Humbrol Maskol?
    January 2008
Humbrol Maskol?
Posted by somenewguy on Tuesday, January 15, 2008 4:45 AM
I was in my LHS yesterday and was looking in the (huge) painting, weathering and finishing accessories cabinets and came accross a 22ml or 28ml jar of a medium purple gel or something called Maskol by Humbrol. Anyone know what exactly you use it for? Masking canopies, painting surfaces? If you've used it is it good?
At the end of the day one's work may be completed but one's education never!
    August 2004
Posted by four-star on Tuesday, January 15, 2008 7:26 AM
It's a liquid mask that can be painted onto the desired surface.  When it sets it forms a rubbery seal over the masked area (reasonably quickly).  Once you've finished you just peel the dried mask off.  I used it a couple of years ago and thought that it was really good for dealing with irregular areas that could be otherwise tricky to mask.  I'd avoid using your best brushes though as it can gum them up a bit if it's not cleaned quickly enough.  It smells a bit bad too but it's worth it I think!
    May 2005
Posted by Bgrigg on Tuesday, January 15, 2008 9:49 AM
Caution! Maskol is ammonia based and can eat an acrylic paint finish!
Ask me how I know that! Banged Head [banghead]
So long folks!
    January 2008
Posted by somenewguy on Tuesday, January 15, 2008 10:32 PM
I have a pretty good idea but anyway, do tell.
    January 2008
Posted by somenewguy on Saturday, March 15, 2008 8:37 AM
I bought the stuff today and read the label. It says to clean the brush with a cellulose thinner. I've got tamiya x-20. Is that the cellulose stuff?
No? What is?
Cheers
