Messerschmitt BF109 GB 2012
    February 2010
Posted by Stage_Left on Monday, March 12, 2012 8:44 PM
satch_ip
I think most RC know about the cowl seam.  It's the spine of the fuselage seam that worries me.
satch
I was guest judging at GraniteCon (Nashua, NH) last October and one of my categories was 1/32 a/c, which had two 109's entered. The fuselage spine seam was prominent on both, and as my team and I were discussing this a member from a team judging the next category over briefly joined in. He noted that the seam was accurate, so there's awareness of the spine seam in this neck of the woods among six people, at least.
    June 2008
Posted by Hans von Hammer on Monday, March 12, 2012 9:08 PM
Are y'all talking about the one on the underside?
    February 2011
Posted by Reasoned on Monday, March 12, 2012 9:18 PM
Hans von Hammer
Isn't there one on top and bottom?
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    February 2010
Posted by Stage_Left on Monday, March 12, 2012 9:26 PM
Hans von Hammer
I was talking about the dorsal seam.....
    August 2009
Posted by TREYZX10R on Monday, March 12, 2012 10:19 PM
Great looking builds going on in here ,hope to get mine started as soon as I wrap up over at another g/b. The dorsal seam debate has been kicked around here on another thread and on other forums I frequent. I 'm not saying it is prominent but its hard to see the seam in pics
I know from research that the construction process of the fuselage did have a join area there in the dorsal spine, but how visible it was on the finished product is questionable.
I do'nt make any claims about being an expert on the 109 but the seam is hardly visible to me in the pics
    March 2010
Posted by Nathan T on Monday, March 12, 2012 10:39 PM
The seam is there, top and bottom, but hardly noticeable compared to the other panel seams on the aircraft. In 1 48 it should be barely visible. I think on most models I see it is overdone.
    June 2008
Posted by Hans von Hammer on Monday, March 12, 2012 11:24 PM
OK,  gotcha.. Thanks..
Meanwhile, I finished the seat.  I had to grind down the seat sides and make them more squared-off than the kit seat was.  Once ground down, I added a strip of Evergreen styrene to each side...
Here's the seat and floor assy.
I then added two stretched sprue "posts" in the top of the rear bulkhead as attachment points for the shoulder harness. I made the strap's hardware, and after sitting the top buckle onto the posts, I used a knife heated with a lighter to melt the tops of the posts and secure the harness-straps.
The buckles and keepers are wire that bent into shape, with Tamiya tape straps...
More to follow..
    February 2011
Posted by Reasoned on Monday, March 12, 2012 11:34 PM
Looking good Hans, nice to see somebody else also uses tape with metal wire for seat harness.Whistling
    June 2008
Posted by Hans von Hammer on Monday, March 12, 2012 11:44 PM
Is there another way?
    June 2008
Posted by Hans von Hammer on Tuesday, March 13, 2012 12:31 AM
Cockpit's about ready for paint...
But I gotta do the floor first:
Since the floor didn't have the foot-rests (or whatever the heck the Germans called them), I had to make them.. I used sheet styrene for a base, and stretched sprue for the detail.. I heat-formed the curve in the edge piece, then glued it into place.  I then cut each individual cross-piece and then glued them into place..
Now, onto the trim-wheels and cannon breech! Yay....Huh?
    September 2009
Posted by satch_ip on Tuesday, March 13, 2012 6:23 AM
A couple of questions for the 109 builders here.
1)  Why are European decals such shite?  Peddinghaus and now Techmod decals look great.  They cover subjects no one else does. But they are so thin and fragile that they are totally useless!
2)  How many 109 builders out there put on all the stencils?  There must be a hundred tiny little decals.  In 1/48 you can't even read them or see some of them with out your Optivisor.  So do you put them all on anyway, some of the more prominent ones, or just stick to the main markings?
Satch
    February 2011
Posted by Reasoned on Tuesday, March 13, 2012 7:15 AM
Haven't done one yet but it seems like they number all of the fuselage panels among other things.
    June 2010
Posted by DoogsATX on Tuesday, March 13, 2012 8:41 AM
Satch - Cartograf is European, too...guess others have to bring balance to the Force.
Personally I do stencils until my eyes start crossing, then I say screw it.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    March 2010
Posted by Nathan T on Tuesday, March 13, 2012 8:45 AM
Satch- As I wrote in my last post I had some limited success with Techmod, but stay away from Peddinghaus! There's so many aftermarket decal options that I tend to stick with what I know is good(Aeromaster, Superscale, EagleCal..ect..) As far as stencils I usually look at photos from the period and whatever stencils are visible on the real thing those are the ones I put on. It usually includes the fuel octane ones, oil tank, trim tabs, external power, and sometimes the wing walk, and sometimes the stencil data on the cowling. Thats it.
    December 2010
Posted by Geof on Tuesday, March 13, 2012 9:32 AM
Satch,
Like Nathan, the stencils really depend on the plane you are modelling. I would say a good majority of later year 109s had the stenciling mostly painted over in the field at some point. There really isn't too much stenciling over all though. The area under the rear stabilizers have a few notes, the fuselage panels are numbered on the left side only and there are a few more here and there. I take the middle ground, usually on the bigger planes I'll do the stenciling, on the 1/48s not so much unless I know for a fact (based on pics or research) the plane I'm doing had them. The one I'm working on now I was doing the stencils and gave up, the decals have been a pain in the a$$ on this one for some reason. So just the key markings for this project....
Photobucket
On the Bench: Tamiya's 1/48 A-10a Thunderbolt
In the Hangar:  Hmmm???
    April 2006
Posted by jgeratic on Tuesday, March 13, 2012 1:50 PM
About Peddinghaus decals, although I've never used them I have seen complaints about them.  Did some digging and learned these are created on an Alps printer (some guy working out of his home?).  If it is a one man business that would explain the lack or very little instructions supplied with the decal sets.
To use them you will have to first apply a protective clear coat and coat them again once placed on the model.
regards,
Jack
    March 2010
Posted by Nathan T on Tuesday, March 13, 2012 1:57 PM
Good to know Jack. But this still doesn't solve the out of scale, too large or too small markings problem. Or the fact that i had to pay $20+ for them. So its good to have comments like these so others know before they buy.
    September 2009
Posted by satch_ip on Tuesday, March 13, 2012 10:23 PM
Doogs, point to you on Cartograph.  They are good quality.  The Academy 109E Heinz Bar had Cartograph decals.  Even ones for the wings and fuselage splinter cammo.
As for Peddinghaus, I found them beautifully printed and they covered some rare subjects, they were just fragile.  I stopped at my LHS today and bought some stuff to fix that.  Thanks Hans for bringing that up.
    June 2008
Posted by Hans von Hammer on Wednesday, March 14, 2012 6:26 AM
No problem, Satch.. Like I said, I swear by the stuff..
    September 2009
Posted by satch_ip on Wednesday, March 14, 2012 7:11 PM
My third Heinz Bar mount is complete.  His Bf 109F-2 of I/JG77, Kerch, Russia, 1942.
Heinz Bar's stable of mounts so far.
The Luftwaffe Experten shelf.
The Kit was the Hasegawa 1/48 F2 built OOB except for the belts.  The yellow is Vallejo and the 74/75/76 are MM Acrylics.  Decals are a mixture of Techmod and kit decals.
My Achilles heel is radio masts and antennae.  I just can't get them tight.  When I tighten the wire, the mast breaks off or gets loose.  Oh well more practice.  Thanks for the GB.  I love me some 109s
Satch
    March 2010
Posted by Nathan T on Wednesday, March 14, 2012 9:48 PM
Nice job Satch. All of Heinz Bar's mounts look cool, from the Emil's to the Fws. What are u using for the antenna? I use stretched sprue and attach with superglue. I secure one end, and only pull enough to keep it tight, the hit the other end with accelerator. Try heating up a razor blade over a candle then hold it over the sprue and it should tighten up.
    December 2011
Posted by Luft Modeler on Wednesday, March 14, 2012 9:53 PM
Excellent job Satch!
PM me which three pictures you want me to showcase on the front page!!
    February 2011
Posted by Reasoned on Wednesday, March 14, 2012 11:05 PM
satch_ip
http://i861.photobucket.com/albums/ab171/satch_ip/Hasegawa%20Bf%20109F%20%20Heinz%20Bar/IMG_0640.jpg
They all look great satchYes!  You bring a smile to my avatar little "Pritzl".... oh that's right, he's always smiling but he does approve of the job you did on his a/c. Big Smile
    February 2012
Posted by lawdog114 on Thursday, March 15, 2012 12:06 AM
lawdog114
Hey PZL66, can I get into this Group Build?  I have a 1/48 Bf 109 G-14 waiting to be built.  I'll have to search the net for some interesting markings.  I've never participated in a Group Build.  Are there any rules?
Thanks,
Joe
The decals and TD cockpit came in today.  I'm read to go.  If I can only decide on which of these 109's I want to build.  Confused
    July 2011
Posted by handiabled on Thursday, March 15, 2012 7:00 AM
                              Looks great Satch  Yes
    March 2010
Posted by Nathan T on Thursday, March 15, 2012 9:07 AM
Whatever you decide Lawdog you'll like that TD cockpit. Simple, but they look great all painted up.
    February 2011
Posted by Reasoned on Thursday, March 15, 2012 10:24 AM
lawdog114
 lawdog114:
Thanks,
Joe
The decals and TD cockpit came in today.  I'm read to go.  If I can only decide on which of these 109's I want to build.  Confused  http://i1065.photobucket.com/albums/u384/lawdog114/BF%20109%20G-14/100_3469.jpg
Being a HUGE 109 fan (my favorite aircraft ever produced), I'll be looking forward to see your work.
    March 2010
Posted by Nathan T on Thursday, March 15, 2012 11:41 PM
Here's my progress, decals on and sealed with Gunze gloss. Drying now, washes to come.
    December 2011
Posted by Luft Modeler on Friday, March 16, 2012 12:08 AM
Almost there Nathan!! Looking great!
    December 2010
Posted by Geof on Friday, March 16, 2012 12:17 AM
Guys, everyone is cranking out some nice stuff! I'm a little dead in the water, been super busy! Hopefully this weekend will show some progress!
Looking forward to that g-14 build! Gonna do it in Hartmann winter scheme?
Photobucket
