The Race Into Space GB, October 2018 - July 2019 (Ended)
    July 2014
Posted by Bakster on Saturday, March 2, 2019 2:51 PM
I stained and clear coated the base. I feel so so about it. I must have got wood glue on some of the frame because the stain wouldn't take to certain areas. Another lesson learned. But--I am moving on.
I coated the interior of the frame with wood glue so as to seal the wood from the water putty I'll be using. My concern being that the water will warp the wood. The glue I am using claims that it is waterproof, we shall will see.
Also worked on:
1. I painted the hatch gasket.
2. I am experimenting with crackle paint for the desert lake bed.
Tomorrow, I will start with decals.
Posted by Gamera on Saturday, March 2, 2019 5:33 PM
Bakster: Well, you can always make a second base and hold on to this one in case it doesn't work out. I've been using the wooden plaques from the art store, I make a half-dozen or so at a time.
GAF
    June 2012
Posted by GAF on Saturday, March 2, 2019 7:45 PM
Bakster> It looks pretty good to me.  I understand it's going to be a dry lake bed so I'm sure a few rough spots are not going to be a problem.  You might try putting tape or something around the outside of the frame to help hold it in place before applying the putty.
Gary
GAF
    June 2012
Posted by GAF on Saturday, March 2, 2019 7:46 PM
At last!  A movie I might want to go to the theater to see!  Well, a documentary anyway...
    July 2014
Posted by Bakster on Saturday, March 2, 2019 8:56 PM
Gam, I thought of doing it over too. I have another frame that I could use right out of the gate. But, it’s a lot of dang work to start over. It was a ton of sanding with these frames, add making the mitered forms, and all the rest. It was over a weeks work for me with working a little bit every day. For the one splotchy area, I can’t justify it. We well see how the water putty goes. If bad luck strikes, I might be forced to do it over.
    July 2014
Posted by Bakster on Saturday, March 2, 2019 9:03 PM
GAF
I plan to tape the frame protecting it from the putty mixture whilst pouring and leveling, then pull it up before it sets. It will be a mess. Not sure how this will go with not having done it before but I found a build where someone has. I am sort of following their lead. Fingers crossed. I will probably pour it this week.
    July 2014
Posted by Bakster on Saturday, March 2, 2019 9:11 PM
GAF
That looks really good, Gary. I want to see this.
    July 2014
Posted by Bakster on Saturday, March 2, 2019 9:18 PM
Bakster
It just occurred to me that I could paint a solid color over the frame. Maybe a black? Or a brown? Then put a clear over it? Would that make it worse? Not sure.
GAF
    June 2012
Posted by GAF on Saturday, March 2, 2019 11:14 PM
Bakster>  Well, paint can cover a host of errors, so painting the frame might be an option if the spots are too noticeable.  See what you think after pouring the putty.
Project Report:
I've gotten the LM pretty well along.  I gave a touch-up spray of white to the upper stage, then masked both lower and upper stages to finish up the black thermal areas.  I'm detailing the antenna on the LM and the hi gain antenna for the Service Module.  Those should be done tomorrow.  I'm also painting the legs silver, though the idea of covering them with aluminum foil is still being debated.  Depends on how the silver paint looks.  Notice I'm having to paint the legs in sections as I don't want to leave finger prints.  Also, the LM "porch" has been glued on along with the descent nozzle.
The LM and SM are getting close to being ready for the RCS nozzles to be glued on.  The Instrument Unit is still awaiting some connection panels.
One thing about the Service Module.  I've found that there was only one SM that was painted "white" for a flight.  That was Apollo 6 which used the Service Module from Apollo 1.  The rest were left unpainted, except for the radiator panels, which explains that metallic gray color that stands out from the rest of the Saturn rockets.
That's it for now.
Mission Director (GAF)
Today in Space History:
1968 March 2 - . 18:29 GMT - . Launch Site: Baikonur. Launch Complex: Baikonur LC81/23. LV Family: Proton. Launch Vehicle: Proton-K/D.
  • Zond 4 - . Payload: Soyuz 7K-L1 s/n 6L. Mass: 5,390 kg (11,880 lb). Nation: Russia. Agency: MOM. Program: Lunar L1. Class: Manned. Type: Manned spacecraft. Spacecraft Bus: Soyuz. Spacecraft: Soyuz 7K-L1 . Duration: 5.22 days. Decay Date: 1968-03-09 . USAF Sat Cat: 3134 . COSPAR: 1968-013A. Apogee: 400,000 km (240,000 mi). Perigee: 191 km (118 mi). Inclination: 51.6000 deg. Period: 15,561.71 min.
  • What at first seemed to be a success, very much needed by the L1 program, ended in failure. The Proton booster lifted off in 18 m/s winds, -3 deg C temperatures, and into very low clouds - it disappeared from view at only 150 m altitude. Aircraft at 9, 10, and 11 km altitude reported the cloud deck topped 8300 m, with 1.5 to 2.0 km visibility. The spacecraft was successfully launched into a 330,000 km apogee orbit 180 degrees away from the moon. On reentry, the guidance system failed, and the planned double skip maneuver to bring the descent module to a landing in the Soviet Union was not possible. Ustinov had ordered the self-destruct package to be armed and the capsule blew up 12 km above the Gulf of Guinea. Kamanin disagreed strongly with this decision; the spacecraft could have still been recovered in the secondary area by Soviet naval vessels after a 20 G reentry. The decision was made to recover the spacecraft in the future whenever possible.
  • Officially: Solar Orbit (Heliocentric). Study of remote regions of circumterrestrial space, development of new on-board systems and units of space stations.
2019 March 2 - Launch of Falcon 9 rocket with Dragon capsule (unmanned) at 2:49 a.m. EST (0549 GMT) from the Kennedy Space Center.  Demo-1 to rendezvous with ISS Sunday, March 3 at about 6 a.m. EST (11 a.m. GMT).
    July 2014
Posted by Bakster on Sunday, March 3, 2019 8:54 AM
GAF
That sounds like sound advice.
That is such a cool model, Gary. I showed your project to my brother and his comment was, "Oh man, that is cool. That is the one I'd like to get."  He remembered the kit whilst growing up, seeing the kit, and wanting it. I agree.
That is interesting about the service module panel. I remember seeing that.
GAF
    June 2012
Posted by GAF on Sunday, March 3, 2019 10:16 AM
Bakster> I think the base will turn out fine.  I have confidence in your ability to bring her down safe.  Big Smile
The Apollo model is nice.  If you look for one on E-Bay, be prepared to pay close to or over $100.
https://www.ebay.com/itm/RARE-Revell-1-48-Scale-Apollo-Lunar-Spacecraft-Over-20-High-Bagged/123644589931?epid=1203638027&hash=item1cc9cab76b:g:fZ4AAOSwHOtcZJRT:rk:15:pf:0
I checked on prices before the GB started and realized that if I were going to complete it I would have to scratch-build some major parts.  I've managed to cobble things together, but even so I'm missing some of the internals on the Service Module.  Nothing that will be noticed, but would be nice to have.  Odd, as I'm sure I had two of these things at one time, and extra CM/SM sets from other kits.
Still, I'm hopeful that Revell will release a new boxing of this and other kits this year in time for the moon-landing anniversary.
Gary
    July 2014
Posted by modelcrazy on Sunday, March 3, 2019 11:34 AM
Gary, your SM amd LM are really looking good.
Steve
    July 2014
Posted by Bakster on Sunday, March 3, 2019 4:00 PM
Well, I have 1 side of the X-1 decaled, sort of.
I am beginning to think the same demon that menaced the test pilots is trying to sabotage my X-1 build. Disaster struck with my very first decal, the tail number. The decal stuck down so fast I had no time to position it. I tried working more fluid underneath it and this eventually led to the decal folding over onto itself. I tried soaking it in water and working it apart, and no dang way. These are the most unforgiving decals I have ever worked with. I nearly messed up the emblem too. I think I have figured out how to deal with these now, but man--don't make a mistake. Or you are screwed. Once they stick to themself, forget about it.
So... now what. I tried looking for aftermarket decals and I didn't have any luck. I found some, but not 1:48 scale. Admittedly, I am not the best at searching for stuff like this. I might resort to using another decal set included with the sheet. It has the same tail number, just a different font for a different flight. I hate to go that route, but I am not sure how else to proceed. The other option is that I have one good decal that could be scanned onto decal film. I don't have a good printer, nor the necessary stuff and experience. I am not willing to invest the time and expence for 1 decal.
Any suggestions are welcome.
GAF
    June 2012
Posted by GAF on Sunday, March 3, 2019 4:32 PM
Bakster> Bummer about the decal!  If you don't come up with something soon, I have to make some decals for the Apollo model and running off a set of tail numbers shouldn't be a problem.  I can't guarantee how well they would work, but they would be free!
Only thing is, I don't know what they would look like and what size they need to be.  You would need to get a really good photo of your last decal and kinda give me a height measurement as precisely as you can (unless I can find the information online).
Perhaps someone else has a set, or another solution.  Might delay your completion by a couple of weeks or three, however.
Gary
    July 2014
Posted by Bakster on Sunday, March 3, 2019 4:37 PM
Hey Gary-- I could mail you the remaining decal. Then you could scan it, or whatever you'd need to do. I appreciate your offer and I might take you up on it. Let's see if another solution presents itself and go from there.
Thanks! Yes
GAF
    June 2012
Posted by GAF on Sunday, March 3, 2019 4:46 PM
You're welcome!  Since they are standard military style letters, I wonder if there might be another set somewhere you could cobble the numbers together from.  Never can tell.
If all else fails, I'll certainly give printing a set a try.
Gary
PS> She's looking good, nonetheless!
    July 2014
Posted by Bakster on Sunday, March 3, 2019 5:23 PM
GAF
THAT--is a brilliant thought. I will research it.
Hey--another question. I am tempted to go over the decals with Microsol. What is your experience with using it? Any concerns?
GAF
    June 2012
Posted by GAF on Sunday, March 3, 2019 5:36 PM
Bakster
None that I know of.  I've used Microsol successfully many times.  It has wrinkled the decals on application, but they've always flattened out.  You may have to do more than one application.
    July 2014
Posted by modelcrazy on Sunday, March 3, 2019 7:04 PM
Oh, sorry about the decal issue. It sucks when 1 decal holds you up. Microsol works great for me however it just won't effect some manufactures. The thinner the better. It sounds like looking for some generic decals may be your ticket.
Steve
    July 2014
Posted by Bakster on Sunday, March 3, 2019 9:14 PM
Thanks guys about the Microsol, and the decals. I will see if I can find something close to what I had before I go the printing method.
Yes
Posted by Gamera on Sunday, March 3, 2019 9:19 PM
Bakster: Sorry to hear about your decal woes. Yeah, Micro/Super Scale Sol and Set are wonderful- I use them for pretty much all my decals. If you can't find a set of aircraft numbers to use you might check the train side of the hobby shop, they make numbers for locomotives and rolling stock that will work too.
Gary: You're making great progress!!!
    July 2014
Posted by Bakster on Sunday, March 3, 2019 9:38 PM
Gamera
Thanks Gam.
    July 2014
Posted by Bakster on Sunday, March 3, 2019 9:43 PM
For reference-- here is a comparison of the two styles that come with this kit.
I need the bottom right.
The other goes with this variant.
    July 2014
Posted by Bakster on Sunday, March 3, 2019 10:17 PM
Here is something that "might" work. Hard to know the size of the characters though. Once to the site you'll have to click on the second image. Kind of pricey, and not know if it will work.
A funny thing. During my search I found a build where they had a similar problem, for the same stencil, for the same kit. They contacted Eduard and they sent a replacement.
https://www.google.com/search?q=1:48+scale+air+force+decal+marking&tbm=isch&source=iu&ictx=1&fir=FGu6yPi5Q_kU4M%253A%252C9pasGeG3W1PhaM%252C_&usg=AI4_-kTADhZhMEh1ZG1YXAArF88lCd3fHw&sa=X&ved=2ahUKEwi4p63RyefgAhVJ9YMKHTqwANUQ9QEwAnoECAUQCA#imgdii=NN_FkRGAs8lSBM:&imgrc=fttoxHE49UOTZM:
    July 2014
Posted by Bakster on Sunday, March 3, 2019 11:21 PM
I am sorry to bomb you guys with my X-1 stuff, but here is a build I found that looks pretty cool. I don't think I'd want as much weathering for my project, but the panel line accent looks pretty good.
Is there a way to apply panel line accent directly onto acrylic paint (no clear coat) and remove the excess without stripping the paint? The thing that bugs me about the traditional method of applying panel line accents is with all the layers a person has to apply, future being one of them. More room for error, more build of up paint imperfections, and more reduced detail.You can't use panel line accent over Dulcote correct? Sorry for the dumb questions, still much to learn.
GAF
    June 2012
Posted by GAF on Monday, March 4, 2019 9:25 AM
Bakster>  Good morning!  Unfortunately, my experience with washes is limited, so I'm afraid I can't help you much.  I will say that the photo of the X-1 you supplied doesn't look right to my eyes.  I think panel lines should be "uneven", and the way this was applied makes it look like a jigsaw puzzle someone put together.  Probably looks a lot better in person and under normal lighting.
You might want to ask about this in another forum thread like "Techniques".  You might also ask about decals in another forum thread also.  I doubt too many people check in on this GB for you to get a wide enough opinions.  Someone outside this GB might have the decals you're looking for.
Gary
    July 2014
Posted by Bakster on Monday, March 4, 2019 9:58 AM
Hey Gary, good morning back!
Thanks for your opinion about the panel lines. I appreciate that honesty and that is what I am looking for. So, maybe I'll just leave mine alone. The model I am building is depicting it as pre-flight. So, there ought not be a lot of weathering. I found an image that I think was taken of the X-1 after Yeagers flight. Man--the plane looks rough. Much of the paint on the leading edges of the wings had been worn off or blackened. Not sure which.
Regarding the decals: I wrote Eduard and they are sending me a new sheet. How long it will take to get here is anyones guess. There is plenty of other work I can do during that time. So, fingers are crossed.
Regarding my question about panel line accents. I did some preliminary searches and found this discussion at the link below. Apparently, some are using acrylics as a wash. I might try this sometime.
https://www.britmodeller.com/forums/index.php?/topic/65173-panel-line-washes/
That is all for now.
Over and out....
Posted by Gamera on Monday, March 4, 2019 11:18 AM
Bakster: I use a gloss or better yet semi-gloss under a wash. The problem with flat is if the wash slops outside the panel lines it can stain the paint and be impossible to remove. On a more shiny surface the wash wants to settle more into the recessed line and it's easier to wipe off any excess.
Orange is a pain to wash in any case. Brown is probably your best bet, personally I wouldn't use black.
GAF
    June 2012
Posted by GAF on Monday, March 4, 2019 12:09 PM
Bakster>  Gamera has good advice on washes.  I must admit that I don't think I've used washes so much as "weathering".  I've actually gone in and used a mechanical pencil to darken panel lines in places for accentuation.
Glad you got in contact with Eduard and they're going to send you a replacement decal sheet!  That is excellent service.
Gary
    July 2014
Posted by Bakster on Monday, March 4, 2019 7:08 PM
Gamera
Thanks for the advice, Gam.
