Hello All,
I've made quite a bit of progress with my Jagdpanzer. The build portion is rapidly coming to an end. Then it's on to painting and finishing.
I have to say once again how impressed I am with this kit! The detail is extremely well done, and the fit is VERY good.
For an example, the gun barrel is a one-piece plastic affair, but it actually has rifling inside the muzzle! The magic tracks are also well detailed, but more importantly, they are super easy to assemble. I had one side built in 15 minutes......no kidding! The longest part of building them was waiting for the glue to set-up enough for me to wrap them around the running gear. Each link does have two ejector pin marks, but they are raised so you can choose to sand them off. I left them as I didn't want to spend all day sanding each link.
As I mentioned in a previous post, I plan on building this kit with all the hatches closed. I did however build up the breech end of the gun so you can see the detail in that area. I wasn't too careful with building it, as it won't be seen after I attach the roof.
The engine deck, and casemate are just placed on the hull for photo purposes. They do lock in easily, and when I do glue them down, the fit will be as close to perfect as you can get!
Well, here's some pics of where I'm at now.
Here's a close-up of the gun mantlet........the casting numbers are molded into the plastic, but there is also another set of numbers that I have to shave off the parts trees, and apply next to these.....yikes!
That's it for now, enjoy the pics, and comments are welcome.
Nate
