Hey Marc! I built the Pegasus Spitfire during the BOB GB. Was very impressed with the fit and external details on a snap together. I have not seen the 109 version but it doesn't look too bad either. I was really surprised as if you did an after market pit with the spit it could be a real contender with some love. Think I threw it together in 8 hours paint and all and was very pleased with it.
Cool choice of markings Gumiflex!
I am betting Guy will be done by morming! Looks spectaculoso! Ditto on the amazement in the speed but fine quality that you can turn these out!
As far as I go spent a good 3 or 4 hours researching the markings I want to do my 109 G in. Narrowed it down to about 3 but want to find my 109 books before finalizing the decision. Too many choices but I want one that has a DOR band to fit in with the late theme of this GB so trying for no earlier than circa 1944. At that stage to where I need to make a choice before proceeding to get the details right.
I do have another question that I am having trouble answering. The forward wing flaps or moving leading edge thingie? I have the flaps on the back wing all apart ready to pose but am concerned that the forward ones may have automatically opened as well. This could be an issue as I do not think there is an awful lot I can do with them without destroying the wing. The Plastic is very thick and the shape would not be accurate after chopping it of. So I think I am stuck with leaving them intact and alone.
Will this be an issue with the position of the flaps on the rear of the wing?
In the mean time I am working on the gear legs and wheels. I used wheels labled G from the hasegawa sprue. There are also another set labled K. I used the G wheels as I have some resin replacements for the Hasegawa kit. Addind the PE parts that I have available. The newer G-10 PE set comes with PE Brake lines which look really cool and hook into a PE inside hub. This older kit does not have them so I am shaping wire using the PE set for the Hasegawa G-10 as a ref. Confused yet? I only eneded up with 5 diff kits and a box full of am goodies thanks to catching this bug! I am getting anxious to try out my new found knowledge on a newer nicer kit!
Here is a comparison of the wheels original and the new ones.
Hope someone knows the answer to the flap/ control surfaces question. I may be able to get away with positioning the rear ones open just a little if that is the case? Thanks!
