Can DAP Alex Plus be used as a filler?
    August 2015
Posted by jr223 on Friday, March 15, 2024 4:37 PM
Howdy,
Just did some work on the inside of my house, filling some cracks on the basebards using  DAP Alex Plus. It got me to wondering if it ( DAP Alex Plus) can be used as a filler in place of say Plastic Putty or any of the other model filler.
    September 2006
Posted by the Baron on Monday, March 18, 2024 12:42 PM
jr223
Howdy,
Possibly, but you could always test it with some scraps of styrene, leftover parts, etc.
It certainly works for groundwork for a base, over a foam insulation core. Or over luan plywood for buildings.
    April 2020
Posted by Eaglecash867 on Monday, March 18, 2024 1:05 PM
Only one way to find out.  Wink
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    March 2020
Posted by Having-fun on Thursday, March 21, 2024 4:22 PM
As you may know, when a wooden ship is planked with the first course of planks, there is a need to sand and fill up all the holes and imperfections due to the inability of the wood to properly bend in the desire orientation.
So, what I have been using as putty to cover those areas is a wood putty that comes in powder form, which is good because you mix the amount you need with water and it become a paste that is fairly easy to put on, you just have to work fast because this stuff drys very quickly.
It is a wood putty, so it is comparable with my wood models, as you may know, when you buy already mixed wood putty, the unused putty left in the can dry up within 20 days so you are always trowing money away, with the powered putty , you only use what you need and as long you close the can, the left over never drys out on you.
Following is a photo of the can. You can buy this stuff in Home Depot or Ace. Lowes most likely also have them. It is cheap, between 8 to 20 bucks, depending on the size
Wood Putty
Hope this helps.
Joe
    August 2015
Posted by jr223 on Thursday, March 21, 2024 5:05 PM
I love the artwork on the can.
    March 2020
Posted by Having-fun on Friday, March 22, 2024 7:48 PM
jr223
Yes, it is not what would you call an example of the product, maybe the designer has a sense of humor.......
Joe
