replacement for photobucket?
    June 2014
Posted by BrandonK on Monday, July 3, 2017 12:29 PM
Not sure what you are doing with Flickr, but it's all I use now. First I click the arrows in the upper right corner of the pic I wish to use. This expands it. I then right click the image, "copy image address", and then paste that into FSM. Your method seems far to complex for what is needed.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    April 2010
Posted by Theuns on Wednesday, July 5, 2017 12:12 AM
I must be really slow as I cant win this damn thing.
I select a pic and click on the arrow indicating share. Then the pix comes up with a highlited blue code on the bottom. Usually on PB I clicked this and it was then coppied. If I do the same on this the blue goes away, the code stays but nothing gets coppied.
I dont get a "BBcode"  or copy image adress prompt.
Will have to look for somthing else it seems
Theuns
    February 2012
Posted by lawdog114 on Wednesday, July 5, 2017 12:26 AM
I understand all good things must end, but $399 a year? A little too rich for my blood. I see they are now holding all my photos ransom now too. No thanks......enjoy holding them, as I have more. I suppose now is as good a time as any to start my own modeling blog.
I'll give Fermis' and Brandon's Flickr tutorial a try. I've downloaded my latest work there. .
    February 2012
Posted by lawdog114 on Wednesday, July 5, 2017 3:34 PM
Theuns
Theuns
It's different than PB. I figured it out (Thank you Fermis).  Do as you did bit when you reach the blue link, paste it to FSM typing field. Make sure BB code is highlighted above the link
Here's were it gets tricky. Find the "http" link embedded in there, between the two [img] then highlight and copy that only. Go to top bar and hit the picture icon and insert as normal. The picture will show up in the FSM field. You'll gave to go back and delete the other words from the link.
Annoying but certainly worth the aggravation to spite Photobucket.
