Star Wars GB
    May 2008
Posted by Boba Fett on Tuesday, January 13, 2009 10:02 AM
like 25mm. Close to 1/48th. They vary in size though.
    June 2003
Posted by reddog-03 on Tuesday, January 13, 2009 12:10 AM
What scale are those Star Warrs "minis"?
Airborne-All the way!
Doug
    March 2006
Posted by TD4438 on Monday, January 12, 2009 7:37 AM
It's been a long night.I watched ROTJ twice while taking breaks from building.I painted a few sub assemblies and test fitted them to the hull.BANG!!! This here Snowspeeder is starting to look like something.I really think you guys are gonna dig this.
    December 2007
Posted by Cosmic J on Sunday, January 11, 2009 9:51 PM
 smeagol the vile wrote:
thing was, I had gotten it brand new from the store, opened it, no workie.
I dont trust testors spray dark red, always comes out in blobs and bubbles.
Strangely enough, that has been my experience too.
    March 2006
Posted by TD4438 on Sunday, January 11, 2009 9:48 PM
My spraycan had rust on it.LOL.
    April 2008
Posted by smeagol the vile on Sunday, January 11, 2009 9:37 PM
    March 2006
Posted by TD4438 on Sunday, January 11, 2009 8:53 PM
Actually fellas,I think the paint is just old.It's a Testors dark red.I usually build tanks,so I have no idea why or when I bought this stuff.I built a few u-boats a few years ago,but I used a brighter shade of paint that I still have.It came out OK.Nothing a little weathering won't hide.I hope.
dmk
    September 2008
Posted by dmk on Sunday, January 11, 2009 4:50 PM
I'm sorry, poor explanation of what I meant.
No, I meant soaking that little tube sticking out of the can. Fill it up with laquer thinner, let it soak and invert the can and spray with a new nozzle.
 May not work, but it's worth a shot.
    April 2008
Posted by smeagol the vile on Sunday, January 11, 2009 3:35 PM
its not the nozel, its in the can.  I replaces the nozel with one from a good can of primer that ran out, no difference
dmk
    September 2008
Posted by dmk on Sunday, January 11, 2009 3:22 PM
Yea make sure everything is working fine.  I have a brand new can of german silver I cant use, because it just wont spray.  Wont come out of the nozzel no matter what I do, switched, cleaned, nothing
Yea, I had a can like that once. Seemed to be clogged down inside the can. There's a trick where you soak nozzled in laquer thinner. Maybe removing the nozzle and soaking the little thing in the can might help.
    April 2008
Posted by smeagol the vile on Sunday, January 11, 2009 1:13 PM
dmk
    September 2008
Posted by dmk on Sunday, January 11, 2009 10:40 AM
get warm water, submerge the can to about 75% of the way in the warm to hot (not boiling hot, but like, the tap all the way hot no cold, hot).  Let it sit for a min or so, take it out, and shake like theres no tomarrow.  The hot water will loosen the paint so the thinner can do it's job.
I concur with this trick. I really helps. I usually soak it in hot for a few minutes, shake it good, then soak it again in fresh hot water just to make sure it's warmed all the way though.
  Also, it pays to test spray on a piece of scrap plastic or even a piece of metal (really anything that isn't porus) to see how that can will spray. Better to learn on scrap that the nozzle is bad or something wrong with the paint before ruining the finish on your model.
    March 2006
Posted by TD4438 on Sunday, January 11, 2009 3:53 AM
I'll remember that little trick for future problems.
    April 2008
Posted by smeagol the vile on Sunday, January 11, 2009 3:51 AM
    March 2006
Posted by TD4438 on Sunday, January 11, 2009 3:03 AM
With the exception of the space-monkey pilots,I really dig the AMT Snowspeeder.It's building up nice.I'm giving it a retro paint job.You guys will understand that when you see it.Big Smile [:D]
I ran into yet another problem with my spray paint.The stuff was coming out thick and slow.With no hobby shop for miles,I was kinda stuck with it.The finish so far isn't bad,but it could have been better.
One more hurdle cleared in my first FSM group build.
    December 2007
Posted by Cosmic J on Sunday, January 11, 2009 1:34 AM
I just like the crystals, because you put them in the silver monoeye holders that they sell seperatly (less then like 7$ for the lot or something) and it really makes them glow when there in the back, inside of the head of a mech.
Yeah, those do look cool. Kinda big for this project. I got one of those 1/20 scale Scopedog kits, its got these turned aluminum lens housings, but the eyes/lenses themselves are just shiny stickers. I might try the MS bits on that project. It will be a bit before I get to it though.
    April 2008
Posted by smeagol the vile on Sunday, January 11, 2009 1:23 AM
I see I see.  Well, whatever works.  Never hurts to know where to find something different, if you ever need it.
    December 2007
Posted by Cosmic J on Sunday, January 11, 2009 1:18 AM
True, but not as much as the Mecha Skunk lenses above. Those look too jewel-like to me, like something on those pewter dragons and wizards you find in a Hallmark store. The MV lenses have a much more realistic curve, like a camera lens or a headlamp.
For flat lenses, I recommend taking a piece of clear styrene or acetate (like you find on a blister pack), and just knock them out w/ a Waldron punch and die set. I do this for larger scale cockpit instruments or gun sights.
Or, you could always just paint them.
    April 2008
Posted by smeagol the vile on Saturday, January 10, 2009 10:40 PM
sure, I figured Id show these because R2's lense is convex
    December 2007
Posted by Cosmic J on Saturday, January 10, 2009 9:51 PM
Yo J, waht are you using for the lense?  If I may, can I recomend these things
http://www.mechaskunk.com/store-mu.htm
There for gunpla mono eyes, but they are really nice looking, and would work great for an R# unit, imho
Thanks stv. MV Lenses are model railroading AM parts. They are used to simulate headlamps on trains. Armor modellers started using them for AFV headlights a while back, which is where I heard of them.
They come in a variety of colors: amber, black, red, white/clear, etc. They are less rounded / convex than the lenses above, so I'll probably stick w/ what I've got. Thanks for the heads up, tho'.
    April 2008
Posted by smeagol the vile on Saturday, January 10, 2009 3:38 PM
    May 2005
Posted by terry35 on Saturday, January 10, 2009 2:56 PM
 JMart wrote:
reddog-03 - very nice! wash made the difference
dmk - nice detailing of the 'pit"; yep, i never liked the orange suits but oh well.. not much military "logic" in SW.
Glamdring - neat kit..surprised at the level of detail, as you say.. it IS mark hamill! lol
terry35 - I really like how it came out..nice weathering!
Boba Fett - yours too! I need to get myself one of those lol
Am I the only one old enough to have worn a "May The Force Be With You" iron-on T shirt in the 70s, when the first movie came out?  Laugh [(-D]
Not really, I think I had one of those T-Shirts, but when Star Wars came out first I was 8.
Terry.
    October 2007
Posted by White_R34 on Saturday, January 10, 2009 12:24 PM
Ok you can put me down for just the TIE Bomber for now, as I will have to build it fully from scratch. Now I would like to say at the same time I'll be working on it I want to try and scratch build the [J-Type 237 Nubian Royal Starship] - [Naboo J-Type Diplomatic Transport]
Building the Impossible Is my main goal!!
    July 2008
Posted by John31388 on Saturday, January 10, 2009 11:29 AM
I would like to join I will buy a kit once i get paid.
    March 2006
Posted by TD4438 on Saturday, January 10, 2009 11:25 AM
 btp2k2 wrote:
Alright....here is the start of my daughter's and my entry. She painted all the cockpit pieces, including dry brushing the center console and I did the figures.
It's always good to see the kids getting involved.
    May 2008
Posted by Boba Fett on Saturday, January 10, 2009 9:23 AM
Chewie sort of looks like nen numb (sp off)You know what I would have tried? Painting him black, giving him a wash of dark brown, then drybrushing the brown onto him, give him a real depth.  But I might be wrong
That's what I did....the figures are so small (about the size of my thumbnail) and the detail so horrid, that is how they came out.
Boba Fett...yeah, the scratch built console is the goal. I was going to give it a go this afternoon but ran out of time before I had to leave for work. I need to find some good pics of it too
I'll give you a shot of my console for ideas. Not now though. Maybe later today.
    April 2008
Posted by smeagol the vile on Saturday, January 10, 2009 2:12 AM
Great minds eh'  (still cant get past your avitar eh')
Those little figures can be such a pain.  And what really bugs me about them, is bandai puts out 1/100 and 1/144 scale figures, that come with their kits... that are molded amazingly, with some great detail.
    October 2007
Posted by btp2k2 on Friday, January 9, 2009 11:42 PM
Paul I Like Tomcats!
    December 2007
Posted by Cosmic J on Friday, January 9, 2009 10:29 PM
Working on my Starfighter. I'll spare you the open box treatment and just show you how I'm modifying the kit.
The R2 (R4?) unit was a bit of a mess. He came molded in two halves, and the seam was a bear to remove. The opening for his central "eye" was oval and crooked, so I filled it w/ Aves and sanded it smooth. I then drilled another hole, to accept either an MV lens or a homemade one. He also looks a bit static as molded, so I chopped off his head so I could rotate it some. Shock [:O]
I furthermore thought that he sat too proud of the fighter's surface, so I shortened his torso a bit. Now he looks all hunkered down and worried. I think this will bring a little life to the model.
The engines as molded are supposed to be trapped between upper and lower hull parts early in construction. As I wanted to paint the engines w/ metallics, and the fighter proper w a Gull or Sea Grey, this would greatly complicate the painting process. Sooo, I modified the engine parts by cutting off their bases. The bases themselves were a little loose in their fittings, so I thickened them up a bit w/ sheet styrene. Now I can paint the pieces separately, and just slip the engines in during final construction.
That's all I got so far, but I'm having fun! Cool [8D]
    May 2008
Posted by Boba Fett on Friday, January 9, 2009 10:02 PM
WOW!!!! Awesome job with those figgies! Thumbs Up [tup] Will you build a control console in front of them for a little accuracy? Just looks wrong without... Your daughter is well on her way to being a good modeler! Smile [:)]
