Ben> Thanks! Glad to have you drop by and comment. We'll see how everything goes.
It's too bad about the decals, but luckily no harm done. I'll just try again!
Mach71> We'll keep a light on for you.
Update:
I've reprinted the CM decals and allowed them to dry overnight. This evening I shot them with a light spray of Testors Dull Coat instead of the Decal Bonder. This didn't seem to react with the ink as bad as the Bonder. I've applied a second light coat (essentially just one spray swipe). So far so good. I'm going to let this dry overnight and then hit it with another coat.
One thing I want to try to do is apply water only to the BACK of the decal sheet and try not to wet the front. I hope this will keep the ink from splotching as in the past. This will be more difficult to apply, but I'm going to be extra cautious.
On another detail, I'm working on the sign for the base. I've cut out a backing from some matte board and am painting it gray. Then I'll apply the sign to the backing with some spray adhesive. I may even put a few bolt heads on the sign when I attach it to the base. Should be an interesting detail.
I've also cut out some "boots" for the legs of the LES where they attach to the CM. This looks better than the bare rods so I'm happy about that.
Also, I'm looking for stencils to apply to the model. There are a couple for the LES on the canard doors that I think I will attempt to print and apply. We'll see.
That's all for now.
Gary
Today In Space History:
1967 April 24 - .
- Crash of Soyuz 1. Cosmonaut Vladimir Mikhailovich Komarov is killed at age 40. - . Return Crew: Komarov. Nation: Russia. Related Persons: Komarov. Program: Soyuz. Flight: Soyuz 1.
The decision was made to bring Komarov back due to an undeployed solar panel which reduced electrical power and blocked orientation sensors. Re-entry was successful and the drag chute deployed. However due to a flaw during manufacture, the parachute compartment housing was too rough and the main parachute would not deploy. Komarov released the reserve chute, but it became tangled with the drag chute. The descent module crashed into a field near Orenburg at 03:24 GMT.
1990 April 24 - . 12:33 GMT - . Launch Site: Cape Canaveral. Launch Complex: Cape Canaveral LC39B. Launch Platform: MLP2. LV Family: Shuttle. Launch Vehicle: Space Shuttle.
- STS-31 - . Call Sign: Discovery. Crew: Bolden, Hawley, McCandless, Shriver, Sullivan. Payload: Discovery F10 / Hubble Space Telescope. Mass: 13,005 kg (28,671 lb). Nation: USA. Related Persons: Bolden, Hawley, McCandless, Shriver, Sullivan. Agency: NASA Houston. Program: STS. Class: Manned. Type: Manned spaceplane. Flight: STS-31. Spacecraft Bus: Shuttle. Spacecraft: Discovery. Duration: 5.05 days. Decay Date: 1990-04-29 . USAF Sat Cat: 20579 . COSPAR: 1990-037A. Apogee: 615 km (382 mi). Perigee: 585 km (363 mi). Inclination: 28.50 deg. Period: 96.70 min.
Deployed HST (Hubble Space Telescope). Payloads: Deployment of Hubble Space Telescope, IMAX camera in payload bay and in crew compartment, Protein Crystal Growth III-03, Investigation Into Polymer Membrane Process-ing- 01, Air Force Maui Optical Site-05, Radiation Monitoring Equipment III-01, Student Experiment 82-16, and Ascent Particle Monitor 01.
- HST Hubble Space Telescope - . Payload: Hubble Space Telescope. Mass: 10,863 kg (23,948 lb). Nation: USA. Agency: NASA Greenbelt. Class: Astronomy. Type: Astronomy satellite. Spacecraft: HST. USAF Sat Cat: 20580 . COSPAR: 1990-037B. Apogee: 596 km (370 mi). Perigee: 590 km (360 mi). Inclination: 28.50 deg. Period: 96.50 min. Hubble Space Telescope; deployed from STS-31 4/25/90. Spacecraft engaged in research and exploration of the upper atmosphere or outer space (US Cat B).
