The Bullion Express--Boot Hill Express (Reboot 10-4-22)
    July 2014
Posted by Bakster on Monday, June 21, 2021 12:33 AM
GMorrison
There was an episode in the Batman TV show where Penguin and his crew raided a bank vault but were surrounded. They escaped by  this,,,
There you go! Don't mess with armament! Lol.
    July 2013
Posted by steve5 on Monday, June 21, 2021 12:42 AM
this is looking pretty cool steve , love your vivid imagination mate .
    July 2014
Posted by Bakster on Monday, June 21, 2021 1:05 AM
steve5
Hey Steve! Hold that thought! I see some gold bandits coming...
Ok. Now what were we talking about? Oh yeah, vivid imagination.
steve5
Thanks Steve!
Btw. I just awoke on the couch. I was watching episode 20 of the Midwest Model Missouri build. All that PE... Wow! You sir will be an PE expert when you are done with your kit.
    May 2013
Posted by Greg on Monday, June 21, 2021 7:20 AM
Great job on that turret and the guns. Your eBay rivets  really added A LOT. Guns are so nice, half a shame to hide them inside the turret.
How did you fasten the wall of the turret to itself when you made the circle? Certainly not a butt joint. It's surprising how well that turned out, however you did it.
I vaguely remember those pop cans Bill mentioned too, and also never heard of the neat trick.
    July 2014
Posted by Bakster on Monday, June 21, 2021 8:43 AM
Greg
Hey Greg--thank you sir. Yeah I think the rivets add another dimension to the piece.
Greg
If you look at the image you can "sort of" see. The ends are butted but I glued a strip of styrene to hold them together. You can see the strip at the far inner wall. I think it was sort of key to not make the strip too wide where memory retention might distort things. On the other hand, a strip too thin might not be enough to hold the circle either.
So basically-- once the glue was set, I worked on bending that join so that the circle carries through. It held the memory of my adjustments nicely. The areas I was most concerned about is where I cut openings. Those were weak points and the walls bulged out at those locations. This styrene is very malleable, so I was able to work out the tensions.
It's not 100% perfect but it is absolutely close enough for my purposes. Actually-- for the time period of the piece-- I don't want it looking perfect.
Thanks for asking and checking in!
    October 2019
Posted by Tanker-Builder on Monday, June 21, 2021 11:32 AM
Hi:
        When I build things like that this is what I do. All the openings have .010 supports inside out of the different sight lines. That avoids the Bulges.
    July 2014
Posted by Bakster on Monday, June 21, 2021 11:43 AM
Tanker-Builder
Hi:
I want to know more. How do you run the supports around the openings? What  sort of shape to them? Place them vertical? Horizontal?
    May 2013
Posted by Greg on Monday, June 21, 2021 1:26 PM
Bakster
Greg
Greg
Ahah!
Yes, I can see the 'splice' when I enlarge the pic. I thought about an unsupported butt joint and an overlap glue job, never considered your solution.
Your verbal descriptions are good, I got everything you explained before I even enlarged the pic. Yes
    July 2014
Posted by Bakster on Monday, June 21, 2021 3:01 PM
Greg
This worked really well because where the two ends connect they melted together nicely. Literally, all I had to do was give the join a light sanding and the join disappeared. No filler needed. I wish it is always that easy. I like working with this stuff.
Greg
Good to hear! Yes
    September 2012
Posted by GMorrison on Monday, June 21, 2021 3:13 PM
Or go fu;ll blown steampunk.  Overlap the ends in two locations- 180 Deg apart. Install massive rivet heads in at least two rows top-bottom, each location. Run a ring of rivets all the way around the top and bottom.
    July 2014
Posted by Bakster on Monday, June 21, 2021 3:39 PM
GMorrison
Funny you mention this because I thought about doing something similar.  I like your concept better, though. In the end I nixed the idea for the sake of expediency. I often cut corners where I can. Not sure that is a good thing.
Anyway, good thought, Bill. You always have good ideas and they often end up in my models. Case in point, the turret gun!
    May 2013
Posted by Greg on Monday, June 21, 2021 3:48 PM
GMorrison
That's a neat idea too.
Posted by CapnMac82 on Tuesday, June 22, 2021 11:37 AM
Bakster
Below: None of this is secured. From here I will move towards painting the stack, turret housing, and the guns.
Outsanding stuff.
Steampunk might suggest a mushroom vent on the turret.  And/orr a whistle-looking appendage.  My Giggle Image-fu is poor today, I know I have seen the effect, just can't find the example.
    July 2014
Posted by Bakster on Thursday, June 24, 2021 10:49 AM
CapnMac82
Bakster
Outsanding stuff.
Thanks Capn!  I decided to  leave it as is. I am in that good enough state of mind. Good, bad, I do not know.
Primer is applied and I hope to apply color no later than this weekend.
Thanks for your input! I always welcome it.
Posted by Gamera on Thursday, June 24, 2021 11:30 AM
Hoorah!!! Looking forward to seeing the first coat of paint on her!
    July 2014
Posted by Bakster on Thursday, June 24, 2021 12:59 PM
Gamera
Ha! I love your enthusiasm,  Cliff.  I have to tell you. Just seeing it primed is exciting to me. There is something about paint that makes the build take on a new.life.
Posted by Gamera on Thursday, June 24, 2021 9:39 PM
Bakster
Gamera
Well, I just love watching other people build stuff here since I'm too lazy to get anything done myself! Sleep
    July 2014
Posted by Bakster on Sunday, June 27, 2021 2:21 PM
Gamera
Glad I can help! Surprise
    July 2014
Posted by Bakster on Sunday, June 27, 2021 3:20 PM
Color is on.
Below:  I painted the EM guns with a mix of Alclad Copper and Alclad Aluminum. Firstly, I wanted the guns a different color than the turret housing. Secondly, the added aluminum brightened the copper some. I did not want a pure copper color.
Also-- all the pieces are treated with a Vallejo Black Wash. I thought I would give the product a try. It is an acrylic based wash. I think the stuff worked very well; it was easy to work with. Any excess I didn't want was easily removed with a water moistened cotton swab. How it works on an acrylic base is yet to be seen.
I am on the fence about painting the em magnets different colors. Mostly because the detail probably won't be seen anyhow and if I can cut some work out of the build, I am all for it. I will make the final decision before install.
Below: The stack and turret housing are painted with a mix of Alclad Polished Brass and Alclad Steel. Their brass is a beautiful gold color, but it is far too close to their gold. The gold bars I will add later I want to stand out and if everything looks gold-- you kind of lose the effect.
(Camera distortion on the stack) Speaking of the stack--I am on fence what color to paint the crown. I am leaning towards the color of the roof which will probably be a light green.
I will probably apply a topcoat to seal them, but I hate to. I love the sheen that the alclad produced. I may opt to not.
I love Alclad. Good stuff Maynard.
Below: In between things, I worked on fitting the roof to the carriage housing. Straight from the kit is a large gap where the two meet. The reason for this, as it turns out, are the circular pads. I had to drastically cut them back. And let me tell you, that was work. I used a large grained sanding stick that makes havoc with any plastic-- but there was a lot of material to cut through.
And this brings me to a side commentary. Over the months I have seen a few posts where people question the use of dremel type cutting tools in modeling. I use the thing a ton and I used it here too. Tired of endless sanding I attached a cylindrical cutter to my power tool and cut the material like it was a milling machine. It made quick work of the job and I only regret not doing that sooner. This is a case where I would have been cussing at all the hard work if I didn't have the tool. For me, the tool is almost indispensable.
And you can see how ugly the underside is and why I probably won't have the roof removeable. Too much work to make that labotomy presentable.
End of update.
    July 2009
Posted by Back to the bench on Sunday, June 27, 2021 4:26 PM
This is looking really cool!!
I now have images in my head of James West and Artemus Gordon that I watched every Saturday careening down a mountain road on this wild machine!
Gil
    July 2014
Posted by Bakster on Sunday, June 27, 2021 5:03 PM
Back to the bench
Hey thanks, Gil.
Lol. Right? I can imagine Dr Miguelito Loveless lifting the turret housing and out comes his smirking face. Stick out tongue
Posted by Gamera on Sunday, June 27, 2021 6:41 PM
Love the brass look on the guns and the turret! Heart
    July 2014
Posted by Bakster on Sunday, June 27, 2021 8:47 PM
Gamera
Thanks Gam!
    May 2013
Posted by Greg on Sunday, June 27, 2021 9:30 PM
Gamera
Oh boy does that sound familiar.
    May 2013
Posted by Greg on Sunday, June 27, 2021 9:38 PM
Bakster
Some folks, included our friend Ernie (PlasticJunkie) are really liking Intermediate Gauzy Agent
It's from AK and folks are talking it up for clearcoating over Alclad. I bought a bottle on PJ's recommendation but haven't tried it yet. It's the green bottle. Ernie said the yellow bottle is for dipping.
Man oh man your project is looking sweet, Steve. Yes
Edit: I stumbled on the above link just searching for a product description to show you. Hadn't seen that tutorial from AK before, it's pretty neat, isn't it?!
Posted by keavdog on Sunday, June 27, 2021 11:57 PM
Whoa!  That looks awesome dude
Thanks,
John
    July 2014
Posted by Bakster on Monday, June 28, 2021 9:54 AM
Greg
Some folks, included our friend Ernie (PlasticJunkie) are really liking Intermediate Gauzy Agent It's from AK and folks are talking it up for clearcoating over Alclad. I bought a bottle on PJ's recommendation but haven't tried it yet. It's the green bottle. Ernie said the yellow bottle is for dipping.
Hey Greg-- good to know. I will look into this. Thanks for sharing this!
Greg
Thanks, Greg.  We'll see how it ends...
    July 2014
Posted by Bakster on Monday, June 28, 2021 9:55 AM
Greg
Yes-- it is nicely laid out. Yes
    July 2014
Posted by Bakster on Monday, June 28, 2021 9:57 AM
keavdog
Hey thanks, keavdog. I appreciate the encouragment!!!
Posted by Gamera on Monday, June 28, 2021 12:35 PM
Bakster
Greg
Greg
Yeah, that's great Greg! Thanks!!! I've been using the sealer for Testor's Model Master Metalizer but since they don't make it anymore (at least I don't think so) I'll run out one day. Great to have an alternative.
