Academy 1-32 Sopwith CAMEL --WIP-- FINISHED 4-29-17
    December 2010
Posted by 1943Mike on Thursday, April 13, 2017 6:00 PM
Greg,
I'm taken with the super work you're doing on this kit. I'm very grateful you decided to do a WIP since that benefits all of us who enjoy building aircraft kits.
I do have a question. In my stash I have the Eduard 1/48 Sopwith F.1 Camel. Would you mind being a bit more specific as to the problems you had with this kit? I'd just like to take a note or two and be prepared. Thanks.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
Posted by gregbale on Thursday, April 13, 2017 7:02 PM
Thanks, John and Mike.
Re the Eduard kit, as I understand it, the earliest versions of the kit's issue had an error in the instructions that reversed the interplane strut positions. The result was---and I can testify to this---that although everything looked 'about' right during construction, the geometry was just enough off that things would not go together. Been doing WW1 kits since the '60s---all scales and manufacturers and degrees of fit, from the sublime to the ridiculous---and never had a kit fight me fang and claw like that one did.
I did finally get the wing on---with wire pins, clamps and super-glue---but I had no love for the little beast left, and into a box it went, dwelling there still. (I topped it off by rigging with my first try at EZ-line, which was't too pretty, but thats a whole other story....)
Google somthing like 'Eduard Sopwith Camel problem,' and you can probably find the particulars. Presumably the instructions error was spotted and fixed at some point...but I'm not sure when. (I've actually got 2 or 3 more of the Eduard kits in the stash---maybe someone will do a 'Beat The Troublesome Plastic' group build some day, and we can all test our sanity together!)Propeller
Thanks again for looking in.
Greg
George Lewis:
Posted by Bossman on Saturday, April 15, 2017 12:28 PM
Greg,
That is some seriously fine work !  The pit, the engine, the wing surface fix, and the painting . . . all stellar !
Chris
    March 2015
Posted by Toshi on Sunday, April 16, 2017 2:44 AM
As I have been following this build, it has matured into a masterpiece.  It's absolutely beautiful.
Isn't EZline fantastic.  That's just a great product and they can accommodate you with EZline in scale too!
Ultimately your build is superb!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by gregbale on Sunday, April 16, 2017 9:07 AM
Thanks Chris and Toshi! Your kind words (and patience in following along) are always appreciated.
As to EZ-Line, I love the stuff! So-o-o much easier to work with than anything else I've tried---and I fancy I've tried them all, at one time or another---and especially good for British-built a/c, where its flat profile corresponds to the RAF 'airfoil' flying wires.
My 'first time' challenge with the Camel will be this: since the Part p-e set I'm using has really nice looking 'hardware' for the cable attachments [on the Camel, they seem not to have been the more standard turnbuckles as such], I intend to use them. The 'challenge' will be that they effectively have to be attached to the EZ-Line---at both ends---before the lines can be installed. I don't expect this to be super-difficult (dullard that I probably am), but it will mean I'll have to scope wire lengths fairly carefully, and count on CA to 'grab' (and hold) in a timely fashion.
As the old saying goes, "...if it was easy, then anyone could do it!"
And as Chris says..."Seize the styrene!" Thanks again for the support.
Greg
George Lewis:
    November 2016
Posted by Gerhard on Sunday, April 16, 2017 9:39 AM
Outstanding work!!!!!
    May 2013
Posted by Greg on Sunday, April 16, 2017 9:57 AM
Great work and thanks for sharing this WIP, Greg.
Enjoying following along.
Posted by gregbale on Friday, April 28, 2017 4:12 PM
Thanks, Gerhard and Greg! (Sorry for the slow acknowledgment, but I haven't checked back for a while.)
FUN WITH RIGGING
No updates for a bit, but rigging and final finishing are complete, and my pretty bird is now lacking only wheels and a prop. Pictures soon, I hope.
Rigging was interesting. I usually do the 'traditional' version of EZ-Line: drilling half-depth holes to mount a given line, then an all-the-way-through hole at the opposite attachment point. Some kind of tubing sections threaded onto the EZ-Line for 'turnbuckles,' then thread the line through the all-the-way-through hole and stretch to the desired degree of tautness, glue with CA, and trim off the line end. Usually a tiny dab of paint is all that's needed to touch up the latter hole.
This one was a bit different. First, the Sopwith Camel---at least some models, in the mid-to-late production runs (as best I've been able to puzzle out)---had mounting brackets for the landing and flying wires that were a bit different from the regular-appearance 'turnbuckles.' As it happened, the Part p-e set I'm using did quite nice versions of these brackets...though in their 'standard' fashion, a bit fussier---and with more parts---than need be. The photo below (with a shiny Mr. Roosevelt for scale) shows these brackets---the 'double' rectangular bits---and the little 'spike' parts that are the separate [why???] pieces for the wing anchors.
[FAIR WARNING: much tedious description follows!]
Note the photo shows that the parts actually have holes for tiny 'bolts' to hold them together. I actually did up a few of these, as a 'test'---using stretched sprue lengths 'heat shrunk' for bolt heads---before determining that there really seemed no point, since they were barely visible. The rest I just super-glued together.
So for each line, I'd glue a 'spike' piece to the 'back half' of the bracket...then CA a strand of EZ-Line to that...then add the 'front half' bracket to sandwich the line end, with a last tiny dab of CA to insure everything held together. It actually went pretty quickly. (I actually 'folded' the double bracket around the glued-on line for the single landing wires, and used two 'doubles,' front and back, for the double flying wires. Photo above shows a completed 'double' at lower center.)
Once the top wing was solidly on and I could caliper the lengths necessary for the various lines, I trimed the EZ-Line runs to length. (I chose 2/3 the 'gap length' as about the right length for the EZ-Line itself. This allowed for enough stretch to make everything nice and taut...but left enough thickness to resemble the fairly-visible RAF-style flying wires.) With lines trimmed I attached the 'other end' brackets and spikes---more CA---and all was ready to install.
Much to even my own surprise, it went more smoothly that any biblane I've ever rigged before. The little 'spikes' actually provided a pretty 'grabby' end to fit to the wing, and allowed for a bit of bending to get the angles right once the lines were in place. I had carefully pre-drilled tiny holes for the spikes at the proper locations---and was sure to keep them as free of paint as possible---then fitted each bracket to its location with a mini-drop of CA and my essential needle-nosed cross-lock tweezers. Once all the 'lowers' were done, I flipped it onto its top wing, and attached the 'top' ends. Here I'd CA the spike/bracket into its hole---and clamp off the line with a little bit of 'slack' in it, until the CA set---then remove the clamp. I only had 2 lines that 'sprang' and had to be reattached---pretty much a 'given' now and then using tiny amounts of CA, that sometmes 'set' on the part itself before they can grab.
The wing rigging itself (once the lines were made up) only took slightly over a half hour. I think that's a new record for me, even compared to the normally-pretty-quick white-gluing strands of stretched sprue!
That's it for now. Next post should have pictures of 'TIKI' in her completed glory---if I can manage not to accidentally nose-dive her off the work table. [Given past experiences, that's not said entirely in jest....] Thanks to all for following along.
Greg
George Lewis:
    March 2015
Posted by Toshi on Friday, April 28, 2017 4:21 PM
Nice detailed work!  Looking forward to more.
Toshi
Posted by gregbale on Friday, April 28, 2017 4:45 PM
Thanks, Toshi! I've really enjoyed the build...but it's nice getting close to the finish-line.
Greg
George Lewis:
Posted by gregbale on Saturday, April 29, 2017 3:21 PM
Despite the restive reflex to keep picking, poking and tweaking, I'm calling this one...DONE.
New-Zealand-born Harold F. 'Kiwi' Beamish served with No. 3 Naval Sq. RNAS (later No. 203 Sq. RAF) on the Western Front. He was an 11-victory ace who amassed 542 combat flying hours (355 in the Sopwith Camel) and was awarded the Distinguished Service Cross. Capt. Beamish survived the Great War to return to his beloved New Zealand, where he worked as a sheep farmer as had his father before him. New Zealand's last surviving WW1 fighter pilot, he passed away in 1986, at the age of 90.
His Sopwith Camel F.1 N6377, named 'Tiki,' was his mount for four of his aerial victories during the summer and autumn of 1917. His personal insignia, the golden fern leaf symbolic of New Zealand, was actually salvaged from the crashed 'Tiki' before he left the front, and returned with him to be prominently displayed on the wall of his New Zealand home.
I had great fun with this build. Thanks to all who took the trouble to  look in or follow along.
Greg
George Lewis:
    January 2015
Posted by Aggieman on Saturday, April 29, 2017 9:11 PM
Fantastic work.
I have that WNW kit on my wish list, having already failed in efforts to complete this kit that you did such magnificent work on and Eduard's far more diminutive 1/48 Camel. I can only hope that when I get the WNW Camel, mine will turn out half as decent as yours.
Posted by gregbale on Sunday, April 30, 2017 9:33 AM
Thanks, Aggieman! I have one more Academy Camel kit, I think two more of the Eduard (and maybe one of the old Revell issues) in 1/48, and a handful in 1/72. If I was logical and reasonable, I'd do at least some of those before ordering a WNW kit...but you know how that goes....
Greg
George Lewis:
    December 2015
Posted by templar1099 on Sunday, April 30, 2017 9:54 AM
Absolutely beautiful.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    May 2015
Posted by Griffin25 on Sunday, April 30, 2017 10:08 AM
Holy Cow, that's nice.
Griffin
    August 2013
Posted by Jay Jay on Sunday, April 30, 2017 12:58 PM
Fabulous build and wonderful history included. Thank you so much for posting this inspirational W.I.P.
Posted by Bossman on Sunday, April 30, 2017 1:01 PM
A very fine build - and a very attractive one at that !
Super job Greg.
Chris
Posted by gregbale on Tuesday, May 2, 2017 12:31 PM
Thanks, guys! I appreciate the good thoughts.
Greg
George Lewis:
    June 2014
Posted by BrandonK on Tuesday, May 2, 2017 12:33 PM
Awesome work. That turned out very nice indeed. Impressive!
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    December 2010
Posted by 1943Mike on Tuesday, May 2, 2017 11:46 PM
Lovely build - great paint job - terrific rigging!
(I've just got to get back to my stringbag soon - love those bipes!)
Hector Berlioz
Posted by gregbale on Wednesday, May 3, 2017 6:29 AM
Thanks, Brandon and Mike.
1943Mike
One distinct advantage of the p-e rigging brackets (particularly on the double lines) was that they helped keep the EZ-Line from twisting---always a challenge with aging eyesight. These stayed pretty straight.
Looking forward to seeing your own project completed!
Cheers
Greg
George Lewis:
Posted by Bish on Wednesday, May 3, 2017 6:34 AM
That is completly stunning. Inside and out there is some amazing detail.
Great build all round.
Posted by gregbale on Wednesday, May 3, 2017 6:40 AM
Thanks Bish!
Despite the underwhelming kit, it grew into a labor of love. (The old Revell 1/28 Camel was literally the first WW1 a/c I ever built---so I had the 'nostalgia' thing going,as well!)
Greg
George Lewis:
