Guess what I Discovered?
    June 2014
Posted by Tanker - Builder on Monday, August 26, 2019 5:58 PM
Hi;
       Well, we all know there is a ton of puttys that are used for modeling, Right? I mean ,over the years I have used just about every one I can think of that are able to be used on Plastic or Wood.
     Now I got some Tamiya White Putty ( never used this stuff before),Because it came well recommended. What I can,t figure is why? I applied it where it needed to be . I let it dry for about two days. Well, let me tell you, was I surprised when I had virtually no luck using hand tools on this stuff!
     Granted it finishes well. But it is rock hard, and almost impossible to work with non - powered tools . My question is this. Why in the heck did it dry so hard?
    February 2011
Posted by GreySnake on Friday, August 30, 2019 1:14 PM
I haven’t had good luck with the white putty from Tamiya nor have others, judging be a quick search. Only used it once on a wing root join and had the same problem as you, it dried rock hard. Switched over to the Tamiya grey putty and haven’t had the same problem. On a recent build parts I used putty on set for twenty or so hours and didn’t have an issue sanding once dry.
    September 2017
Posted by Strongeagle on Friday, August 30, 2019 3:15 PM
Ahoy Tanker-B.  Hmmmmm.  Like yourself, I've also tried nearly every putty know to man and lately, Tamiya White Putty has become my favorite solvent based putty.  Haven't had the rock-hard experience you've described.  I don't usually let it sit a couple of days, but usually get after it fairly quickly (within a couple of hours).  I sometimes thin it with lacquer thinner and apply it with a toothpick whose end I shape to make look like a small flat screwdriver. I like it because of it's very fine composition and smooth texture.
    September 2012
Posted by GMorrison on Friday, August 30, 2019 3:38 PM
My favorite continues to be Bondo Glazing and Spot Putty, the single-part stuff in the tube.
    June 2014
Posted by Tanker - Builder on Saturday, August 31, 2019 8:56 AM
Hi;
      I concur with that " G ".  I have used it about 80% of the time.
    March 2015
Posted by JohnnyK on Tuesday, September 3, 2019 11:21 AM
Yep, the Bondo stuff works great.
Posted by Don Stauffer on Thursday, September 5, 2019 9:03 AM
JohnnyK
There are other brands that are very similar.  Used to be it was called spot putty.  Now it is called glazing putty. I find it primarily in auto parts stores.
    June 2014
Posted by Tanker - Builder on Friday, September 6, 2019 7:26 AM
Don;
    The stuff you refer to, used to be called 3-M SpotGlazing Putty. Would you believe it came in 5lb. tubes? It was always a dark red. Boy, did it work good too! I still use it on ship hulls as a last coat mistake corrector. Great stuff considering how long it's been around.
      We started using " Green Stuff" and didn't like it's reaction under Ditzler's " Hot " lacquers! Sometimes the surface looked like the Auto had a case of Zits! So we went back to the red Spot Glazing Putty !
    April 2016
Posted by GlennH on Sunday, September 8, 2019 11:58 AM
I had nothing one day to fill a small seam in a howitzer barrel so I used some premixed drywall mud I had. It worked and has lasted. I suppose there must be drawbacks I am not aware of because I never hear it mentioned.
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
    June 2014
Posted by Tanker - Builder on Wednesday, September 11, 2019 7:58 AM
GlennH;
     Hi Glenn! Don't worry. Before Hobby Putty and Spot Glazing Putty, I used to use Plaster of Paris or Spackling Compound. Sometimes even Plastic Wood ! They all work too! T.B.
