Mustang, wow, that DB mill looks real. I can't wait to see the rest.
I'm in for an update on my A-6. I was able to get the upper RLM 74/75 paint scheme and gloss coat down last night. As I said earlier, this was my first experience with Gunze Aqueous. I can honestly say I prefer Tamiya paints. I just don't like the glossiness of the Gunze and it seems to take forever to get the paint/thinner ratio to where it sprays without being translucent. It seemed like I was adding paint forever. It could be due to the thinner I used, which wasTamiya X-20. On the positive side, I was able to add XF-2 Flat White to lighten it for weathering and to my eye, Gunze really nailed the RLM colors. They look dead on. I will continued to experiment with these, at least for my RLM needs. Sometimes its hard to teach an old (err...middle-aged) dog new tricks
I left off last time after I sprayed down the RLM 75. I used the instruction sheet as a reference and rolled up Blue Tac that outlined the camouflage pattern on the wings. I prefer this method because it will leave a soft demarcation line, which just look better to my eye (I even do this on Spitfires and the like which have hard lines apparently). Once done, I dial the air pressure down to about 5 or 10 psi (to reduce overspray) and I built up the color. I added the fuselage mottling at this point as well, again, using the the instruction sheet profile as a general reference.
I then lightened the 74 and streaked the color to simulate condensation on the upper wing. I then removed the Blue Tac and returned to the original RLM 74 at which time I added more mottling until it looked like the profile picture (well....close enough...not an exact science here).
All masking tape was removed and I was pleasantly surprised on how the headless eagle exhaust area (don't know how else to describe it...lol) turned out. Like the cowl, It looks much better than a decal. A post shade was then added, primarily around the control surfaces, gun breaches, and anywhere else subject to dirt to add an extra dimension.
I put the engine into the cowl then added it to the front of the airframe, temporarily attached with a glob of Blue Tac (I use this stuff for everything). Everything fit fine. I still don't understand the fuss about cowl fit on this kit. Maybe I'm mistaking this kit for another one.
The whole thing was sprayed with Alclad II Clear Coat to await decals. I hate Hasegawa decals so other than the fuselage 5's and maybe some other plane specific decals, these will be pieced together from my spare decal box.
Thanks for looking. More to come soon.
Joe
