To cut a hull lengthwise, I would score it repeatedly with the back side of a #11 blade until thin enough to 'snap'. Then flat sand it to get the uniformity I desired. I do it with aircraft fuselages all the time.
On smaller project I use a piece of a micro saw blade chucked into a knife handle to make the cut. Here is a 1:144 airliner I did.
I will draw a reference line or use some sort of straight edge fastened to the piece to act as a guide for my scoring or saw cuts...as long as you take your time and let the blade do the work it is clean fast and easy.
