1,000 Roadwheels - 2009
    November 2006
Posted by dupes on Friday, January 30, 2009 1:06 PM
Glad to see so many people cranking out the builds! Excellent work, too.
Keep it up fellas! Earn those stripes! Big Smile [:D]
    February 2005
Posted by Glamdring on Friday, January 30, 2009 8:02 PM
Looks like this was released at the perfect time.
http://www.dragonusaonline.com/item_detail.aspx?ItemCode=DRA7321
I'll have to definitely get one for this GB....
Robert
"I can't get ahead no matter how hard I try, I'm gettin' really good at barely gettin' by"
    July 2007
Posted by Geist on Friday, January 30, 2009 10:51 PM
Here is the first painting update. My basecoat is straight PolyS Panzer Dark Yellow. Next up is going to be PolyS Panzer Olive Green then PolyS Panzer Red Brown. Can you tell I like PolyS?
Erik
On the bench: Italeri Leopard 1A2 correction build with Perfect Scale turret and Eduard PE
Posted by tigerman on Friday, January 30, 2009 11:53 PM
Erik, good going so far. I personally don't care for Poly. I just have a tough time getting it to cover. I prefer Tamiya or Model Master Acryls.
 Eric
    September 2007
Posted by Mobious on Saturday, January 31, 2009 3:43 AM
 Very nice progress updates all! It's neat seeing the Jagdpanzers form 3 different manufactures being built. Have fun with the builds. Looking forward to seeing more phenomenal updates from everyone.
"It's a problem of applied physics" Roy Brown
    April 2005
Posted by wing_nut on Saturday, January 31, 2009 6:35 AM
HEY...I am starting to think I need a bath or something (imagine a smiley smelling his arm pits here).  Every time I finish up a GB... that's when the building gets cranked up.  OR maybe iI need to slow down a bit so I last longer? (don't even go thereWink [;)])
Excellent progress from all of you.  I may need to throw together something else for this one.
Marc
    July 2007
Posted by Geist on Saturday, January 31, 2009 9:25 AM
I just like the variety PolyS presents. It seems like everyone uses Tamiya and builds start to look the same after awhile. You know what I mean?  I do use Tamiya occasionaly though. They are a dream to airbrush.
Erik
mmc
    February 2007
Posted by mmc on Saturday, January 31, 2009 1:35 PM
Evening all.
Done a bit more work to my Jagpanzer, what a simple and straight forward kit this has turned out to be. I've left the tools and spare track of the body until it's painted. The kit comes with a choice of long and short barreled 75mm guns, the short is in 2 pieces, while the long is just a single piece, I decided to go with the long barrel. The schurzen aren't fixed in place , they just hang on supports down both sides of the body.
Next up is painting and adding the tools, spare track and wheels.
Mark
    November 2006
Posted by dupes on Saturday, January 31, 2009 1:53 PM
I use Tamiya acryls almost exclusively, but do mix it up every now and then just for the reason you mentioned above...either that, or mix some other shades in to prevent everything from looking identical!
Wingy - you "MAY" need to build something else? There's eleven months left before this GB expires...I should hope you have a full shoulderboard by the end. Wink [;)]
Ahhhhhh! A DML 1/72 Panzer IV chassis! It's about time! I'm with you...going to have to pick one up to bang out for this GB! Big Smile [:D]
    May 2006
Posted by panzer88 on Saturday, January 31, 2009 6:05 PM
Everyone's builds are coming along nicely. I don't think that I would have all that patience to take care of all those injector pin marks on that Trumpy kit, hats off to you. Well with all this progress, I figured that I should show that I've been doing something too. The Jagdpanzer is pretty much ready for paint, I added some periscopes since the kit lacked them. Yeah, and Dupes can you put me down for couple more kits, Tamiya's Ausf. J and Dragon's Ausf. J Late. I couldn't help myself. The Dragon Ausf. J is almost ready for paint and the Tamiya kit still has some work. The Schmall Turm Panzer IV is coming along slowly, I had to use a bunch of squadron putty to repair and rebuild the back of the turret and some on top of the hull (had to break out the dremel tool and do some grinding) to help smooth things out. Still have to sand the hull roof down smooth.
    July 2007
Posted by Azgaron on Saturday, January 31, 2009 6:12 PM
Yes, there sure is some really nice builds going on!
Mine has came to a halt, due to lack of color, and my LHS didn´t have them, so I decided to try Tamiya. So I´ll put in an order asap! Smile [:)]
Cheers,
Azgaron
    April 2005
Posted by wing_nut on Saturday, January 31, 2009 7:02 PM
Question.  Is the Hummel clasified as a tank destroyer?  At our May club meeting the theme is "Destroyer Night".  Anything that was design as a destroyer or has that word in its name. Like the USS Buchanan, the Dicker Max, or an Me 110... all are "destroyers" I can kill 2 bid with 1 stone.
Who makes the best Hummel?
Marc
Posted by tigerman on Saturday, January 31, 2009 8:08 PM
No. The Nashorn was based on the Pz IV chassis and was considered a TD. The Hummel with its 150mm was designed for artillery support.
Dragon just released a Premium Edition with all the goods. They have an Early and Initial as well. From the reviews I've read on the Initial and Early, they appear to be very good kits. I wouldn't mind either myself.
If you are considering the Nashorn, then kit 6166 is the Early and also is considered good. There is also a Premium Edition of it out too.
 Eric
    April 2005
Posted by Thunderbolt379 on Sunday, February 1, 2009 6:10 PM
Hi all,
Some progress occuring, I'm working each evening on the Jagdpanzer and have started mods for mounting the Cavalier set. Some mods will be to the kit, others to the zim to accommodate kit molded detail. I'm impressed with Cavalier's product, the resin is easy to cut and sand but firm enough to hold its shape. The cast replacement components are molded directly from craftsman-modified kit parts, so you can be sure they'll fit.
Here's the rear hull mounted (my alignment isn't milimeter-perfect, but nothing on this kit is!)
Photobucket" border="0" />
The part was added with superglue, and I reinforced the back with Plastruct angle stock:
The upper hull is mostly done too, including scratchbuilding periscopes to go under the covers -- they're not the right height, but I've seen plenty that look like this on other models. More updates later.
Cheers,
http://worldinminiature.blogspot.com/
    December 2006
Posted by detailfreak on Monday, February 2, 2009 6:21 AM
a little update on the progress.dml F2/G,the vehicle is coming together quite wel as one can see.so far there have been no real fit issues.some of the smaller hull fittings,visors and such need to be added.but the heavy construction is complete.front view you can just make out the brake assemblies.hey doog,toned the screamin yellow ochre down quite a bit.this right quater view shows the suspension and tracks .lots of hand painting here now.as said earlier, the old indie links required a great deal of cleanup on each link there were two knock-outs and three to four sprue attaching points.nothing quite as good as a rear view.you can see where this ones headed with those winterketten dupes.a little top view.and last but not least my next two offerings for this G.B.
[View:http://s172.photobucket.com/albums/w1/g-earl828/]  http://i158.photobucket.com/albums/t104/cycledupes/1000Roadwheels4BuildBadge.jpg
    November 2006
Posted by dupes on Monday, February 2, 2009 9:38 AM
Looking good Detailfreak! Like the looks of those Ostketten. Thumbs Up [tup]
    December 2006
Posted by detailfreak on Monday, February 2, 2009 5:25 PM
my apologies dupes for being so rough on your dial-up.i feel your pain as i use a dial-up also.peoplepc with an accelerator feature.not the greatest but 45.2 kbps will have to do.i see the photos did'nt turn out that bad and i can hear you from here wbill.that guddarn wood grained backdrop does'nt that ornery cuss ever listen to sound advice.well yes ,but you must understand we are down to 2/3rs of our normal living space as we had to remove a poorly deteriorated portion of our residence.hence no room.the living room table is my workshop currently.everyones builds look great so far.and the quality is setting a rather high standard also.Thumbs Up [tup]any comments or suggestions are also welcome.at the rate you're punching these out wingnut you will run out of room to display them. the primered hulls in the last photo are the pz4 ausf.e 3 in 1 kit,and the dragon 6166 nashorn(very likely my favorite spg/td.also with any luck i'll throw in the new brummbar mid production.thanks for looking.
    April 2007
Posted by SMJmodeler on Tuesday, February 3, 2009 11:34 AM
T-Bolt:  Zim is looking good so far, I have some Cav' for a Panther and have heard good things, keep us posted!
detailfreak: Frickin' love those tracks!  You doing a winter camo' too?!
Is that drybrush wear on the fenders, etc...?  What color and medium is that?...it's subtle...very nice!
    December 2006
Posted by detailfreak on Tuesday, February 3, 2009 4:58 PM
indeed there will be a snowy used up coat of whitewash,my winter warriors fix.just starting to bite into figure painting so this one wo'nt get crewed yet.the tracks need a little bit of a wash to tone them down a bit.have'nt decided on a unit yet.Blindfold [X-)]
    April 2005
Posted by taxtp on Wednesday, February 4, 2009 7:09 AM
Hi Everyone,
Here is the latest WIP pic of my Panzer IV Ausf J. I've used three shades of Tamiya XF-60 Dark Yellow on it.
More to come.
Cheers
Tony
I'm just taking it one GB at a time.
    January 2003
Posted by p38jl on Wednesday, February 4, 2009 12:48 PM
Ok,, bare with me here, altho I've been on FSM for a while, this is my first time posting here..
Dupes has shamed me into joining this build after viewing my kit stash and seeing one lonly Panzer in my unbuilt stash..
I will dig this out and start soon.. Wish me luck
[Photobucket]
    June 2008
Posted by Hans von Hammer on Wednesday, February 4, 2009 12:53 PM
Luck..
    July 2007
Posted by Geist on Wednesday, February 4, 2009 5:58 PM
The finish on the A/O isn't going as planned. I rushed the painting cycle and didn't prime the kit. Now my washes are rubbing the paint off. I'm not really even rubbing that hard either. Should I try sealing the paint before the oil wash? I've never sealed before and I haven't had a problem. I'm going to start a new kit for now. Once I get to the painting process on whatever I start I will repaint my A/O.
Erik
    August 2007
Posted by some assembly required on Wednesday, February 4, 2009 8:23 PM
Geist, id definatelly squirt on some future or testors dull cote.either way you need a layer of protection over your polly s.good luck and btw im diggin your TD.
    February 2005
Posted by Glamdring on Wednesday, February 4, 2009 8:53 PM
I firmly subscribe to Doog's washing method, so I'd go with the Dullcote.
Robert
    November 2006
Posted by dupes on Thursday, February 5, 2009 6:01 AM
Waiiiiit...is this CHRIS? Excellent! (for the rest of you here on the forum, Chris is one of the very few 'local' modelers around my parts I've been harassing about getting on the website, and this build in general) Let me know the make and model of your Pz.IV variant, and I'll add you to the front page! Cool [8D]
Geist - sorry to hear about your finish. I'm guessing a clearcoat would be in order...hopefully you don't have to do a complete repainting?
Detailfreak - holy cow! Missed your part about the additional builds at the end...i.e., the  pz4 ausf.e 3 in 1 kit,and the dragon 6166 nashorn! Excellent! Shooting for all 5 bars on the shoulder by the end of the year? Wink [;)]
    April 2005
Posted by taxtp on Thursday, February 5, 2009 7:48 AM
Here is the 1/48 Panzer IV Ausf Jwith the camo pattern applied. I hope it looks better once the weathering is applied. I'll attach the turret schurtzen tomorry, and hopefully spray the pattern on that over the weekend, unless it's too hot. I've got to admit, I'm not too crash hot on the way it looks right now. But then, I never am at this stage.
Half midnight here, good night all.
Tony
    November 2006
Posted by dupes on Thursday, February 5, 2009 8:33 AM
Tony - looks solid to me. Once you wash and weather this guy, I think it'll look fine! Thumbs Up [tup]
    July 2007
Posted by Geist on Thursday, February 5, 2009 4:25 PM
 I don't think I'll have to but I probably will. I wasn't very happy with the finish anyway.
Erik
    August 2007
Posted by some assembly required on Thursday, February 5, 2009 7:01 PM
bummerSigh [sigh] nothing jams me up like having to do a strip & repaint.
