Third hand stand. Danger to parts?
    January 2008
Posted by somenewguy on Tuesday, January 29, 2008 5:59 AM
Just got a third hand standBig Smile [:D]. Got home and began toying around with itConfused [%-)]. Put my pinky finger in one of the  clamps to see how much tension they had believing that they would  be fairly weak. Boy, was I wrongSign - Oops [#oops]. They ain't weakTaped Shut [XX]. And that lead me to believe that most or some parts (or any part mounted in the clamp/s in the wrong position) will simply break under the pressure. Are they safe for all parts, or should I be very careful with what parts I lodge in the clamps as well as the position I mount them in? Cheers.
At the end of the day one's work may be completed but one's education never!
    August 2006
Posted by HawkeyeHobbies on Tuesday, January 29, 2008 10:18 AM
I have some of the note holders that are given away by companies as promotional items. They work great for holding small parts for painting. You can relax the tension of these alligator type clamps by heating them. Don't get them too hot or they'll loose all of their grip.
You can also clamp the clamp. That is use a clamping device that is gentle to the part to hold it, then hold the clamp with another holder with a firmer grip.
Gerald "Hawkeye" Voigt
    October 2005
Posted by usmc1371 on Wednesday, January 30, 2008 11:57 AM
I got the Third hand stand.  To minimize damage when using the clamps, I wrap each jaw with masking tape a few times thick.  This provides a cushion when a part is clamped.
Jesse
Posted by MikeV on Wednesday, January 30, 2008 1:10 PM
You can also take a small length of surgical tubing and slip it over each jaw of the alligator clip.
It cushions the part and also helps with gripping the part.
    October 2005
Posted by usmc1371 on Wednesday, January 30, 2008 1:51 PM
Cool idea, Mike.  I'm going to give that one a try.
Jesse
Posted by MikeV on Wednesday, January 30, 2008 4:07 PM
Jesse
Thanks Jesse. I should have been a mechanical engineer like my oldest brother. Big Smile [:D]
    December 2007
Posted by Glue_Sniffer on Thursday, January 31, 2008 8:01 PM
I just tore off a square of cardboard from a model kit box, folded it a couple of times, and use that between the part and the jaws on my third hand. Seems to work well so far.
