Me410 B6/R2 ProModeler (Completed)
Posted by Texgunner on Tuesday, December 16, 2014 3:13 PM
Thanks for the tips! Beer
Gary
"All you mugs need to get busy building, and post pics!"
    June 2014
Posted by BrandonK on Saturday, December 20, 2014 2:19 PM
Decals are going down. I am about 75% done with them. Then a pin wash and final assembly. This one is really coming out great. Very happy with this kit all the way around. More pics once it's complete in a few days.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    April 2013
Posted by Greatmaker on Sunday, December 28, 2014 12:46 PM
I just starts this monster this morning.  First impressions of this kit are I picked a bad week to give up drinking.  Did you use superglue to attach all the photoetch parts? I just couldn't get them to stick so I tried some Elmers glue to tack them in place and when that dried I re-enforced with superglue.  It seems the instructions on this kit are pretty vague especially in the cockpit construction.  Did you find any better instructions for this kit?  Thank You
    June 2014
Posted by BrandonK on Sunday, December 28, 2014 2:42 PM
Greatmaker
I used think CA glue and accelerator for the antenna wire and the radar antenna. Once I had the basic shapes built for the array I built a small platform to set at the nose of the plane and used it to rest the array on at just the perfect height so I could attach it to the support piece that went on first. Then, once all pieces were aligned to my satisfaction I put CA glue at the joints and hit them with some accelerator to speed up the curing time. It worked very well and the array is pretty secure, if not terribly delicate. Hope this helps.
As far as instructions, I felt they were a bit vague as well but I test fit and trialed all of them as I went and looked ahead in the instructions to make sure nothing was going to give me problems as I worked along. The kit went together very well and was a pleasure to build. Except for the small bits I kept breaking off near the end other build, but that's just me bumbling along. Good luck. Big Smile
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2014
Posted by BrandonK on Sunday, December 28, 2014 2:46 PM
Well boys and girls, I'm calling this one done. The fine details and small parts on this kit will drive a sober man to drinking. It seems over the last few sessions I had at the bench were bathed in hatred. Every time I would touch the kit I would break off something and spend hours getting it back in place. This is one delicate kit to say the least.
It went together well enough but be warned, the small pieces are numerous and just looking for a reason to get knocked off. This is a tricky kit to handle once all the fiddly bits are added. I even kept the photos at the end to a bare minimum to avoid breaking it for the millionth time. It sets on the shelf where I am scared to death to even look at it cross eyed for fear of something falling off. Whew, its done.
All in all its a good kit and fit was great. I really had no assembly issues at all. The only hard part really was doing the front radar antenna. That was tough. But superglue and some accelerator, a stack of objects to rest the whole thing on while I worked and a great deal of patience made it come together. And that radar assembly is small and very, very, very delicate and bends SOOOO easy its just nuts.
Since I really was unable to find any photos of aircraft that were dirty or heavily weathered I kept it simple and did a simple oil wash for the small details and added some soot for the exhaust stains. Dirtied up the flaps a bit and sealed it all in with MM clear flat. I am especially happy with the paint on this one as it came out great and was my first attempt at mottling.  I hope I have covered enough but if not just ask. Thanks for looking.
I don't know why the photos are rotating. They were not taken that way and don't show up in my photobucket like that. Stupid internet. Bang Head
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    April 2013
Posted by Greatmaker on Sunday, December 28, 2014 4:26 PM
Wow amazing job If mine turns out even a 1/3 as good as yours I'll be happy
cb1
    December 2009
Posted by cb1 on Sunday, December 28, 2014 4:50 PM
bloody awesome!
    March 2012
Posted by mustang1989 on Monday, December 29, 2014 5:22 AM
Way to go! That mottle pattern looks sharp Brandon! I'm the same way with my builds. Once they are built they remain untouched for the most part. How folks transport these things to model shows I'll never know.
 Forum | Modelers Social Club Forum (proboards.com)
    April 2013
Posted by Greatmaker on Wednesday, January 14, 2015 9:14 PM
Ugh I'm on the bitter dregs of the process.. In the two years of putting together 43 planes. This one had many firsts. First one with so many PE parts. First one I had to use a vice grip on to get the fuselage halfs.  It was like the cockpit was too wide for the body. I put the canopy on tonight.  Definitely would recommend putting it together on the plane and painting it on there.  I always paint the canopy first then put it on, but even with test fitting the canopy supports were too high.  Made the canopy about 2mm from seating on the fuselage.  Did some fast trimming but I must admit this is the worst looking canopy I've done.  Started on the radar array. That should give me a few more gray hairs. Looking forward to putting this one behind me
    April 2006
Posted by waynec on Wednesday, January 14, 2015 9:29 PM
SWEET!!!!!!!!
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by Texgunner on Wednesday, January 14, 2015 10:59 PM
Geez Brandon, she looks great man!   Your paint work is first class, really well done. Bow Down
Gary
    June 2014
Posted by BrandonK on Thursday, January 15, 2015 9:09 AM
Greatmaker
I built up the canopy before I attached it to the plane, it just was easier to deal with that way for me.  The support struts are a bit tall and I had to file them down just a tad to get the canopy to sit down. But, other than that I really had no problems with this kit. It was nice and the fit was quite good. I may build their other versions as well. Keep at it, it's worth it.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2014
Posted by BrandonK on Thursday, January 15, 2015 9:11 AM
Gentlemen, thank you all for the kind words on my build. They are appreciated. We all know that some of these kits really test our patience. Fortunately this one was a gem to build. Thanks Again,
Brandon
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2013
Posted by bvallot on Thursday, January 15, 2015 4:25 PM
That's come out real nice Brandon.  I've been following along several GB right now but unfortunately I haven't been able to partake just yet.  I have an Fw 190A6 that was a night fighter planned...I just need to get this Hawk off my desk.  =D lol.
Real glad to see all of this come together.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    March 2005
Posted by Devil Dawg on Thursday, January 15, 2015 10:19 PM
Great job, Brandon! Always liked the looks of the Hornet.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    April 2013
Posted by Greatmaker on Friday, January 16, 2015 4:33 PM
Interestingly enough.  I didn't have near as much trouble with the radar as I figured. The canopy was what gave me the most fits. I even had little trouble with the spiral prop decals. Those usually cause some creative cursing so that's a first for me as well Brandon if you don't mind how did you do your antenna wires. Like the rest of the plane it looks fantastic
    June 2014
Posted by BrandonK on Friday, January 16, 2015 6:56 PM
I use fine fishing line, clear, and then a permanent marker to make them black. I attach them with CA and an accelerator.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2012
Posted by lawdog114 on Friday, January 16, 2015 7:29 PM
Gorgeous Brandon.  Thanks for taking us with you on the build.
Joe
Posted by jeaton01 on Friday, January 16, 2015 10:42 PM
Very nice, Brandon.
John
    June 2014
Posted by BrandonK on Friday, January 16, 2015 11:04 PM
Thanks guys, I really enjoyed this kit and it turned out pretty decent.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    August 2013
Posted by Jay Jay on Saturday, January 17, 2015 7:39 AM
Fine, fine job Brandon.
BTW I used your fishing line antenae wire idea for my latest build and it came out great.  Thanks for the tip.  I moved to Florida and now I have a use for that ice fishing line I just happened to keep.
