Falklands/Malvinas War 30th Anniversary GB
Posted by VanceCrozier on Friday, September 16, 2011 10:58 AM
My kit has an Exocet, but I saw a post from someone else who is looking for one for his kit.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2008
Posted by bsyamato on Friday, September 16, 2011 11:18 AM
effectively is not so correct, at least the pylon is more correct than the academy kit
Posted by VanceCrozier on Friday, September 16, 2011 11:49 AM
Yes, it's Friday afternoon... I just found this on youtube, a spanish-language History Channel bit on the Falklands air war:
http://www.youtube.com/watch?v=Wakg5ygIcwQ
    October 2008
Posted by bsyamato on Friday, September 16, 2011 12:05 PM
cool 3d scenes in Yes i'll watch completely after.
thre video remember me that i already built another falklands war veteran , some years ago
actually a good dust keeper Surprise
is the old matchbox (and as i know the only) hp victor , the actual larger finished kit i have.
Posted by VanceCrozier on Friday, September 16, 2011 1:12 PM
That Victor is a different looking machine, I don't think I've ever seen one built up!
Posted by Bish on Friday, September 16, 2011 1:35 PM
Thats a nice Victor, and i have to say as well that you don't often see one built up. Be nice to see all 3 of the V bombers built up together.
    October 2008
Posted by bsyamato on Friday, September 16, 2011 3:31 PM
effectively never me seen other victors builded Embarrassed must bereported to the wwf as protected aircraft species Big Smile
it's even one of my favourites planes, the strange victor aerodynamics solutions are really uniques
Posted by Bish on Saturday, September 17, 2011 2:01 AM
Well hopefully you will enjoy this. This Victor is at Duxford.
    October 2008
Posted by bsyamato on Saturday, September 17, 2011 6:11 AM
yessrr!! wow, color are really gone Tongue Tied
lately airfix did a new kit of the valiant, i hope airfix or some other provide to a good new victor Surprise
Posted by Bish on Saturday, September 17, 2011 7:55 AM
Ye, would be nice to see a Falklands version for the 30th next year. But my guess is they will just re-release the Vulcan instead.
Posted by VanceCrozier on Tuesday, September 20, 2011 2:42 PM
Bish
I had contacted Airfix/Hornby months ago as we were planning the group build and asked them about 30th anniversary releases. I was told at that time that there were none planned, fwiw.
Posted by Bish on Thursday, September 22, 2011 3:05 AM
Really, now thats shocking. I get the feeling this war is slowly being forgotten in the UK.
    October 2008
Posted by bsyamato on Thursday, September 22, 2011 12:31 PM
i remember at least a commemorative set of the airfix including ships and aircraft involved but not sure for the 30 th anniversary.
Posted by VanceCrozier on Friday, September 23, 2011 7:18 AM
Alright, a quick update & a couple of confessions!!! Most of the decals are on now. They do seem to stand out quite a bit on the dark gray. So the plan is to over-spray everything with a very thin mix of the base coat to try to dull them down. Most of these were pver-painted anyway from what I've seen) I probably should have just left the small stencils off... I just couldn't help myself. I had very good luck with the Airfix decals btw, even the roundels that straddle the venting areas on the fuselage sides. I put them down with a coat of Microsol, let them dry overnight, then came back the next day, sliced out the ares that needed to go inside the open areas & hit them with more microsol.
All thos crazy blade antennas & various fiddly bits will be added over the weekend.
yellow striping should be on the canopy framing (right?), but I followed the framing edges as I painted, which turned out to be too narrow to apply these decals to. Embarrassed
The red + black zig-zag... the placement sheet just pointed underneath the control surfaces, so I just guessed! Embarrassed These will be mostly over-sprayed anyway.
And the underside decals - sliced & diced after the pylons were mounted. So to fix this up.... I laid a strip of masking tape onto my cutting mat. Then I placed one of the un-mounted pylons up against the edge of the tape, then placed another strip beside the pylon, giving me the proper gap in between the two pieces. Then I took the portion of the decal sheet that had both roundels on it, and set it over top of the tape strips, secured it, and sliced across using the tape on either side as a guide for my straight edge. Next time.... I'll just add the pylons AFTER the decals like I was supposed to!!! Bang Head I think it worked alright though.
I'm happy with my paint mix for the aircraft, but there doesn't seem to be enough contrast between that and the enamel I had chosen for the gear bays... any thoughts??
Posted by Bish on Friday, September 23, 2011 7:53 AM
I guess the 30th isn't really a big annerversary, not like 25, 50, 60 etc. But what with next year also being the 60th of the Queen on the throne and the London Olympics, i would have thought they could have thrown this in as well.
Nice looking Harrier Vance, i seem to recall they do have a lot of little things sticking out of the sides. You have done a good job with those decals.
Posted by VanceCrozier on Friday, September 23, 2011 8:19 AM
Yes, probably 8-10 little bumps to add - after decals, so I don't knock them off!
Well the decals behaved quite well, making me very happy!! The red outline box on the topside was different. They give you four separate strips, one for each side. So I placed the rear line (as I could locate it using a panel line), then one side, (so I could make sure the spacing was even working out from the centre), then the front section (now that I knew how far forward it needed to go. Then I left that whole lot to dry overnight, then came back and added the last side piece. Took 2 sessions but everything seems to have lined up.
Posted by Bish on Friday, September 23, 2011 8:22 AM
I haven't done an Airfix kit for as long as i can remember. And the only one i have in the stash i have AM decals for. Sounds like they have improved a lot since i last did one. Sounds like quite a job as well for such a small aircraft
    October 2008
Posted by bsyamato on Friday, September 23, 2011 8:27 AM
Bish
you suggest a commemorative airfix queen scale kit? Whistling
Vance the harrier looks good , i'll pay attention of your warnings for the roundel stencil decals, the pylons decals problems is out good Surprise
yellow stripes on the canopy??  is better to paint it i think.
At the end this airfix kit looks  pretty molded. The italeri kit ,even if came with finest details, not include airbrake option and main gear well.
Posted by Bish on Friday, September 23, 2011 12:19 PM
bsyamato
Now theres an idea, Her Majesty in plastic Yes
    December 2009
Posted by Azorean on Saturday, September 24, 2011 11:42 AM
More decals on
Posted by Bish on Saturday, September 24, 2011 12:29 PM
Those are looking nice, and i like that wing tip colour.
Posted by VanceCrozier on Monday, September 26, 2011 7:37 AM
(OK, this is kind of a "thread-bump" Whistling pics coming later!)
I finished up the decals that I'm using on the Sea Harrier over the weekend, then went back and oversprayed with a lightened version of the base coat. (First time I've really done overspray that was more than just weathering.) It gave me the effect I was looking for, the decals as supplied look good, but are for a factory-fresh machine with bright reds and sharp black lettering. I then hit the upper surfaces with the last of my ModelMaster dullcote, which I am kind of regretting now. It seems to have sprayed unevenly, looks a little splotchy. Not sure if I'll call it "salt-spray stains" and leave it as-is, or use a little more dullcote from another can to finish it.
Also, one Bang Head moment - I managed to snap the pitot tube(?) that mounts to the nose. I'll have to save the piece that mounts the tube, attach some brass rod to it. Ahhh well, it'll be stronger in the long run anyway I suppose!
    November 2006
Posted by dupes on Monday, September 26, 2011 8:46 AM
Hey fellas! One of the fall contests is in the books, means I'm finally done with a 3-month megabuild. Jumping back into the Scimitar shortly - will be nice to do something smaller, and this thread REALLY needs some armor!
Big Smile
Posted by VanceCrozier on Monday, September 26, 2011 9:16 AM
Dupes is back!!! Yes Cycling season is winding down too I suppose? Looking forward to the Scimitar!
    October 2008
Posted by bsyamato on Monday, September 26, 2011 9:56 AM
Nice progress Azorean  Yes The insigna color looks good too, i remember when i used the one from model master was really orrible to use, like a slimer and a terrible smell Dead .
Vance waitin for seapictures Big Smile
Dupes good to you're back Beer the only tracks here, effectively are only from background cd player..
    December 2009
Posted by Azorean on Saturday, October 1, 2011 9:56 AM
I forgot to paint the black stripes along the fuselage...
Now we are ready for the rest of the decals.
Posted by Bish on Saturday, October 1, 2011 10:05 AM
Dupes, look forward to seeing the baby tank.
Azorean, that looks very nice, a nice paint job there.
    November 2006
Posted by dupes on Saturday, October 1, 2011 10:30 AM
bsyamato
Haaahahahha...nice. Speaking of tracks, I accidentally picked up some Friuls for the Scimitar in the interim - the kit ones are WAY too tight, leading to stretchiness, which made them look totally fake. ALSO snagged the out-of-print Bison decal sheet that includes markings for a Falklands-specific Scimitar! Pretty happy I was able to find those. Had hoped to get a few accessories from Accurate Armour as well (those big fat ropey tow cables and correct fire extinguishers) but wasn't able to justify the expense. Maybe later. Will just have to do with what's on hand!
Vance - yeah, cycling season is indeed winding down - couple hundred more miles and I meet my goal for the year. After that, I'll head out if it's sunny/warmish, otherwise it's 100% bench time.
Bish - glad to be back! Super motivated to build after going to AMPS last weekend (and Granitecon in 2 more weeks).
    December 2009
Posted by Azorean on Saturday, October 1, 2011 3:25 PM
With most of the decals
    October 2008
Posted by bsyamato on Saturday, October 1, 2011 4:49 PM
Dupes so accidentally you increase the build time with all these extra pieces Cool
Azorean you just show how a matchbox kit can be turned into a great build YesYes
my harrier need more beers to take off
