Airfix Group Build 2011-2012
    April 2010
Posted by Theuns on Wednesday, October 26, 2011 10:04 AM
I actually have pix of the SAAF that had a "pet" full grown Lion at one of the bases! So it might not be so far fetched LOL!
As for the National markings, when we were "playing" in Angolan airspace they were regularly ommited, not like there was actually anyone else it could be if they were shot downWink
I will be starting a 1/72 new tool Airfix BF 110 for the Africa GB, so it might just pop up here aswell.........just to show I can actually bash some plastic LOL!
Theuns
    October 2008
Posted by bsyamato on Wednesday, October 26, 2011 10:28 AM
Noah T
Checkmateking02, Greenshirt and Bsyamato thanks for the encouragement.
Looks like the Italeri Hs129 B-3 has some better details on the engines and the gear doors for sure. I read about the stripes on the wing for the pilot to better line up the plane and was going to mask some off, but whats the white dash on the fin? Nice weathering too BTW. What grade octane is in that triangle I have some spares. The orig decals dont look too good so im improving from a great sheet of 190's that i just picked up. Wish some of the spiral decals I have would work but these spinners are small. This plane is really... Must've been a heck of a ride, good thing they say it was underpowered (and horrible in the desert enviorn apparently). For a twin engine bird this thing is little.
It's normally than the italeri is better than the old airfix , i picked it few time after the kit was published about 95-96 and finished in same period.
The kit had the option to another one with props spirals but i avoid these subjects when is possible Tongue Tied i had lots of problems with spirals on a me-410 (another aircraft with a big gun on the nose) and after some test i just painted with a freehand brush Paradise lots of patience needed.
If i remember Vance had posted something about a masked propeller cover. Decals are not good to reproduce (recently i tried on my revell greif, after some attempt i just trow away spiral decals....Angry ).
Will try next time to paint the propeller cobers in white and after put a stripe of tape around it, probably will work .. at least i hope Hmm
the white on the fins are just the serial number i think . If you need some close view for the gun just tell about, this 129 is still alive Surprise
Posted by VanceCrozier on Wednesday, October 26, 2011 12:54 PM
You are right bsyamato...
For this one I didn't use the decal spiral. I painted the propellor hub white, then used a narrow strip of masking tape, starting at the muzzle opening at the front & pulled it around & around until I had my entire spiral in place. Then I airbrushed the black-green. You can see one little spot where it wiggled out of place a little bit, but it did the job quite well. Next time I think I would use a quick spray of dullcoat etc. to seal the tape up better before applying the final colour.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2009
Posted by Khalee2 on Thursday, October 27, 2011 5:29 PM
Well if I can join this one I will be doing a 1/72 scale FAA Corsair.
    March 2010
Posted by Scorpiomikey on Thursday, October 27, 2011 11:26 PM
No worries, front page updated. If ive missed you just gimme a nudge. Ive been laid up with a chest infection and havent been watching things as closely as i probably should have.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    October 2008
Posted by bsyamato on Friday, October 28, 2011 4:44 AM
nice Vance, i will try to use (on the greif) if i had again electrical insulator tape, probably i have someone in the basement. Instead of normal tapes is easier to bend.
Posted by VanceCrozier on Friday, October 28, 2011 7:12 AM
electrical tape could probably be pulled around the curves better, I'll have to try it next time.
Posted by VanceCrozier on Friday, October 28, 2011 8:46 AM
Update on the Mirage...
underside gray (ModelMaster enamels) already on & dry; masked off & upper tan sprayed on (Humbrol enamels).
Instruction sheet scanned & scaled up for masking the camo,
Masking tape in place,
Green applied (Tamiya acrylic after 4-5 days of allowing the enamels to cure), masking tape removed. I see a few spots that will need to be touched up before weathering & clear-coats, but the tape job worked pretty well. Using the acrylics & misting them on slowly probably helped avoid paint bleeding under the tape as well.
Next up in the paintshop - black nosecone, white markings on the tail, metallics on the exhaust can.
    August 2011
Posted by Noah T on Friday, October 28, 2011 8:54 AM
Vance thanks for showing us your process. Having it all laid out flat like that, thats the sort of obsessive thing that makes me feel better!
I can tell its going to be sharp.
On the bench: 72nd scale P51D, P47D Razorback
---Everything Is What It Is, And Not Another Thing.---
Posted by VanceCrozier on Friday, October 28, 2011 9:08 AM
HA - obsessive?!?! Yes, probably! That's likely what slows me down so often - I don't dare start something unless I'm convinced it'll work. Laying it out flat - I figured the easiest way for me to get this pattern was to get the upper surfaces masked properly first, then kind of fill in the areas along the sides. Glad you like it!
    September 2003
Posted by checkmateking02 on Friday, October 28, 2011 9:59 AM
Vance:  great progress.  Looking good.
I've been wondering how to lay out the camouflage masks for the Gladiator I committed to for this build.  I think I'll be appropriating your method.  Thanks.
Posted by VanceCrozier on Friday, October 28, 2011 10:19 AM
Thanks checkmateking - and appropriate away! I used some of that Frog tape this time - by the time I laid it down on the cutting mat, peeled & applied I had a few small spots that began lifting. I might try it with something a little tackier next time, but overall I was happy with the results.
    October 2008
Posted by bsyamato on Friday, October 28, 2011 10:37 AM
Vance this is what i call BIG patience about painting BeerBeer
the f-1 come great !! and the shapes of this plane convinced me even more Stick out tongue
Posted by VanceCrozier on Friday, October 28, 2011 11:48 AM
Now that it is getting some colour on, the shape is really growing on me as well. It certainly looks different than anything else I have in the collection.
    August 2007
Posted by DUSTER on Sunday, October 30, 2011 5:36 PM
Vance now you've done it !  My super secret method is out for all to see.
Gee after all the time I took to steal  er Borrow the idea from someone a long time ago, on a forum like this one
Seriously  your Mirage looks great
Steve
Posted by VanceCrozier on Monday, October 31, 2011 8:01 AM
DUSTER
Vance now you've done it !  My super secret method is out for all to see. http://i171.photobucket.com/albums/u294/PropDuster_album/Smileees/getsmileyCAS2JLY0.gif
Gee after all the time I took to steal  er Borrow the idea from someone a long time ago, on a forum like this one http://i171.photobucket.com/albums/u294/PropDuster_album/Smileees/c_laugh.gif
WHAT!! You mean I'm not the first one to try this ever?!?! Whistling I guess I can stop filling out those "copyright" forms now huh??
    February 2011
Posted by the real red baron on Monday, October 31, 2011 3:07 PM
ScorpioMikey - I would like to enter a Airfix 1:72 Corsair.
    March 2010
Posted by Scorpiomikey on Monday, October 31, 2011 3:38 PM
Front page sorted. Which corsair? Airfix has done several versions. F4U, A-7?
My signature
    September 2011
Posted by Centhot on Monday, October 31, 2011 3:46 PM
Looking great Noah and Vance!  Both two excellent builds.
2012 A/B/C: 10/3/0 (Acquired/Binned/Completed)
    February 2011
Posted by the real red baron on Monday, October 31, 2011 4:05 PM
Hard to say but the box says - 1:72 Vought F4U Corsair [FAA] with a corsair in british markings on the front, but mine is going to be in USN markings, but I don't have any in the spares box, and I have already painted it.
You wouldnt happen to have any spare 1:72 USN decals would you Whistling
    March 2010
Posted by Scorpiomikey on Monday, October 31, 2011 4:14 PM
Only in 48 scale unfortunatly. I do have some early USAAF P-51A decals though, star in a circle with yellow trim.
My signature
    February 2011
Posted by the real red baron on Monday, October 31, 2011 4:27 PM
How long are they? From one band to the other?
The corsair is a fairly big aircraft even for 1:72, they may fit?
Dimensions - length - 138mm. wingspan - 173mm.
    March 2010
Posted by Scorpiomikey on Monday, October 31, 2011 4:47 PM
When i say 48 scale, i mean theyre actually 48 scale corsair decals. got them for my f4u-4 for the korean war GB.
Ill have a hunt around tonight, might have something.
My signature
    October 2008
Posted by bsyamato on Monday, October 31, 2011 7:55 PM
Repairing the wscout canopy disaster :
Used 4 pieces of balsa for the mould
refined with putty
and after loooots of try with clear plastic sheets the good one
ok not perfect but sure better than the original Embarrassed
after lots of cuts and designed the frames with a blade, i fixed the rear with CA glue
that's all
    February 2011
Posted by the real red baron on Monday, October 31, 2011 11:35 PM
Oh, sorry. lol
I thought you might of meant 48 for a much smaller plane? If you find anything, I will be very gratefull!! Thankyou for helping!! Bow Down Beer
Posted by VanceCrozier on Tuesday, November 1, 2011 6:56 AM
bsyamato
http://i405.photobucket.com/albums/pp139/bsyamato/modellismo/scout%20airfix%2072/100_8688.jpg
WOW! Nice how-to on how to replace a canopy!! That should look very good after painting,
    August 2005
Posted by Phil_H on Tuesday, November 1, 2011 7:21 AM
Nice save bsyamato.. Looking good.  Big Smile
    February 2011
Posted by the real red baron on Tuesday, November 1, 2011 5:21 PM
Looks good bsyamto.
This is the current stage in which my corsair sits. I attempted my first navy plane in a tri-colour scheme.
Scorpio -  its ok, you don't need to send me those decals anymore, Gamera was so nice as to help me out and has already collected them together.
Thanks for the offer anyway!!
    March 2010
Posted by Scorpiomikey on Tuesday, November 1, 2011 5:50 PM
Thats cool, she looks nice, i hope my tamiya wildcat turns out that nice. Thats one ill be building completely OOB if i can recover the decals.
My signature
    February 2011
Posted by the real red baron on Tuesday, November 1, 2011 5:56 PM
Thankyou, what does OOB mean?
That reminds me, have you decide what your going to enter in the PH 70th GB?
