Wow, gang! This thread really took off! I apologize, I was on vacation, and believe it or not, I was off the grid!
Anyway, thank you all for the comments, I will do my best to explain further. When I read Bakster and Max's comments about a point and shoot camera, I remembered I do have a Nikon CoolPix S4. But after a fresh set of batteries, the screen is black which indicates the CCD has gone bad. I may look into purchasing another one, but not at this time.
Jack you are correct, I am too close to the subject. I was basically moving within a couple inches (Sorry, about 6cm) from the subject, then pull back until it would take the picture. I do realize this is not a preferred method, and a main reason for this thread. Also, i'd rather purchase exquipment for a small portrait studio, and have quality lighting, than purchase a new lens.
Greg in the picture is a .050 piece of round stock and a wire that was bent into a spring. Greg you and Bakster are correct that the camera focused on one end of the stock and not on the other end or the spring. I attribute this to being to close to the subject, which I believe I can improve upon.
Now, Mr. Tilley really lit my light bulb when he mentioned the pixel size and croping. So, I decided to take another picture. This time I took off the 18-55mm and put on my 70-300mm IS lens. I stood back several feet, zoomed in and took the picture. Here is the result after I cropped the picture with Paint:
I am please with this result.
Granted, I still want to spend a few dollars for better lighting and different back grounds for different subjects. And I'll be practicing more. Thank you all for the suggestions and comments.
By the way, the piece you see in the picture is the front landing gear for a MQ-1 Predator. I did not like the plastic shock that was molded, so a cut it out and scratch built a proper coil over shock.
Thanks again to all who commented, you definitely helped me out!
