Fw 190 Butcher Bird 2013 (extended to June 2014) Group Build
    February 2014
Posted by dflu78 on Friday, April 11, 2014 11:04 PM
Finished up the main colors. Really liking where it's at right now.The dark green isn't really represented well in the photos.
    August 2009
Posted by JOE RIX on Friday, April 11, 2014 11:36 PM
Oh Hell Yeah! Now you've got it goin' on dflu. That looks awesome.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    March 2012
Posted by mustang1989 on Saturday, April 12, 2014 3:23 AM
I'll see your Hell Yeah and raise you five Joe! This is truly turning out to be one of the best schemes I've ever seen. Keep takin' your time dflu, she's turning out great!
 Forum | Modelers Social Club Forum (proboards.com)
    July 2011
Posted by handiabled on Saturday, April 12, 2014 7:45 AM
Looks great! Be waitin for more!
    April 2013
Posted by SchattenSpartan on Saturday, April 12, 2014 2:05 PM
I lost count of how many paint jobs you put on that model, but every single one looked better than the one before and this is no exception. Marvellous work!
    September 2013
Posted by blackdog62 on Saturday, April 12, 2014 2:48 PM
Well it looks like you have your Edward under control. What's your plan for gun panels open/closed ?
    July 2011
Posted by handiabled on Saturday, April 12, 2014 2:51 PM
Heres where we are at, weathering close to done, have to fix one missing trim tab, getting there, Thanks for lookin Everyone! Smile
    March 2012
Posted by mustang1989 on Saturday, April 12, 2014 7:20 PM
Lovin' it Handi!! Say, aint those engine panels gonna be open?
    March 2010
Posted by Nathan T on Saturday, April 12, 2014 7:57 PM
Sweet camp handi. How did u weather the underside?
    March 2012
Posted by mustang1989 on Saturday, April 12, 2014 8:14 PM
Nathan T
I'll second that question.
    September 2013
Posted by blackdog62 on Sunday, April 13, 2014 12:02 AM
Dflu you you got it goin on lookin good
    September 2013
Posted by blackdog62 on Sunday, April 13, 2014 12:06 AM
Looks like a ridin hard combat aircraft
    February 2014
Posted by dflu78 on Sunday, April 13, 2014 12:06 AM
Thanks everyone. Really encouraging. Keep moving forward on this one.
I've done a lot of painting today. From the master bathroom to this project and the P-47 sharing the bench...phew...I am tired.
Anyway, some mask work. All you see here is paint. The balkenkreuz  mask for the fuselage sides gave me some fits, so I laid them on in a manner that allowed me to do the white parts. The black will be easy enough to mask off and paint.
Note the mask for the "chessboard" pattern is still in place in anticipation for the black squares.
    March 2012
Posted by mustang1989 on Sunday, April 13, 2014 4:31 AM
This is nothing short of impressive dflu. If it's a real look you are after then I'd say that you  are well on track!!
    April 2013
Posted by SchattenSpartan on Sunday, April 13, 2014 5:49 AM
Handi: Great paint job and weathering! She looks like she has seen a lot of action!
Dflu: Your work really is spectacular!
    July 2011
Posted by handiabled on Sunday, April 13, 2014 7:53 AM
Dflu your doing an awesome job with the masks and mottle ! Looks really sharp!
Mustang the cowls will be open on the 109 that's waiting for a new decal sheet, not this one as funding for the resin motor was disapproved by the commander in chief. As for the weathering I use a quirky method with a few before steps and not many after, and it was a trial and many error deal figuring out what would work right. But it seems to always work well with RLM colors if done right... After pre-shading panel lines and other detail and putting down paint as usual and then Future.  Here's the disclaimer.... If your Future coat isn't good, or "fisheyes" ect, you will be staining that area and will NOT be able to get it too release even wet. Preplanning this works if there's a place you want darker staining than others. Thusly heavier amounts of Future where you want less staining and vise versa. You want to mix a Contractors Permanent Marking chalk ( you can find at any hardware or big box diy place for a couple bucks for a pound or more ) with water and a drop of dish soap just as any pastel type wash, but ... over exaggerate the amount of chalk, put a lot of it in to where you get a slurry mix on the bottom, ( it took me a few try's to get it right ) Before applying  make sure that if going over any decals that they are well bonded and then recoat with Future.  From the bottom of the mix apply with a q-tip. It should go on grainy and solid colored.   Let it dry completely , then starting with a cotton ball wipe in the direction of air flow. Sometimes a bit wiping is needed before it starts to release then as you go you can control what you want to leave behind. Smaller areas or getting better control just wipe with a dry q-tip. When it needs to be taken off areas where dry wiping won't work then you can use the lick and wipe q-tip method.  This probably isn't for everyone, and I don't weather every bird this way, but when you want a worn as ever look this achieves it.
    May 2013
Posted by Greg on Sunday, April 13, 2014 6:58 PM
dflu, that is one special paint job / scheme. Looks terrific. My hat is tipped to you for your perseverance re all those re-do jobs. I agree, each one DID look better than the previous.
Handi, that bird is looking amazing.
    February 2014
Posted by dflu78 on Wednesday, April 16, 2014 10:27 PM
Got the painting and decals all wrapped up finally. Did I mention I hate decaling? Anyway, things didn't go so badly this time around. Well give it a day of so and see if any decide to silver before moving on to a protective coat.
    March 2010
Posted by Nathan T on Wednesday, April 16, 2014 10:44 PM
Cool. What markings are painted and which are decals?
    February 2014
Posted by dflu78 on Wednesday, April 16, 2014 10:51 PM
The only decals are the slogan in white on the fuse (that mask was provide but was unworkable), data stencils and walkways. The tail code, swastika, balkenkreuz, and numbers were all mask.
    March 2012
Posted by mustang1989 on Thursday, April 17, 2014 2:39 AM
Wow dude! That is just one BAD A looking 190! A job worthy of a friggin architect!!!
    April 2013
Posted by SchattenSpartan on Thursday, April 17, 2014 3:29 PM
mustang1989
A big "Amen" to that! All the work on that camo pattern really paid off!
    February 2014
Posted by dflu78 on Friday, April 18, 2014 12:03 AM
Thanks guys. I"m really enjoying this one. I've loved every bit of this kit and managing to pull off a scheme that I've always wanted to do but that's haunted me really has me tickled pink. I'm just glad I can share. Thanks!
    August 2009
Posted by JOE RIX on Saturday, April 19, 2014 3:41 PM
dflu, Your efforts have paid of in spades! The camo is just fantastic. And those masks turned out remarkable. Beautiful work dflu. It really is.
    July 2011
Posted by handiabled on Saturday, April 19, 2014 5:04 PM
Dflu, bird looks amazing, here's our meager progress in comparison,, busied the gears and a bit more weathering. Have a good Easter all.
    March 2012
Posted by mustang1989 on Saturday, April 19, 2014 7:11 PM
This looks awesome handi!! Love the camo and weathering!!!!
    March 2010
Posted by Nathan T on Saturday, April 19, 2014 7:30 PM
Same for me handi! The camo and weathering are right on! Looks just like the real yellow 2. So u have that pic?
    July 2011
Posted by handiabled on Saturday, April 19, 2014 7:36 PM
Thanks Mustang and Nathan,  actually I do not have a pic of that bird,,, kinda winging it..Whistling Just putting the wear and tear shown on the most common areas of other 190's,,, I kinda blended into one...
    August 2009
Posted by JOE RIX on Saturday, April 19, 2014 11:11 PM
You've got some sweet action going on there Handi. Very nice.
    February 2014
Posted by dflu78 on Saturday, April 19, 2014 11:52 PM
Handi, I'm liking your Dora a lot. You certainly are scared of going for the heavy worn look...much unlike me. You've pulled it off well though.
Well guess what? She's done. I really plowed through the past couple of days and got this one done. Like I had mentioned (as per SWMBOs request) I went light on the weathering here. Nothing but Flory wash over gloss...I left it for 24 hours so it stained a little more than customary. but it;s just right I think. I decided to forgo the usual dullcoat finish and used some satin varnish to keep it a little "newer" looking. Its reflecting a lot of lite here, but looks much better to the eye. Again, just about what I was hoping for.
Looking at the following two pictures I realize now I need to get some RLM 02 around the edges of the wheel wells where I got some overspray.
