Back to the bench
The stack assembly looks awesome!
Hey Gil, thank you so much. That encourages me.
Back to the bench
Kind of sets the tone for the whole build
I like that. It kind of does.
Back to the bench
I was curious how you fabricated the rings or ribs on the stack?
I really appreciate that you asked that. Aside from the crown, everything else was done by using Evergreen plastic. Starting at the top then. I used half round strip that I wrapped around the tube giving it that rounded look. Below that I used T strip with the top of the T glued down on its flat side, and wrapped around the stack. This produced a thin band that circles the tube. Below that then (x4) I used thin flat strips wrapped around the tube. And the last piece is again the T strip attached the same as the first. In this case, it creates a sort of flange. You can't tell from the image but below that stack I had drilled a slightly undersized hole into the roof whereby the tube can go through, but the flange can't. This seats the assembly onto the roof.
And this speaks to my point where I said it would be difficult to do if I had used a brass tube. The reason is, I would have to use CA glue to attach the strips, and that is never an easy prospect. For one, it's messy. Secondly, if a person is not careful it could attach too quickly, possibly crooked. With styrene on styrene using Tamiya Extra Thin, the process is very forgiving, and very easy even. I tack one end of the strip to the tube and then keep working the strip around until it overlays the other end. I then carefuly cut the strip so they butt together. All during this I can adjust the alignment so it's straight. The glue offers a person some working time. It is not much, but just enough time.
I hope I explained it so it makes sence. If more thoughts or questions, please let me know.
If by chance you are not too familiar with Evergreen plastic, see the link below. Most hobby stores carry the line. The more I use the stuff, the more I love it. It is very versatile. Several years back GMorrison educated me on it and it opened a whole new dimmension to me in scale modeling.
Probably more than you wantd to know. Lol.
https://evergreenscalemodels.com/
