Berna Clamps?
    September 2003
Berna Clamps?
Posted by mightymax on Thursday, January 17, 2008 10:22 PM
Does anyone carry Berna Clamps? Are they still around???
Max Bryant
    August 2006
Posted by HawkeyeHobbies on Friday, January 18, 2008 8:38 AM
I've had some for years, though they don't get used as much as I had hoped they would. They have a major drawback...no lateral support. Apply pressure to a part and they slip from torsion (twisting). The single rod between the beams just doesn't keep the clamp in alignment. If they find a way to improve this they'll get more of my business. What I found better is getting the original mirco 'Quik Grip' from Vise Grip. I have several which I use a lot. The knock offs are cheaper but stay away! I once had to crush a model to get them to release. So much for saving a buck.
Gerald "Hawkeye" Voigt
    September 2003
Posted by mightymax on Saturday, January 19, 2008 12:25 AM
Hi Gerald,
Thanks for the reply. I have several different types of clamps and a small Berna. I like it for alot of reasons. So are they still available? Anyone know????
Max Bryant
    August 2006
Posted by HawkeyeHobbies on Tuesday, January 22, 2008 8:29 AM
Oops I forgot to mention the answer...yes. They are owned and distributed by Zona Tools.
    December 2008
Posted by springy on Thursday, December 25, 2008 4:51 AM
On 01-18-2008, Gerald Voigt of Hawkeye Hobbies wrote about Berna Clamps:
"I've had some for years, though they don't get used as much as I had hoped they
once had to crush a model to get them to release. So much for saving a buck."
This answer to a model maker looking for a place carrying the Berna clamps gives me a magnificent opportunity for underlining some important property of these clamps. The Berna clamps reproduce exactly, against the object(s) you want to hold, the force you are exerting with your fingers when you push the jaws close to the beam towards the object(s). This can be demonstrated with a little of mathematics and physics (the demonstration is included in the brochure that is normally given to every user). In other words, you have the exact control of the clamping force. However, this is true only if you do not thrust upon the jaws. If you thrust, the jaws of those clamps refuse to thrust. They twist off. This twisting off of the jaws, if too much force is applied upon, is not linked to the rotundity of the beam, but simply to the fact that the jaws are slightly flexible. These clamps have only been created to apply a gentle pressure on delicate objects and not to crush them. But mind! This anti-damage safety by twisting of the jaws appears only in clamping configuration, that is to say when the jaw buffers are facing each other. As a result in bench-clamp and in spreading configurations, you can press much harder. Control of the clamping force is then only available as a safety.
So on condition you use the Berna clamps as specified above (no thrusting when buffers are facing each other), on top of the exact clamping force control and of the anti-damage safety, you can enjoy all the benefits the Berna clamps offer for holding delicate objects, unlike every other clamp:
Feather lightness,
Very limited extent beyond span, even in spreading configuration.
Instant locking.
Instant release (one finger, moving close to the beam and along it, has just to slide one jaw rear end apart).
Absolutely no marking.
Locking even when a minute force is applied.
Jaw buffers conforming to difficult shapes and as result expanding clamping force on objects and as such avoiding any pressure peak.
Extra-sturdiness as built with materials, such as carbon fibers, normally used for building modern aircraft.
Easy use as a bench-clamp for stabilizing objects that are very unstable.
Easy use as a revolutionary helping-hand with large and parallel span, without any risk of scratching at all, helping-hand that can clamp and spread.
Pressure kept up when glue retracts by drying, which results in excellent bonding.
Maximum span extendable with beam connectors.
All these benefits are explained with photos and drawings in a brochure with directions for use. This brochure is available on request. Please simply send an e-mail to phberna@free.fr, telling that you need the Berna MultiClamps brochure and you should normally receive a copy of it within a fortnight at most.
Thank you for your attention,
Dr Philip Berna
    September 2012
Posted by namrednef on Thursday, December 25, 2008 9:24 AM
My, my!
Dr. Berna next time you post (and we hope you do!)....simply click the "quote" button on the post you wish to reply, then enter your answer or comment AFTER the final bracketed quote!
.....and Sign - Welcome [#welcome] to the FSM forums!
dmk
    September 2008
Posted by dmk on Friday, December 26, 2008 11:32 AM
Interesting. I think I'll have to try a set of these.
BTW, a google search for "berna clamps" turns up at least a dozen vendors selling them, including Micro-mark.
    December 2008
Posted by springy on Saturday, December 27, 2008 5:12 AM
Reply to the message of 12-25-08 from LCdr Namrednef Navy Air WingGB:
Many thanks indeed for your advice of clicking first the "quote" button and for your Sign - Welcome [#welcome] to the FSM forums.  However, I tried to click "quote". But after having made logically displayed the message (yours), I did not see where I had to click for inserting my answer to it. So could you please explain us what to do: coming back to the Forum after having gone through the "quote" process and then clicking the "reply" button? Today, I selected to click again only the "reply" button.
Have a nice day Smile [:)]!,
Dr Philip Berna, French Air Force Lt. Col. (retired)
    September 2012
Posted by namrednef on Saturday, December 27, 2008 8:11 AM
I'm not sure I understand, but for instance.....I have quoted your last post here. Immediately following your last posted word (retired) after your signature, there appears a backslash and the word quote contained in brackets.
Simply position your text cursor to the immediate right of the final bracket and enter your text. When done, click the post button and the quoted post will appear with your new text following!
Should you wish to reply to a single sentence in a post without the entire post showing, you can edit the text by using the delete or backspace keys. Be sure not to erase the bracketed quotes though.
Hope this helps you!
BTW HawkeyeHobbies (Gerald) is very involved in the developement and marketing of modeling tools and paints.
    June 2007
Posted by squeakie on Tuesday, January 6, 2009 12:44 AM
there's another clamp that works like that, and they're made in many different sizes. It works on a "X" frame deal and will not twist. Tobe exact I think that the name of them is "Can't Twist Clamps". Tool makers use them a lot, and on occassion you can pick them up in tool sales from somebody retiring. I had a half dozen of them and gave them away! There's another bar clamp from Excell that I use every now and then to seems to work very well for me. They will slip on uneven surfaces unless you put a layer of masking tape between the plastic and the jaws. (actually I use two sided masking tape) My favorites are the cheapo blue plastic ones that Excell sells. Not real strong, but if you use several of them you don't need a lot of pressure anyway.
gary
    June 2008
Posted by jtrace214 on Saturday, January 10, 2009 11:13 PM
I just bought a pair of the small Berna clamps this morning at my LHS I haven't used them yet but I am very impressed with the quality of these tools and not even not yet using them I can see my self buying more. I have a weird fetish for clamps I got zillions of them lol
John
the pic to the left is my weekend condo lol
    May 2005
Posted by Bgrigg on Saturday, January 10, 2009 11:24 PM
John,
NOBODY ever has enough clamps! I have tons of them and yet never enough for some reason. I guess the old adage "You can never be too rich or have too many clamps" is true! Big Smile [:D]
So long folks!
dmk
    September 2008
Posted by dmk on Sunday, January 11, 2009 10:33 AM
You can say that again. Every time I need to clamp something, I can never find just the right clamp for what I have.
