Hey Dupes,
Enjoy your vacation! Here's an update that you can view and comment on. if you wish..
The Trumpeter Bruckenleger, still ohne brucken. The bridge support rails have been installed and the bridge sub-assemblies have been assembled and painted in base coat (see below). As described in the previous post, the chassis was painted with a base coat of Tamiya Panzer Gray and then panels were highlighted with the same lightened with Tamiya flat White. Tonight, the chassis was weathered with oils to mimic accumulation of dust, dirt and mud by using oil washes...
... consisting of various mixtures Flake White and VanDyke Brown; initially consisting of very light brown (i.e., 90% white) and progressively getting darker by adding more VanDyke brown, until it was almost 80% or so.
One mistake I made in photography; I set the lights too close and actually started melting the plastic!!! (see the transmission plate in photos 2 and 3). I've got some ideas a to how to correct the problem; but any suggestions on how to handle the damage will be appreciated.
Decals went on without a hitch, without Future but with liberal treatment with setting solution.
The rest of the bridge sub-assemblies have been constructed and painted...
The Bruckenlager is nearing completion. Comment sand criticisms are welcomed.
Don
