wBill,, great installment. Your reads are always informative. Nice work on the extra links, PE and antenna config..... Always a pleasure observing your posts,,, !
Carl,, looking forward to the pz-fix pics,,,
I've been jumping around a bit with the pz command build. While I was waiting for the Verlinden interior detail set I began moving into sub-assemblies.
I started with some work on the Friuls... a dip into Blacken-It. I like to let the tracks "blacken" in stages..... first just a short dunk, remove, pad dry and let air dry. I dip them again and follow the same pattern. It blackens them in spurts and leaves a hint of oxidation / rust in some of the corners and low lying areas. I like to add a thin black brown wash afterwards... the wash will wait until shortly before I am ready to mount them though.
Bouncing around in sub-assembly-land,,,, I put together the rear deck.
A lot of hatches which could be posed open... (I was SO tempted)....... a little PE screening,,, nothing over the top.
There was a small gap between the upper deck plate and the sides. I stretched some sprue and placed.
Cut the ends off,,, add a little liquid glue and let dry.
Then I use a curved / point detail tip with a small wood burner (a dremel / drill speed control to adjusti the heat) melting the styrene stretched sprue into a weld seam.
While the weld seam looks a bit bulbous, a little micro-filing and a bit more liquid glue blends and reduces the effect.
While it's not much,,, it's progress.... and I am looking forward to starting on the Verlinden interior set -
I also want to thank a number of you for pointing me in the right direction on this set.....
Hope to have some more informative build pics soon. Thanks and as always,,, all comments welcome.
Bill
