FineScale Modeler WWI Aeroplane Group Build 2013
    September 2012
Posted by GMorrison on Tuesday, April 16, 2013 3:45 PM
shivinigh
I have been looking through alot of sites and a couple books cause the curtains puzzled me as well but haven't found anything about them. Lots of pictures I have seen show the curtains just not a reason for them. The windows were for view sideways and down cause the Rolland had poor lower visibility due to it's wing design which made landing a hazard.
Well I think the reason is that the side openings were not glazed. The guy could lean out and look down.
So when he wasn't doing that, he'd close the drapes to make the thing less of a wind tunnel inside.
Posted by gregbale on Tuesday, April 16, 2013 7:41 PM
Bish
Also, these some stiching along the sides of the fuselage. It is of course very small, so not sure if i can do anything. But just woundering if this would be the same colour as the rest of the air frame.
Any suggestions appreciated.
Bish:
If the stitching reresents seams where covering panels are put together, then they would have been taped over, doped and painted the same color as the rest of the fuselage. (Same would go for stitching on wing ribs, etc.)
Not familiar enough with the 0/400 to know where the inspection panels were (I presume there were some), but these were usually laced up with distinctive zig-zag or diagonal lacing. That was occasionally painted over as well, but more often a brown or black cord color.
In 1/72, a little drybrushing to highlight the molding would probably be great for either one.
Truly inspiring work on a challenging bird!
Greg
George Lewis:
Posted by Bish on Wednesday, April 17, 2013 12:37 AM
Greg, thansk for the info. I am certain the stitching isn't any inspection panels as there is quite a lot of it along the fuselage sides with one line going front to back. Photos i have found do show somthing but not distinctive stitching. Maybe Airfix just wante to show it for some nice detail.
I think some dry brushing with a very fine brush is in order. Ye, it is a bit of a challenge, but i am enjoying it now.
    April 2006
Posted by jgeratic on Wednesday, April 17, 2013 12:27 PM
Bish -  looking great, I think that build will look very impressive once done.  As far as weathering goes, the wing surface rib detail is where most of the work is.  Subtle approach is best, by creating a slight shadow along the sides of each rib.  Other than that, there is the normal dust and dirt thrown up by prop splash and perhaps the wheels.  I think it would be correct to have some slight chipping on the metal frame work of the engines, along with some oil streaks perhaps.
Regarding the curtains on the Roland, looking at reviews of the Eduard kit., it states the decals represent painted on curtains, and not actual drapes.  I think we are witnessing some WW1 humour here, and they were just that - a crewman's artistry at work.
regards,
Jack
Posted by shivinigh on Wednesday, April 17, 2013 5:58 PM
finished the inner workings and ready to put the fuselage haves together
here the halves, lower wing, rudder and elevators are glued on. The upper is there temporarily to line the wing struts up while the glue dries
now that the body is together I can see why it was called "Walfisch"  Whale. It is pretty fat and rounded.
    February 2006
Posted by ruddratt on Thursday, April 18, 2013 12:44 AM
Bish, I can pretty much only echo what's already been said in regards to weathering, and Jack's idea is a good one in reference to accentuating the rib detail on your aircraft. Highlighting the raised part of the ribs with a shadow effect on each side of the rib really adds a lot of depth. Have to say your build is really coming along nicely - hard to believe it's your first bipe. Good stuff! Yes
shiv, that's some impressive work on the interior of that Roland, and overall it's shaping up into a real stunner! There's just something about the lines on that bird that I find very appealing. Yes
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
Moderator
    September 2011
Posted by Tim Kidwell on Thursday, April 18, 2013 9:04 AM
Shiv and Bish - It's great to see those planes coming along so nicely.
Jack - I like that explanation for the curtains. From the colorful lozenge camo to the interesting markings and sometimes outlandish designs, these aircraft have so much personality. It's similar to the Age of Sail for ships.
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
    April 2005
Posted by wing_nut on Thursday, April 18, 2013 10:05 AM
Guys!  Jeez Louise!  Nice stuff.
Shiv that's some great progress.  Are those really curtains?  For when they are having tea between dogfights?Stick out tongue
Jack nice grimy little motor you got there.
Bish still amazed at your choice for 1st string bag.  But you are doing it justice.  Ditto on the ribs.  Thinned Tamiya smoke and a post-it make quick work of it too. Just keep moving the post-it along the wing.
Marc
    October 2008
Posted by P mitch on Friday, April 19, 2013 3:43 AM
Just a quick update from me. Been busy with life but have done some work on the control cables inside the cockpit which i hope to get finished this weekend. What I have had is a reply form the gentleman making my prop for me, have a look at the photo
There was some discussion between myself and Craig about the colours (I won) and I think it looks great, now I hope I can do it justice
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    October 2010
Posted by Dogfish_7 on Friday, April 19, 2013 5:42 AM
What a difference the shading makes on the wingsBow Down
Bruce
Moderator
    September 2011
Posted by Tim Kidwell on Friday, April 19, 2013 11:57 AM
Fellow aeroplane builders, it seems that I'm alone this week, with no one to operate the video camera. Aaron has spirited off to Atlanta for the AMPS show, thus leaving me in the lurch!
So, here are a couple pics for today.
After three different kinds of tape, some Micro Sol, and some 600-grit sand paper, the decals are off my ailerons, and I'll put some paint on them this weekend and get them back under lozenge.
And then, the turnbuckles arrived! And finally, all will be complete with the cockpit and I can get it closed up ... FINALLY!
I'm sure Aaron is having an awesome time at AMPS. If any of you guys are down there, I hope you are, too.
I apologize for our little hiccup here. We'll be back next week.
Have a great weekend!
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
    October 2008
Posted by P mitch on Friday, April 19, 2013 12:14 PM
Quick update pics on my build. Cockpit is finally together so on to the fuselage in the next few days
A couple more pic on my WIP
Phil
    October 2011
Posted by Chuck Davis on Friday, April 19, 2013 12:20 PM
Wow, guys...yet more great progress.  Marc - I love the shading.  I need to try that.  And Tim - couldn't you hold the camera and talk at the same time?  Kidding...I guess we'll have to wait.
Now folks - a confession.  As of last night (late) I had managed to mess up my pre-painted PE belts that I decided to use.  I decided to test fit my white metal gear struts I just bought to the spreader.  Trouble was...I can't find it!  Very disheartening night - I almost decided to pull off the road and cheer you guys on from the sidelines.  This kit for whatever reason was starting to shape up into "one of those" that kicks you around and laughs each time you get back up.  After a good nights sleep, I think I'll have a go at replacing the part.  Should be relatively straight forward.  Picture a metal cannula to hold the axles wrapped in airfoil shaped plastic - sort of a plastic burrito.  OR - my work is looking at getting a 3D printer (Makerbot), and it would take all of 5 minutes to create a 3D file and print it in my office.  First the slacker that needs to write the justification - me - needs to get off his rear, though.
So how about it folks...should I make one old school, or "cheat" and do a printed part?
Have a great weekend everyone!
Chuck Davis
Moderator
    September 2011
Posted by Tim Kidwell on Friday, April 19, 2013 1:38 PM
Chuck, hang in there! Can you use the kit's parts as a starting point, or are they beyond hope?
For me, I think it would be kinda neat to see a part made on a Makerbot in a build, but I also understand the value of making a part from scratch. So, my vote is yes and yes!
Hmmm, not helpful.
OK, if you can use the Makerbot without getting in trouble, and it'll still give you enough time to finish the build, do it. If not, then go the scratchbuilt route.
Either way, positive thoughts, man.
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
Posted by Gamera on Friday, April 19, 2013 1:45 PM
Great stuff guys! Great stuff!
Chuck: Scratch-build the missing part and it will magically reappear! Always happens to me... Bang Head
    September 2011
Posted by falconmod on Friday, April 19, 2013 1:50 PM
Gamera:  you must be touched with a bit of magic,  I had to scratch build the joy stick on the Albatros and the old one never showed up?  I don't win at lotteries either!
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    October 2011
Posted by Chuck Davis on Friday, April 19, 2013 1:53 PM
Strange...I found an Albatros joystick that showed up out of nowhere.  Hmmm...
Chuck Davis
    September 2011
Posted by falconmod on Friday, April 19, 2013 1:56 PM
Ooooooo...Surprise   that's wierd!  I must be in the twilight zone!   And I mean "Rod Serling" not that other crap!
Posted by Gamera on Friday, April 19, 2013 2:03 PM
Lol... the more time I spend scratch-building a new part the larger the chance the old one will show up when I finish it - or something like that!
Plus if you seal up the model the missing part that goes inside will magically appear too!
My best way to find missing parts is when I hear a loud *CRACK* I peel the broken part off the bottom of my shoe....
    September 2011
Posted by falconmod on Friday, April 19, 2013 2:07 PM
O man when that happens I just cry!Crying
    October 2011
Posted by Chuck Davis on Friday, April 19, 2013 2:23 PM
Gamera
HAH!  You're so right.  I've found rolling desk chairs to be another excellent "part finder."
Chuck Davis
    September 2005
Posted by freem on Friday, April 19, 2013 2:49 PM
Tim
No entertainment for this weekend--shucks! Nice looking buckles too but you see why my E-IV is in 1/72 scale because I can't afford the quarter to size my plane up. ; )
Chris Christenson
    September 2005
Posted by freem on Friday, April 19, 2013 2:54 PM
Chuck, have hope! A feline raiding party (must have been British cats) raided my Fokker factory (aka my model bench) and knocked the joystick, fuel tank and fuselage on the floor.  Found em all!
freem
Chris Christenson
    October 2011
Posted by Chuck Davis on Friday, April 19, 2013 3:02 PM
freem
freem
Thanks for the words of encouragement.  I'm still hopeful.  What's frustrating is this would be the second time in recent history I've lost major components to a kit.  Ironically, the most recent was the landing gear struts from a WnW Pfalz.  Maybe I should start looking into What-If versions of WW1 kites with retractable gear?...Stick out tongue
Chuck Davis
Posted by gregbale on Friday, April 19, 2013 3:43 PM
Gamera
You forgot one.
If you scratchbuild some tiny, complicated fixture or mechanism, and it comes out perfect --- it will be just barely too large to use. When you do it again, and get the size dead-on, you will never again faintly approach that initial level of perfection.
Wing_nut    Thanks for posting the pics of your rib shading treatment, particularly the "before and after." Very useful (and inspiring).
Phil   Beauuuutiful propeller. And that 'pit is magnificent.
Tim   Always sucks to be the guy left behind to man the battlements. Enjoy the turnbuckles.
Chuck  Truly heatfelt sympathy for your difficulties. Please do hang in there--it's only styrene. (And I'm wth Tim--the MakerBot thing sounds really cool.
Got a bit of interior done on the Baby. The kit supplied a full suite of PE, but a lot of it seemed to call for "building up" to a more 3-D look with added bits of sheet and rod. (Still at the test-fitting stage, no control cables, throttles or stuff yet.) Scratchbuilt the seat and instrument panel for fun.
Have an excellent weekend one and all.
Greg
George Lewis:
    April 2005
Posted by wing_nut on Friday, April 19, 2013 6:27 PM
Sorry about your belt trouble CD.  If you want the PE belts,  you were kind enough to send to me , back... I just found mineWhistling
Marc
Posted by jeaton01 on Friday, April 19, 2013 10:24 PM
Chuck, it's right there, to your left...I know it is!  My favorite way of losing things is to have them right there in plain sight, I'm looking right at it, and I still don't see it.  Bad attitude, most likely.
Greg, the seat looks well worn, realistic.  I think my leather could use some aging after looking at yours.  I think you may have done double work on your rigging, there is usually only one turnbarrel on any single run of rigging and it looks like you have two.  But they look very convincing to me.
I have accomplished absolutely nothing this week.  I'm building a new deck/porch on the back of my house.  Concrete, paint and redwood are the order of the day but I think this weekend I will face the rigging on my DH9a fuselage.  I think I have decided how I want to go about it.
John
Posted by Gamera on Friday, April 19, 2013 10:41 PM
Greg: Love what you've got going there, esp the netting on the seat.
As to missing parts I've got to share the story of the 1/35th MP figure I dropped while airbrushing a layer of matte finish on him in the basement and his head shot off. I searched for hours for it until I decided to do some cleaning and found it in a box of airbrush parts with a crack in the top about a cm wide. How on earth it bounced off the floor and though a gap barely wider than it I have no friggin' idea. Larry Bird couldn't have made a shot like that....
    April 2005
Posted by wing_nut on Saturday, April 20, 2013 3:26 PM
Good news biz is great right now and making some bank. Bad news is bloody tired at the end of the day and it is sorely affecting bench time. But I did manage to get some... finally.
Some more cockpit work done, finally got the belts made and installed. I was also waiting for the little spark plugs to be delivered to install in the cylinders. These are little gems from RB Motion. they sell car model details. these are the smallest plugs they make at 1/24 scale. But with the cylinders drilled out a little so they sit a touch deeper they look great.
Marc
Posted by shivinigh on Saturday, April 20, 2013 7:10 PM
almost ready for the rigging. As this is the first time I have done a WW 1 craft I was wondering what size if wire I should use for a 1/48. I was going to use .005 wire.
