M32 progress report update:
after seeing so many great posts yesterday, i went home totally stoked 2 work
on my project !
- added a couple of plates of applique armor 2 the hull sides
- made brackets 4 spare drive sprockets out of brass strip
- drilled holes 4 lifting hooks & brackets in upper hull
- started cleaning up flash from suspension parts (just a little, not 2 bad, really)
- assembled & installed tranny housing
- did some dry fitting
mine looks just about like Domi's at this point, except i didn't fill in the ejector pin marks below the sponsons... which is very bad of me, i guess...
but since the upper hull isn't glued in (got a bit of work 2 do on the interior first) i can always go back & fix that at some point if i have 2...
Domi: did u fill urs in because u know it'll b visible, or just because u r a great modeler w/ good work habits ?
frosty
