WIP 1/48 AMT A-20J Havoc COMPLETE! (Updated) Tarmac Base Added
    December 2013
Posted by route62 on Sunday, June 25, 2017 9:35 PM
A few more...
    January 2015
Posted by PFJN on Sunday, June 25, 2017 9:40 PM
That looks exceptional Smile
1st Group BuildSP
    March 2009
Posted by wolfhammer1 on Sunday, June 25, 2017 10:37 PM
Outstanding work sir!  Thanks for sharing.
John
    August 2013
Posted by Jay Jay on Monday, June 26, 2017 9:25 AM
Ditto on the outstanding work Mate.  Are you entering it in the IPMS Orlando show, I'd love to see thiis in person ?
    December 2013
Posted by route62 on Monday, June 26, 2017 12:36 PM
Thanks again for the encouragement.  Jay Jay, yes I do plan to enter this one at modelpalooza this year along with a few others.  Look forward to seeing you there.
    March 2015
Posted by Toshi on Tuesday, June 27, 2017 7:55 AM
route62
This is just superb!  And good luck to you at the modelpalooza!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    December 2013
Posted by route62 on Wednesday, June 28, 2017 9:51 PM
I really enjoyed this one.  Only issue was the fuselage was warped and twisted the tail.  I cut the tail off and reattached it inline. She started as a free kit that was half started. I added some etch, resin, scratch and extra decals.  I may build a small base to place her on for the show coming in September. Click pics to enlarge
Please critique.  Suggestions and advise are welcome.  Its the only way I will improve.
    November 2008
Posted by mrmike on Wednesday, June 28, 2017 10:02 PM
The nose glazing looks thick, couldn't you have thinned it a bit to scale? Kidding of course!
What a great build of a venerable kit & subject - please post pics of the model and base.
    July 2004
Posted by stikpusher on Wednesday, June 28, 2017 10:59 PM
That looks REALLY GOOD!!! If I have to critique anything, your interior green color is a bit too bright for my taste, but that's about it. The build, paint work, and weathering all look "just right".
And perhaps a little more weathering on the tire sidewalls to match the tread area.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2013
Posted by route62 on Wednesday, June 28, 2017 11:07 PM
I took pics with and without flash to capture different details.  The pics with flash make the interior green real bright and the tire weathering on the treads stand out.  In person the green is not that bright and the tread weathering is not that intense.
I took these pics with my cell as my light box is at work.  I will take better pics in the light box.  Thanks for taking a look!
    November 2016
Posted by StephenL on Wednesday, June 28, 2017 11:19 PM
Looks fantastic! I enjoyed following along.
200 kits was my limit...
    December 2013
Posted by route62 on Wednesday, June 28, 2017 11:27 PM
I was not sure what color if any the antenna wire would be on these aircraft.  Right now it is just the bare wire.  Any input is appreciated.
    July 2004
Posted by stikpusher on Wednesday, June 28, 2017 11:53 PM
Most long wire antennas that I came across during my time in the Army were bare metal. Based off that, I'd say stay with bare metal.
Regarding your photos, the flash enhancing those two things I mentioned makes perfect sense.
       - Plankton
LSM
    September 2011
Posted by falconmod on Thursday, June 29, 2017 7:38 AM
How did you do your weathering/chipping  on the props and cowl?
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    November 2003
Posted by tempestjohnny on Thursday, June 29, 2017 8:02 AM
Really well done.
    December 2013
Posted by route62 on Thursday, June 29, 2017 9:10 AM
falconmod
John
Thanks for asking.  Once the model was decaled and another coat of gloss clear was applied,
first I did a basic sludge wash using burnt umber oil paint.  I thin the oil paint way down till it is almost as thin as the thinner.  Using a flat brush I will apply the wash working in sections.  I do not do the whole model at once.  I let the section dry, in this case wing/cowl/prop, for 10-15 min.  Then I take a piece of paper towel put a few drops of thinner on it just enough to wet it without soaking.  I then lightly wipe away as much of the wash in the direction of air flow of flight.  Any hard to reach corners etc I will wet a cotton swab with thinner, dab most of thinner out of the swab and wipe away the sludge wash.
This will leave wash in the panel lines and add streaks as well as tone down any bright colors like the invasion stripes and yellow prop tips. If needed I will repeat depending on the effect I am going for.  I will then go back with a pointed brush and using the pin wash method add wash to any panel lines that the sludge wash did not fill or I wiped away.  Again wait to dry and wipe away any extra.
for chipping, it is similar to drybrushing.  I used some packing foam, it is the same packing foam that you can see in the wheel wells in some of the earlier WIP pics.  The foam or sponge should have an open pockets as part of its makeup, not the foam that is solid.
I will clamp a piece of this foam into some locking tweezers, dip a corner of the foam in silver paint, dab most of the paint off the foam on a piece of paper and then tap the foam at different angles so not to create a pattern onto the prop and cowl, leaving convincing looking chips.  If there is too much, I can wipe away with thinner and try again.
Once I am happy with the chipping, I will take a small brush and using the same silver paint drybrush highlights here and there along the leading edge of the prop and inside lip of cowl.
If the silver is too bright I can add a little wash again over the chipping to tone it down.
    June 2014
Posted by BrandonK on Thursday, June 29, 2017 9:11 AM
Well done. That is a very nice looking AC. Your weathering is excellent.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Thursday, June 29, 2017 10:17 AM
Oh wow, I liked how my model of this kit came out when I built it but dang now I wish she looked as good as yours!!! Heart
And thanks for the walk-though on how you weathered her.
    June 2017
Posted by Chemteacher on Thursday, June 29, 2017 10:24 AM
Outstanding!
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    January 2015
Posted by Aggieman on Thursday, June 29, 2017 12:04 PM
Your Havoc would wreak havoc upon any modeling contest if I was the judge.  Truly fantastic work, sir!
    December 2013
Posted by route62 on Thursday, June 29, 2017 12:41 PM
Thanks Aggiman.  I will post how it places at the contest this Sep.
    March 2015
Posted by Toshi on Thursday, June 29, 2017 12:47 PM
That's some outstanding work. This is just a superb build!  Beautiful!
Toshi
    August 2013
Posted by Jay Jay on Thursday, June 29, 2017 1:55 PM
Absolutely excellent build and painting/weathering sceme.  I'm anxious to see it and meet you in person at the show Mate. ( and pick your brain in reference to the how-tos )
    September 2016
Posted by ManCityFan on Thursday, June 29, 2017 2:42 PM
Jay Jay
Ditto  Just adding to the many positive comments.  Really well done.  Thanks for sharing.
D
Dwayne or Dman or just D.  All comments are welcome on my builds.
Posted by 7474 on Thursday, June 29, 2017 2:49 PM
Fantastic work, glad you finished it.
    October 2016
Posted by DasBeav on Thursday, June 29, 2017 4:12 PM
Just added to my "favorites" browser....Beautiful work, sir.Bow Down
 Sooner Born...Buckeye Bred.
    December 2013
Posted by route62 on Thursday, June 29, 2017 4:25 PM
Thank you all!  I am getting great feedback from everyone.  I have some clear bench space so onto the next one.  I have started on the monogram F-102 Dagger.  From reading reviews this kit goes together well.  I have started on the rescribing and will post a WIP as soon as I have made some progress. I have never done a gloss finish aircraft so this should be interesting.
    February 2014
Posted by silentbob33 on Thursday, June 29, 2017 4:56 PM
That looks awesome! I'm going to come back to look at this when I get around to mine
On my bench: Academy 1/35 UH-60L Black Hawk
    December 2013
Posted by route62 on Sunday, July 2, 2017 4:23 PM
I used the holiday weekend to make a simple tarmac base for the Havoc.  I have some figures and a tug tractor in my spares.  I think I will make a small scene with the tug pulling a cart of bombs and have a pilot and navigator figure look to be talking  about mission details.
Here is the completed base.  It went fast since it is a simple layout.  Just used stuff I already had.  Took about two evenings to complete.
Posted by Bish on Monday, July 3, 2017 3:03 AM
Nice work on that base, be great tro see the figures with it.
