Harrier colors
    April 2009
Harrier colors
Posted by Cadet Chuck on Tuesday, August 26, 2014 7:41 PM
I'm working on a 1/72 Hasegawa Harrier.  The only two paint schemes they show in the  instruction sheet are both green and gray camoflage.  I looked up  a bunch of photos of the plane on the  internet, and found most of them were solid colors, various shades of grays, some blues, some tans- but no camo that I came across.  What do you think would be the most appropriate color for this model?  I am not too interested in the camo scheme.  Since it is a Marine aircraft, I'm thinking gray would be most appropriate .  And how about the bottom- White?  Or same as on top?
Posted by jmcquate on Tuesday, August 26, 2014 8:17 PM
Depends on the time frame. Early USMC Harriers had a green/ grey with light gray underside. Then the went to to a 3 tone wrap around camo similar to a Euro 1 scheme. Currently they have a 3 tone grey camo.
    July 2004
Posted by stikpusher on Tuesday, August 26, 2014 9:41 PM
It all depends upon the version and era for the camo scheme. The RAF, FAA, and USMC Harriers all wore various camo schemes over the years, both factory and field applied.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2004
Posted by seasick on Tuesday, August 26, 2014 11:57 PM
Its a matter of time. More green and dark gray in the 1970s Becoming dark and light ghost gray in the late 1980s and onward.
Chasing the ultimate build.
    April 2009
Posted by Cadet Chuck on Wednesday, August 27, 2014 12:13 AM
Thanks for the info!
Chuck
    July 2004
Posted by stikpusher on Wednesday, August 27, 2014 12:41 AM
AV-8A, same as the RAF- Deark Sea Grey & Dark Green over Aircraft Grey w/full color markings
later AV-8A/AV-8C, same colors with subdues markings
field applied scheme of White added for use in snowy areas
AV-8B
Initial production scheme Dark Green and Medium Gray over Light Gray
Standard production scheme dark gray/dark green wraparound
Desert Storm 1991, Dark Green and sometimes Dark Gray replaced with lighter grays in field applied schemes
post Desert Storm TPS schemes on Harriers- darker and lighter versions
light
dark
       - Plankton
LSM
