Nope. But I find I use so little each time that it lasts me a long time. I generally do not spray it on joint, but apply it with a toothpick, or a homemade tool.
The tool I use is a medium size sewing needle, with its point shoved into a piece of 3/8 inch dowel. Then, I grind the end of the eye off, leaving a fork. I push down the plunger of the kicker bottle until some kicker oozes out of the nozzle. I then touch the fork to it, transferring the liquid kicker to the area within the fork, where it sits by surface tension. Then I apply it to the joint.
