Regia Aeronautica GB II (06/15/09 to 06/15/10)
    October 2007
Posted by Summit on Sunday, January 25, 2009 10:22 AM
 sfcmac wrote:
I dunno how he does it? Must be something in the Tea?  Do you think he takes them to work? I can just see him driving that huge wheeled monster on the wrong side of the street. Hobby Knife in one hand MA 205 in the other while steering with his feet! Then trying to explain to the Bobby that he thought he was in Texas.  Yippie KI Yeh!
All~right this has my curosity ? What does Guy drive ?One of these ?
HP
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    February 2007
Posted by Luftwoller on Sunday, January 25, 2009 10:54 AM
Wowzers, now thats a whopper fer sure. Im only a lowly bus driver. But i still whittle away while driving. Puts the fear of god up the******drenched old codgers but im sure the fumes from the tenax subdues them a fair bit...That and the gin.
I did a bit on the UC today. The gear doors had some awfull PE bits that i remade out of styrene sheet. Much better i feel. Ive also added a few of the resin bits like the small vent on top of the fuz, the aerial isolator thingy and the spercharger intake. Anyway, Blab is worth nothing without piccies and i havent got any as yet, so tough LOL.
Wish me luck, with the grannies.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    October 2007
Posted by Summit on Sunday, January 25, 2009 11:08 AM
Oooh one of those Double Deckers Guy ? I have always wanted to ride in one of those open topped ones. Big Smile [:D]
I got the fuse sprayed white for the "belly band" also painted the rudder incase the crosses on my decals have yellowed to much to use. I will place one over the bright white background and see how that looks. If to "creamy looking" I will remove it, and mask the crosses.
It will be a slow day today waiting on paint to dry. Guess I will attempt to  paint my other pilot .
    September 2004
Posted by razordws on Sunday, January 25, 2009 12:26 PM
Sean, nice work on painting that pilot Thumbs Up [tup]Thumbs Up [tup]  In 1/72 that is really hard to pull off.
Aaron you crazy nut.  Pulling out an old geezer of a kit and then detailing the heck out of it.  You rmaking the rest of us look bad!  It's all your fault!
Guy, looking good.  She's coming together nicely.
I spent most of last night and this morning looking for my reading glasses.  I'm at that age where I'm blind as a bat without them.  Seams one of the kids (ya it's their fault) knocked them off the side of computer table.  Sheeesh!!!  Anyway, also a little under the weather today so I hope to just take it easy and see if I can do as good a job on my little pilot as Sean did.
Dave
    December 2005
  • From: back seat of your car with duct tape streched out
Posted by soulcrusher on Sunday, January 25, 2009 12:34 PM
Thanks for the comments fellows. I am really trying to keep it simple. I was going to ask of anyone had a decent kit instruction of the MC 200 to try to copy some details but between Frank's link and looking at the 202 which is supposed to be a reengined 200. I figure I can get ball park enough for a kit that had nodda!  Probably more fun that way.  You notice it also has molded on antenna and pitot( 2 of them) tubes.
Working on the wheel bay area. Kinda complex wasn't it?
Aaron if you feel like going nuts here is a copy of the Classic Airframes instructions that has a very detailed cockpit and wheel well area. So if you feel like it here is everything you need to go nuts!
        SoulcrusherPirate [oX)]
    October 2004
Posted by sfcmac on Sunday, January 25, 2009 1:37 PM
Thanks a bunch SC! Actually seeing that is kind of a relief. I was just using Frank's link and the 202 kits to give an informed guess at it. Looks like I got pretty darn close! Do the happy dance!
I just sat down to do some more on the wheel  bay area. So your directions are right on time!
I am trying my best to carve and create stuff out of what ever is laying about. I found an old circle stand for the atrocity of a figure from the Arii 109, I made a template shape by mushing clay into the upper fuselage and removed it to trace the shape outline onto the circle. Then I just roughly dremeled to the line and presto! Got a bulkhead that fits like it was made for the kit.
Ten after much much clean up of the lower fuselage and wing I started playing around with ideas. The center beam was lame so I drilled out 3 hoes on each side and wallered them out a bit with the hobby knife.
Also made some back walls for the wheel bays out of masking tape and super glue. In the process of detailing them a bit using the 202 wall as an example.
I use a lot of white glue to tack it in place and let me position the tiny pieces then set it with CA when it looks right. Works well.
The front walls are thin. When attached to the fuselage there is no room to add much so I drilled a few more tiny holes to make it appear more structural as in the center beam but lots smaller,  did the same for the upper fuselage edges that show through.
Have to finish the rear wheel well walls and do up the bulkhead a bit then we are in business! Thumbs Up [tup]
    October 2007
Posted by Summit on Sunday, January 25, 2009 1:59 PM
Thanks for the Great comments on "Guy" the 1/72 Pilot figure.  That is my second figure I have attempted in the last 15 years. He actually has more color but the work light washed them out.You most likely wont be able to see much of him through the windscreen anyway. But he will be in there Thumbs Up [tup]
Aaron - you are the Modeling King , I cant believe how much that kit has "Popped" with the extra detail.  You do a few more of these like that and you will never want to look at the newer "super Kits" anymore.
Dave -If I could have all the hours back for searching for my readers..... The worst for me was several months ago my Wife had a Conference out of town and I went along. Took a stack of FSM from the 80's to read. Left my glasses at home ,could not read or see anything at all. Two days stuck in a hotel room during a Monsoon rain with nothing to do.
    October 2004
Posted by sfcmac on Sunday, January 25, 2009 3:51 PM
Well Sean the Queen is keeping me busy today. Letting stuff dry and working on the honey -do list. I had some Italian Wedding soup for lunch so I am raring to go!
 Anybody got some good profiles or pics of the MC 200?  Thinking about a desert version. Kinda just trying to figure out what I am representing. Man the time to paint came up quick!.
    October 2007
Posted by Summit on Sunday, January 25, 2009 5:34 PM
Not the best, but all I could find at the moment in my books.
Chi 200 I will keep looking though.
Pilot - Guy jr. is starting to look quite Dapper. I am pulling out all the tricks as I know Dave is going to come in with something looking like it should walk & talk.
SC- Could you post a pic of the Brush you use for clear with something to gauge the size? Shy [8)] (bambi eyes Please)
    October 2007
Posted by Summit on Sunday, January 25, 2009 6:08 PM
One more -
Chi 200a
    October 2004
Posted by sfcmac on Sunday, January 25, 2009 6:37 PM
 Hey thanks Sean! I re read the whole thread and there was a pic I hadn't noticed of one as well. I am saving them all and trying to figure out what is best.
To show my gratitude I have specially made an attempt to make my deviant pilot antatomically correct.
This fellow is awful. No detail no face not much but a blob. To really paint a good figure you have to start with a good figure. I did not replace him simply because the point of this build is to make something out of nothing from nothing. So I painted shadows and carved features with a sharp hobby knife. I am no Michael Agelo especially in 1/48. But here is what I came up with.
Normal viewing at size he looks not so bad.
Zoomed in you can see he has no face. Just dots and bloches in cuts made by the knife and a nose shaped from CA.
A lotta work for what it is but keeping with the kit parts.  Like you say he is tucked in pretty well so not much will show and he will do fine.
On the up side my bulk head is done and other details added to flat gear covers.
 A little more than a flat piece of plastic now.  Lotsa color to show something in the dark space. Drilled some holes from nose to this bulkhead and will add some wires for cables ext to jazz it it a bit.
    December 2005
Posted by soulcrusher on Sunday, January 25, 2009 6:49 PM
Sean I use a brush that is about 1/4 inch wide that is very soft.  Do not shake the Future like paint because this causes air bubbles. Move the brush along slowly and if you get a bubble go over it agian very slowly to remove it. The biggest thing is make sure the work are is dust free. I like to give the workbench a wipe down with a wet paper towel right before I start. Future is like a dust magnet so the cleaner the area the better. Do not expect it to be perfect. When the final dullcoat is applied it will hide all of the small imperfections. Now off with you and have a go at it or Aaron will be wondering where the pics are of your work! Guy is at work so I am handing out the homework in his absense.Whistling [:-^]
Aaron here are some pics for you. If you do not see anything you fancy I can post some more. If your decals are not that good let me know and I could send you some that are sure to be better than the junk that came in the Smer kit.
    February 2007
Posted by Luftwoller on Sunday, January 25, 2009 7:10 PM
 sfcmac wrote:
Do you know, i swear i had him on the bus today. Not a bad evening really. The Pussy cat dolls were playing in town and i was there just as all these hundreds of young girlies (Who dress like the dolls at thier concerts) all wanted my bus home. Oh its a hard life.
Dave, i feel your pain with the glasses episode. I spent a whole week searching for mine to no avail. Then i realised i dont wear glasses. Oooh i was mad.
Summit, Driving a bus is one of those things that seem really cool....untill you do it day in, day out for a year or 2. Then you hate everyone and everything. And the fact that your driving 13tonnes of aerodynamic housebrick, with all the accelleration of Honey really starts to grate. LOL.
Aaron, you are seriosly the man!! Your scratching details (Not the ones you told me about Hush hush, mums the word) on your 'Dog' of a plane are truly superb. Going that extra mile has turned your Reggy into a thing of wonder. Whats the colour scheme your going for? Have you chosen yet?
Crusher, you are doing a stunning job in my absense. Whats the homework for us. I love homework. Remeber i found Franks Piccy, God im ace LOL.
Anyhoos, im knackered and off to bed. You kids play nice while im gone.
...Guy
    October 2004
Posted by sfcmac on Sunday, January 25, 2009 7:42 PM
 Thanks SC ! Great pics!  I think I am going to have to stick to my guns and make this outta nothing. Any after market decals would have cost more than what's in this kit so far by about $6. I'll holler if I run into a stumbleing block!  Doing my best to keep er simple. The Smer decals? Not good some thick yellow after armacist roundrals a a black 2.  I'll come up with something and holler if I mess up ok? Good to know you got my back!
 Did Guy go to bed to sleep or was he kidnapped by girls dressed like dolls? Guess it depends on what your definition of knackered is?
Lets see. I am putting it all together now.
Bulkhead ready for wires and extra's
Guy Jr in the seat!
The details I put in actually show up for a change ! Wow I am excited. Hard to get the camera to reach down into the pit though.
Well take a quick break and give er some wings! Thanks again for the comments Fellows you make this real fun! ( anyone notice the subliminal message in pic 1?)
    September 2004
Posted by razordws on Sunday, January 25, 2009 8:51 PM
 sfcmac wrote:
Ooooooo...  just you wait MacNeal!!!  Mischief [:-,]
Dave
    October 2007
Posted by Summit on Sunday, January 25, 2009 8:56 PM
Aaron - Man, I cant believe how good that Chi-200 looks. How Fantastic your detail can be seen from the outside. To me there is nothing more disheartning then to do all that pit work and then it sits down in a dark hole that cant be seen.  And then there is your Pilot - from the looks of him he must work for my old company... Really Cool, so you really had to make his nose ?  I would of went for a Carl Maldon look myself . Laugh [(-D]
Well here is Guy jr. took me forever to get him away from the Jack Elam look.
Guy -1 And the both of them together
Guy's Man, my eyes hurt from the reading glasses and optivisor combo.
    October 2004
Posted by sfcmac on Sunday, January 25, 2009 9:24 PM
 I guess he saw it. Shock [:O]
Sean those pilots are incredible. 1/72 and has a mustache! Looks just like Guy Jr!
That has got to be an eye strain! You must be farsighted as I know those fellows are tiny!
 I'm still goofing around as well.
cut the smallest wires loose off one of my many fried power supplies. Still thought they were a bit large but actually look ok inside. Again the rainbow of colors show up and it lets you know something is there!
Now the hole that used to look at the pilot from the wheels is full of detail and not see through.
Guess I need to focus.
Anyways Guy showed how he checks his seams with color while sanding. To show when the sanding is even ya know? I do the same but when you got a fit nightmare like this old kit you need the old trick of painting gloss silver to show everything! Oldy but a goody! Plus you can use it to weather chips and scratches later!
More to come! Keep em coming Sean! You need to show these fellows that Devastator! It is too cool!
    October 2004
Posted by sfcmac on Sunday, January 25, 2009 10:00 PM
I just realized he reiminds me of Alex Trebeck!  Your answer must be in the form of a question please! Cue jeapardy theme music!
    October 2007
Posted by Summit on Sunday, January 25, 2009 10:36 PM
I'm special, Near sighted in one eye, Far sighted in the Other Confused [%-)]
Thats why I never needed to drink beer, If the girl at  bar was to ugly I would just  close the appropiate eye and vice~a~versa! Laugh [(-D]
Its all Daves Fault ha ha - where is he anyway ?
This is OT but Aaron wanted me to show this old Monogram TBD-1 Devastator I have been working on.
TBD -t If I need to be punished - send Wingus and Dingus right over  Big Smile [:D]  Ooops I mean Angry [:(!]
I like the rainbow of color you added Thumbs Up [tup]
    March 2007
Posted by bondoman on Monday, January 26, 2009 12:01 AM
Here's your Guy. Lost his leg in WW2 in a place south of Rome. Neither of us spoke Italian so it was a little hard to figure out. Him: Croatian. Miss Bondo is impressed, they are no doubt related.
Here's a plaque on City Hall of the dead from WW1.
Here's a plaque of the dead from WW2 (top), and the dead from 10/7/43 when the Italians surrendered and the Germans retaliated by bombing this town- six families, several people each.
Food was good and the people wonderful. Oh look, it's Miss Bondo with Miss Italy (runnerup) 2007.
Cheers, Bondo.
    October 2004
Posted by sfcmac on Monday, January 26, 2009 1:09 AM
 Bondo I love the pics!  Your daughter looks like she fit right in!  The fellow who lost a leg looks like my now deceased father in law.  The first thing he ask me is Do you beat the women you date? I said, No Sir?! He replied that I had better start!  ( seriously he said that)  21 years later I now understand. Laugh [(-D]
 Ok we got the before dinner and now the after but no food pics!  I guess I'll go heat up some more wedding soup. You look like you are fresh out of Rolaids!
Like the explaination on the historic memorial plaques. Too many stories like that. Too many.
Oh yeah in progress stuff.
Guy Jr has his wings!
I was working on the wing seams and wanted to show how much I thinned the cowling flaps. And thinned and thinned somemore. Then rolled up a black wire glued it into a circle (kinda) and put it inside to represent the exhaust ring that shows up in photo's  Here you can see a right and left view of the seams and the cowling doo hicky.
and a better shot of what the gear bays and fuselage guts look like now.
 Well  I think I am ready to paint! I had better decide which aircraft soon huh? Confused [%-)]
Dog gone it Bondo you made me hungry now! Mischief [:-,]
    March 2007
Posted by bondoman on Monday, January 26, 2009 1:29 AM
Oh, ok, snacks before lunch but that's all you get!
The roast pig was pretty good too,
except that my friend Fred got us all 86'd for sticking his hands in it!
Sorry to hijack your thread, Guy, LOL
    July 2003
Posted by sidure on Monday, January 26, 2009 1:32 AM
Geezz, I am away for a few days and I have to catch up with pages of posts. Everyone appears to be having fun. Great work Aaron and I really like what you are doing to that kit. On my front I did get the smoke rings down over the last ywo days. I did the fuselage on Sat and let it sit for a day to see how they set. They looked good and I finished the rest tonight. Quick note on these Mike Grant decals, they are terriffic lay down smooth and respont to set very well. One note of caution though, trim them close as they will fold under themselves if you have too much carrier film on them. They take patients but are worth it.
Hopefully I can put the glosscoat down after I do a panell wash. Crap, I have to put the kit decals on first. DOHH.
Steve
    February 2007
Posted by Luftwoller on Monday, January 26, 2009 3:06 AM
Very nice Bondo! WHich one is the wife and which is he runner up? Hubba Hubba.
Sean, fantastic looking Devastator. Couldnt you italianise it? Im sure theres some decals knocking about.
Obi 1 (Aaron) your skills are putting us all to shame. Im going to have to go back to LEGO. At least i didnt have to paint it. Loving the wire details in the UC bay. Very prominant on Itlian planes it seams. Im going to have to try to replicate something like that for mine. 10.30 till 7ish tonight. Booo. I like earlys not these middle shits I mean shifts.
Steve, thats looking superb. Those decals look amazing. I got 2 wings worth on the CR.42. Did you trim out the centres of the decals as well as around them? I gave them all another future coat to protect them before i start the weathering process.
...Guy
    March 2007
Posted by bondoman on Monday, January 26, 2009 3:35 AM
Miss Italy (runnerup) on the left; my daughter on the right! Guy, you've got a GB for the records here, fine deal, and thank you for humoring the riffraff that drops by.
    October 2004
Posted by sfcmac on Monday, January 26, 2009 3:41 AM
Good golly Guy? don't you know nuddin? The one without the purse is Bondo! You didn't know that? Mind yer manners when a lady be present! Grumpy [|(]Make a Toast [#toast]
 Thanks for the compliment btw but I is just playin, or is it paintin?
Great work Steve! Those decals! That finish. Spectacular! The other Aaron wuz just asking about them. So there ya go! Great work! Glad you remembered to add the kit markings!
 Bondo! I went back to the bench to get my mind off food and it worked until I checked the e-mail! Jeeze!  Your killing me here! That looks like a King's feast!  Spectacular. ( stomach growling)
Sean! eat your tofu!  Look away!
Frank finished his 190 ! it looks as good as they get! Check it out or show us something here Frank! We got Seans Devestator! Lots of great stuff going on!  Have I missed anyone else while Guy has me slaving away shaving the elf's legs?
And...
She's finished!  CLick here
Guy? So that is a super secret project eh? Ok I have a clearance! I think I might have slipped with Wingus or Dingus though? They have ways of making you talk! Taped Shut [XX]
    October 2004
Posted by sfcmac on Monday, January 26, 2009 3:47 AM
Blush [:I]Sign - Oops [#oops] I meant MS Bondo Jr. In the above post!  Well you could say I was 1/2 right?Pirate [oX)]
    October 2007
Posted by Summit on Monday, January 26, 2009 9:21 AM
Steve -   Wow, those smoke ring decals look really good. I think I will order some for a later build. Your almost done - you going to build another Italian Job ?
Aaron - What a machine you are, I thought you had a job. Are you like Guy and whittling away on kits as you rumble that Locomotive along the rails ? Today is Monday - The Wife and Kids are all getting ready to head for school. I will dig out the "Black Sheep" kits here shortly.
Bondo - As always nice pics. Makes those of us who don't have much family feel like we do. And dont be Holding out on us - If you got pics of the Main Course do share Dinner [dinner]
Where is Dave  Eh ? He must be looking for his readers again, or maybe this time his walkies Confused [%-)]
    September 2003
Posted by Daywalker on Monday, January 26, 2009 9:36 AM
Hey- I didn't know Alex Trebek flew Macchis for the RA!  Excellent work on those tine fellas.  I don't how you do it, painting guys as small as the ejector pin nubs on a 1/48 kit.  I Bow [bow] to you guys!
Aaron- You crazy man, you're almost done with another one?  By the time I get my first one finished here you'll prolly have a whole fighter wing completed.  I blame Dave, it's all his fault. Wink [;)]
Sean- Love that Devastator!  Careful though, lots of Axis planes around. Shock [:O]
Steve- Those decals look perfect!  WOulda guessed you painted them on if you hadn't said something different.
Now that my 190 is finished, I can proceed full-steam on my 109s! Big Smile [:D]
Frank
    December 2005
Posted by soulcrusher on Monday, January 26, 2009 11:34 AM
Steve those smoke ring decals came out great. Like guy siad do'nt forget to clear over them before the panel wash. You would no want to ruin those awesome decals I cant wait to see how she looks with the rest of the markings.
Aaron Have you slept in the last two weeks? Seriously you are like the energizer bunny! So what camo is it going to be?
