Possible alternative to PE
    September 2012
Posted by namrednef on Saturday, July 26, 2008 7:17 AM
A few weeks ago I discovered a 'roll' of aluminum flashing material in the shop.....I figured it might be good for something, so I lopped off a foot of it.
A few days ago I attacked it with scissors........it can be cut soooooooo easily! I cut a bunch of strips for seatbelts. The stuff is so thin (about .015") that you can bend it and shape it as you like. I've shaped and will paint some examples.....but the stuff is very convincing.
It may have other applications.......I'll keep you posted.
PS: Anyone can find this stuff as scrap laying around near any roofing or constuction job
    August 2006
Posted by HawkeyeHobbies on Saturday, July 26, 2008 7:28 AM
Check out the metal foil tape used for sealing duct work...it too works great for modeling.
Gerald "Hawkeye" Voigt
    September 2012
Posted by namrednef on Saturday, July 26, 2008 7:36 AM
Gerald! Funny you say that! I use the stuff daily......but it is a major chore to get paint to adhere to it......oh! I have tried! I cannot find a combination of paint/primer that will accept bending without flaking off!
The stuff would be great as the tack of the tape is second to none!
    May 2003
Posted by qmiester on Sunday, July 27, 2008 10:01 AM
You might try etching the surface of the tape.  Cut it to shape, then drop it in a small cup of vinegar for a few minutes, let it dry and apply your paint.  Another suggestion would be to mold the piece to it's final shape before painting.
Quincy
    September 2007
Posted by Mobious on Monday, July 28, 2008 5:21 AM
 Hey namrednef,
 That's a great tip, I'll see if I can find some scrap flashing around the house or at the hardware. I've been using aluminum wire for some of the detailing. It's easily bent and with a little pressure from flat jaw pliers, can be flattened. I've used it for door handles in 1/35 scale and it worked great. The door handles looked better than the PE and was alot easier to do. I'll be looking for the flashing. I've got tons of stuff I could use it for.
 Thanks again for the tip,
 Best Regards,
"It's a problem of applied physics" Roy Brown
    September 2003
Posted by Daywalker on Monday, July 28, 2008 7:58 AM
Great idea Nam!  Sounds like an exciting and CHEAP idea, I love it! Thumbs Up [tup]
Frank
    September 2012
Posted by namrednef on Monday, July 28, 2008 7:35 PM
I will attempt that qmeister! If I can maintain that great stickiness.......that would be great! Makes sense to me!Thumbs Up [tup]
Yeah guys.....try the flashing and see what it gets you! You all must know someone that can get you a chunk somewhere! A whole expensive roll would last us all forever. But the stuff is sold in mall sheets also.
    September 2012
Posted by namrednef on Monday, July 28, 2008 7:40 PM
 Mobious wrote:
 Hey namrednef,
 Best Regards,
Mobius another great heads-up about the aluminum wire! That is soooooo simple! (Head Slap!)
Tons of uses!
    September 2012
Posted by namrednef on Wednesday, August 6, 2008 7:27 PM
Quincy and Gerald.....et al.
I happens that my idea hit a wall! As thin as it is.....the flashing is just too tough to work with in such a size as 1/48. Someone might have great success in 1/32.
Also have tried treating the aluminum duct tape to etch it a bit.....that's still in-work. If the tack remains (and it seems too) and will take paint......it may be a keeper.
Folks could split the cost of a roll....about $12 for a 3" X 50' roll and send a foot long piece to friends....enough seatbelts for a lifetime!
Well, maybe not for Lufty and a few others!Laugh [(-D]
    May 2003
Posted by qmiester on Thursday, August 7, 2008 7:32 AM
Namrednef - hope it works out (I've used that a lot on 1 to 1 aircraft - the FAA frowns on sanding aluminum on aircraft).  I've been tinkering with a couple of ideas for sources of soft metal to use in modeling.  One is rather common on my modeling desk - the empty soft aluminum Coca Cola cans that seem to appear on a regular basis around and on the desk and a dead soft aluminum tape made by 3M for the aircraft industry.  Am currently attempting to make a set of landing gear doors for a 1/72 Heller Bf 109 C out of one of the cans (one of the doors apparently was taken by the carpet monster/6th dimension).  I've made Alice suspenders for a couple of 1/35 figures and seat belts/harness for a couple of my models from the 3M product.  Only problem seems to be the incredible stickiness (AKA 500 mph duct tape) and the cost - last roll (2"x40yd) set me back $45!
Quincy
    September 2012
Posted by namrednef on Thursday, August 7, 2008 4:19 PM
Great suggestion Quincy! I have beer cans all over the place!......another V-8 moment! (Slap!)
How can I be so blind? Can metal will work!
TY!
    June 2008
Posted by Hans von Hammer on Saturday, August 9, 2008 3:07 PM
I do pretty good with the Testor's tubes... Or any products that come in a metal tube, for that matter... The Testor's tubes though, they can be pulled apart into two pieces, delaminated, as it were.  The label side is super-thin...
