I've Got The Modeling Shakes......
    July 2012
Posted by littletimmy on Thursday, October 19, 2017 6:16 PM
Tanker - Builder
 Now the " Devil's Cut " and the " Couvosier " only come at completion usually .
I have a few customers that "swear" I weatherize BETTER when I have a snort or two of Bourbon in me. (So much so that they bring the bottle!)
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    March 2005
Posted by Devil Dawg on Saturday, November 18, 2017 1:45 PM
Thanks to all for the replies to this thread - greatly appreciated!
Went to a neuro specialist the other day, and he said the same thing other doctors have told me - it's a condition called "essential tremors", and it's nothing to worry about. Some people display it worse than others, but it'll probably stay at the same intensity that it's at now for probably the rest of my life. Oh well..........
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    November 2004
Posted by snapdragonxxx on Sunday, November 19, 2017 7:11 AM
Everyone has this type of shakes. It is the result of your brain overloading your nervous system. you don't realise this because it is a subconcious thing and is a result of stress and tension. You don't realise it but conciously you recognise that this is a very small and quite often vital area that has to be done right the first time. This has a knock on effect subconciously and causes like a mini riot between nerves and muscles. All the stress and movement messages come streaming down so fast with the messages stay still! tiny movements! stop flexing.... It's like the internet melting down when playboy of the month does a live interview on youtube in the pink and crinklies!
You can minimise this with several techniques including slow deep breathing to calm yourself.
Just let your mind go blank and empty. Try a measure of Whiskey or other DARK spirit. That kind of alcohol will slow your mind down and calm you a little bit. Don't overdo it though or else it will have a negative effect. Just half a standard measure will be fine. Drink it neat and in little sips and give it an hour to get into your system.
Use a magnyfying lamp. this can fool your stressed out brain that things are larger and easier.
When dealing with small painting jobs, limit your time at the bench to just that bit and then walk away for an hour or so. don't try and do it all at once.... it's a stress releving excersise!
ON the other hand.... if you are on a roll and it becomes easy then just keep going.
Put some classical music on in the background. Particulaly Mozart. It is a good and calm distraction.
I have hand shake. some days it is worse than others and it is due to side effects of my heart medication that is keeping me out of a wooden Jaffa box and away from a BBQ!
Some deep breathing and slow release, a sip or two of whiskey and some Mozart on and I am off!
Boiling it down. you are just overthinking this and what you are attempting to do. cut that out, have a drink, some background music and crack on!
    October 2014
Posted by ThatMixBoy on Monday, November 20, 2017 2:43 PM
I also have the shakes, primarily in my left hand. Dr. says it is because of the meds for epilepsy. Cannot do anything about it. I do the best I can by resting that hand on the bench and not using it for small parts placement. Won't keep me from the bench though. I am only 65 so I have a lot of time left. I like the suggestions of deep breathing, whiskey, and soothing music. Keep on truckin' through the fog.
    October 2020
Posted by Demolition on Sunday, January 10, 2021 7:11 PM
snapdragonxxx
thats great advice!
Posted by Don Stauffer on Tuesday, January 12, 2021 8:46 AM
ThatMixBoy
I go further with the hand contact bit.  I keep a couple of blocks on my bench so I can raise my left hand a bit above the bench surface.  I hold the model or the assembly I am adding parts to in that left hand touching the bench, or that block.  I then keep my right wrist in contact with the benchtop while holding part with tweezers or fingers.  Having my left and right wrists in solid contact through benchtop helps a lot with shakes.
    January 2020
Posted by wpwar11 on Tuesday, January 12, 2021 12:57 PM
I completely agree with Don.  Keeping my hands on the bench helps significantly.  I try and plan and build various assemblies where I can optimize this approach.
    August 2020
Posted by Dodgy on Friday, January 22, 2021 11:41 PM
Well Mate, I have the same condition - essential tremor, or familial tremor. My sister has it too. I am 63 and it became so bad that I couldn't write, and even had problems typing. I gave up taking photos years ago and had basically stopped modeling. Two years ago I had "deep brain stimulation" surgery. Essentially I now have a couple of electrodes located in my brain, connected by wires to each other and then to a unit in my chest which I have to keep charged up. Booze used to help, but getting boozed to the point where my hands settled down and trying to stay sober enough to complete the work became a problem.
I still drink, Vet affairs has me listed as addicted to and dependant upon alcohol. True enough. But the surgery, whilst not pleasant, worked a treat. Now I just have to stay off the booze, because it undoes all the good work that the surgery achieved. I try to maintain a balance, but its not always easy. I have had the tremor since I was about 48 or 50.
The breathing exercises are good value, as is the advice to rest your hand against something. It will however deteriorate, at which point you will need to consult your doctor. My situation is much improved, but I still have to pick my days.
Good luck old son.
Rob Ferguson
I long to live in a world where chickens can cross the road without having their motives questioned
