but I suspect it's just being 13 and 16! After all, I seem to recall a period of time during adolesence when certain parts of my own brain seemingly shut down!
So long folks!
    February 2007
Posted by SnakeDoctor on Sunday, January 6, 2008 6:16 AM
I found some irony in your comment about smoking in the car with the windows rolled up and your concern about putty Smile [:)] I agree with the comments on toluene, and using chemicals in well ventilated areas away from others. Smoking dulls your ability to smell. I have alergies and when I smoked they went away, now after over 30 years of not smoking, my wife still smells things I don't. My wife picked up some sculpting clay which is very easy to work with. No odors etc. I am going to try using it when I do some zimmerit applications. I would think most artist supply places would have it. You probably will have to seal it with Future as I don't know how good it will take to paint.
Ed
"Whether you think you can or can't, your're right". Henry Ford
    September 2012
Posted by namrednef on Sunday, January 6, 2008 10:34 AM
wow....lotta reading to get up to speed. But 20-odd years ago when I had 2-3 tubes of Sq. Green with all the !!!Toluene!!! warnings.....fuselages, wings etc. laying around....no one ever detected a scent from the putty unless within 2-3 feet of my bench....and that was when the tube was open.
 I'm not saying it's all safe......but ventilate your area. That's the best preventative. Try not to sniff from the tube......and TLP.....prolly not good to have the kid near it. Or Chinese toys
Nam
    November 2006
Posted by TheLastPriest on Sunday, January 6, 2008 11:01 AM
Hey fenderman, In another post I am pretty sure you said you were a HVAC tech. Do you still work in the industry?
    January 2003
Posted by Triarius on Sunday, January 6, 2008 12:03 PM
First off, a thanks to Bill for carrying the torch!  Heed his advice—ignore it at your peril, and the peril of those around you.
A few things I'd like to add. They've been said before, but not in this thread:
  1. Smell (by humans) is the worst indicator of the presence of any chemical. If you can smell it, you need better ventilation. Furthermore, some very nasty chemicals deaden your ability to smell them after brief exposure. Some have little or no odor.
  2. Carcinogens are like bullets. It only takes one molecule at the wrong place at the wrong time to kill you.
  3. Toxins have a threashold limit for adverse effects. Concentrations below that limit are not necessarily harmless, but are less likely to be harmfull either long or short term. The threshold limits are much lower for infants and children than for adults and are generally unknown.
There are less dangerous alternatives to body putty, many have already been mentioned.
Eternal vigilence is not merely the price of liberty. It is the price of life, itself.
Posted by jhande on Sunday, January 6, 2008 1:31 PM
With that and an infant about, best to use less toxic products.
Better to be safe now than sorry later. Wink [;)]
Yes Ross I realize that a sniff test is not a proper way to detect toxic fumes. But if my wife can smell my farts before they leave my butt... Propeller [8-]
-- Jim --
    March 2007
Posted by JMart on Sunday, January 6, 2008 3:49 PM
I worked half of my adult life in biomedical researchand laboratories... I want to strongly DITTO what Ross posted.... all three points... mostly the "smell" part, many modelers equate "bad smell" with "toxic" and no smell with "non-toxic" (as in enamels vs acrylics)... and how very VERY susceptible infant lungs are to airborne toxins and particulate matter... hope all this information helps!
    August 2007
Posted by 9 Toe Tanker on Sunday, January 6, 2008 4:05 PM
One thing I'd like to point out after reading these responses thus far concerning Squadron Green or White putty is this....UNDER NO CIRCUMSTANCES INHALE THE SANDED DUST!!!
I know from experience that when we modelers apply putty and wait for it to dry...(we just can't wait to start sanding it!). When we sand we get a little dust and generaly just blow it off the surface and that airborne dust has to go somewhere.
The dust is just as toxic if not much more toxic than the fumes are.
Dead [xx(]
Best Regards Joe
    January 2003
Posted by Triarius on Sunday, January 6, 2008 4:26 PM
Nah. She just gets the EPA emergency bulletin…Evil [}:)]
    January 2003
Posted by Triarius on Sunday, January 6, 2008 4:37 PM
Actually, that may not be the case. Many fully cured polymers are essentially inert. HOWEVER
Unless you know, why take a stupid chance?
How do you know it's really fully cured?
Almost any fine dust can be severely irritating to the respiratory system. Our respiratory systems get enough grief. Chronic irritation, too, can eventually be fatal, as in severe asthma and emphysema.
There is a very simple preventative measure: Always wet sand.
    September 2012
Posted by namrednef on Sunday, January 6, 2008 7:10 PM
Yes Chris....still at it.........using my sheetmetal abilities on a paint booth(plugging my post under 'airbrush')
Got boiler or furnace troubles?
btw....good advice you've been getting in this thread. I used to pooh pooh such notions. Not anymore.
Nam
PS....and like the name recognition!Wink [;)]
    November 2006
Posted by TheLastPriest on Sunday, January 6, 2008 10:19 PM
Ya sorry bout the name recognition, I cant look at your name without reading it fenderman. its odd, The reason I ask is I work in the home warranty industry as an appliance and HVAC expert confirming coverage and purchasing equipment. I was curious if you work with Old Republic Home Protection?
I really appriciate everybodies feedback on this thread, while I havent really lived my life taking the best care of myself I do want better for my son. I went by micheals and picked up some non toxic modeling clay. I will be giving it a shot next time I have a seem to fill
    September 2012
Posted by namrednef on Sunday, January 6, 2008 10:42 PM
the nick is one I've had for many years....related to guitar building.....
I'm surprised that you can buy a toxic product where you live!Sign - Oops [#oops]
Not sure what your counterpart here in CT would be....but I would venture that you are an inspector of some sort. We don't subscribe to the organization you mention, but we sure have our share of inspectors to deal with. We just do residential heat and A/C.....most often for new builds or major additions.....most of our service calls are for things we installed.Sign - Off Topic!! [#offtopic]
Take care of that young one.....just get a little styrene in his nose now and then!
Sure glad you got away from that disturbing sig pic you had!
Nam
    November 2006
Posted by TheLastPriest on Sunday, January 6, 2008 11:08 PM
No inspections, I am kind of like a claims adjuster for a home warranty company. When one of our plan holders calls and says their A/C (or other system or appliance) is not working we dispatch one of our network techs in the area(Contractors we have agreed pricing with) who then go to the property and diagnose. The contractor then calls my company and lets us know the specifics of the system, the malfunction, cause of malfunction and weather it was normal usage. I then determine if it is covered or not and if so I would order the condenser, air handler, compressor, god forbid a package unit or other equipment. Ship it to the contractor and have it installed. Or if it is not covered I just call the plan holder and advise of denial, then wait for the yelling to ensue. But now that I think of it we dont have plans in CT.
I was just curious to see if I had ever worked with your company over the phone, and also to let you know how much respect I have for men in your trade. It is a tough job and takes a good mix of technical knowledge and pure instinct gained over years of doing the job. I always find it funny I can send out one tech and they can spend 4 hours trying to daignose a unit and not figure it out, those are the ones that will constantly just say the unit needs to be replaced. Then I send out a good tech who can tell just by the sound or other small symptom and tell exactly what the problem is. A defrost control board later and we are in business.
Oh and dont worry about it being off topic, its my topic and I can change the topic whenever I want. Which sig pic did you find disturbing?
    May 2003
Posted by styrene on Monday, January 7, 2008 12:24 PM
For what it's worth, I would like to jump in here if I may.
I've read Ross' and Bill's responses, along with some others, and some good points have been made.
1.  The labels on products are becoming increasingly "informationally saturated".  With liabilites being what they are, and everyone becoming more and more litigation-happy, manufacturers are having to provide these "mini-MSDS" in an effort to cover their hind parts.  They have no clue whether the user is building models, repairing autos at 5 tubes a pop, or sitting in an alley sniffing the stuff out of a plastic bag.  Manufacturers are providing GENERAL information in hopes of trying to cover all the bases where use (or abuse) can occur.  With that in mind....
2. ...Common sense is authorized.  The amount we modellers use is relatively insignificant compared to say, auto/truck body shops.  Exposures are driven by the frequency of use (how often), the duration of use (how long), the product used, the ingredients, and their concentrations.  Using a few toothpicks full of putty over an intermittent 30-minute period to cover a seam in your 1/48 kit does not equate to a significant exposure.  Most putties (auto body-type lacquer putties) are nothing more than thickened primers.  If you were able to instantaneously vaporize about 60ml of putty (that's a lot!) in an averaged size room, the concentrations in air of the all the putty solvents would be less than the thresholds needed to cause a bodily effect.
I think I would be more concerned about having a pregnant wife drinking one beer every night than I would having her stand over me for 10-15 minutes while I apply a half-ounce of putty once or twice a week (Both ethanol and toluene have potential reproductive hazards associated with them.)
3.  Smelling a solvent does not mean an overexposure is occurring.  See no. 2 above.  Most organic solvents have an odor threshold several orders of magnitude below any dose-response effects.  Even if higher doses are received, the body has a remarkable means of metabolizing and excreting toxicants.  Generally speaking, problems (symptoms) arise when toxicant intake exceeds the body's metalbolic rate.
(My wife, too, will complain about the odors coming from my modelling area, but will sit in her chair in the den for an hour and remove all of her nail polish and then repaint her fingers and toes without making a peep.)
4.  Does this mean precautions should not be observed? Of course not.  Minimally, protective gloves (nitrile) and eyewear should be worn.  Using putty in a well-ventilated area should also be observed.  I would also ensure the baby is out of the way before applying solvent-based materials like paints.  Aerosols will increase exposure potentials much more quickly than semi-solids.
Use your putty appropriately, take the proper precautions, and you should be just fine.
    May 2005
Posted by Bgrigg on Monday, January 7, 2008 1:15 PM
Gip,
I will always defer to your judgement, but the concern here is a small apartment with a very young infant. As I said in my earlier post if it was just the two adults then good ventilation is fine. However small children are MUCH more susceptible to intoxicants and chemicals like toluene, and therefore I stand by my recommendation to use a less hazardous product.
Common sense should always prevail, and here my common sense is to err on the side of caution.
I will continue to use my tubes of Squadron White putty, until such time as they run out. I will look at the alternatives at that time, but will only use them if they are equal in quality. I have the luxury of a man cave, seperated from the rest of the house by a door, and well ventilated.
Cheers,
Bill
So long folks!
    June 2006
Posted by AJB93 on Monday, January 7, 2008 1:34 PM
WOW! And I thought I was on the edge of death because I sprayed acrylics without a respirator ONCE in my very well ventilated garage for about 3 seconds!
Everything I use is non-toxic.....glue, putty, acrylic paint, everything. I am extremely careful nonetheless. Glad I've been like that for most of my modeling career! No way I'm using anything labeled "Danger" or "Warning" ("Caution", maybe, in an emergency ;))!!
    January 2003
Posted by Triarius on Monday, January 7, 2008 1:45 PM
When there is a potential for taking fire, erring on the side of caution is always wise.
In that regard, I'm like an old combat veteran with a slight superstition. I've been overexposed to the incoming fire from various toxins and carcinogens. When I hear bullets flying, my instinct is to find cover, fast.
To mix the metaphor even more: The SAM (nasty substance) that gets you is usually the one you didn't see. One never ignores SAMs—it just "isn't done"—bad form and all that…
There is a difference between being careful and being paranoid. Careful is the middle ground. Most people are either careless or paranoid. The problem is that they are generally too inadequately educated to make good decisions even when they are adequately informed. Sigh [sigh]
And Gip, I think there's one thing you left out: That no one knows (or can even adequately investigate) the cumulative effects of all these nasties over time. I worked with a man who died at sixty from brain, lung, and liver cancer. He was a heavy smoker. It's easy to say that smoking killed him. But he was also exposed to very small amounts of tetrahydrofuran vapor and rarely, liquid, every day for years. Did that have an effect? Impossible to say, because one cannot disprove a negative. Does that mean it did not? Ditto.
So should we throw up our hands and do nothing? Hardly. Reasonably educated and informed caution, erring on that side, is the only sensible course—and hope that is enough. If not, well, nobody lives forever—and excessive worry will kill you as surely as anything else.
Are you willing to suffer to learn? If not, you will almost certainly learn to suffer.
